Home » Language IDEs » ServerTools (WTP) » Environment Command Framework and Dynamic Wizard Framework
Environment Command Framework and Dynamic Wizard Framework [message #201529] Mon, 08 October 2007 18:27 Go to next message
Where can I find some documents about these two frameworks in WST? Thanks.
Re: Environment Command Framework and Dynamic Wizard Framework [message #201652 is a reply to message #201529] Tue, 09 October 2007 15:01 Go to previous messageGo to next message
Hi Feng,
Currently there are no documentations on these 2 frameworks, only
Javadoc is available. These 2 frameworks are still considered internal
API meaning that we won't guarantee compatibility across different
releases. If you want more information, you can take a look at the WTP
Web service wizard and see how to use these 2 frameworks.
Kelvin
Re: Environment Command Framework and Dynamic Wizard Framework [message #201683 is a reply to message #201652] Tue, 09 October 2007 17:39 Go to previous messageGo to next message
Thanks Kelvin. I will take a look at the web service code. Just curious,
are these two frameworks broadly used in WTP? Why WTP introduced another
wizard framework, will they get merged into the platform as the common
navigator framework did?
Re: Environment Command Framework and Dynamic Wizard Framework [message #201774 is a reply to message #201683] Wed, 10 October 2007 16:35 Go to previous message
Hi Feng,
As far as I know, the WTP Web service is the only user of these 2
frameworks. The goal of the dynamic wizard framework is to introduce a
flexible framework allowing commands/wizard pages to be dynamically run
based on runtime condition.
We currently do not have any plan to merge this into the platform.
Kelvin
Previous Topic:Issues in using Structured Text Editor
Next Topic:Eclipse ATF new name - vote here : http://www.surveymonkey.com/s.aspx?sm=xpcUsNQpBZ5J3a70bXHzyw_3d_3
Current Time: Tue Sep 16 14:02:48 EDT 2025
Powered by FUDForum. Page generated in 0.07675 seconds
