Home » Language IDEs » Java Development Tools (JDT) » Ant Run menu missing on 3.1M6
Ant Run menu missing on 3.1M6 [message #201462] Wed, 20 April 2005 10:22 Go to next message
Originally posted by: westerdaled.bigfoot.com
I have just migrated to Eclipse 3.1M6 from Eclipse 3.02 and am now unable
to run
my ant build scripts. I have now uninstalled Xmlbuddy 2.0.38 in case this
was confusing Eclipse but have left MyEclipse 3.8.4 betaFor 3.1M6; this
was next on my uninstall list.
Under preferences-->Ant General settings: build.xml is associated with the
ant editor.
From the build.xml pop-up menu, the "select Run Ant...." does not exist!
Does anyone know where it was gone and if so how to get it back!
Daniel
Re: Ant Run menu missing on 3.1M6 [message #201480 is a reply to message #201462] Wed, 20 April 2005 10:50 Go to previous messageGo to next message
Originally posted by: chaves.inf.no.ufsc.spam.br
Daniel, are you sure the XML markup is valid? Can you provide the script
here? The action will only be enabled if Eclipse can verify the file
looks like a valid Ant script (the name is not enough).
> unable to run
> this was confusing Eclipse but have left MyEclipse 3.8.4 betaFor 3.1M6;
> this was next on my uninstall list.
> the ant editor.
> Regards
> Daniel
Re: Ant Run menu missing on 3.1M6 [message #201494 is a reply to message #201480] Wed, 20 April 2005 13:07 Go to previous message
Rafael
Thanks for getting replying so quickly. I did try other known good build
scripts in other projects and got the same result. It seems MyEclipse
3.8.4 betaFor 3.1M6 might be the problem because as soon as this was
uninstalled
my "Run Ant" menu reappeared, allowing me to test our build.xml file.
I have raised this bug with Genuitec and await there response.
Also, I may just reinstall MyEclipse tonight to prove again this is the
issue.
REgards
Daniel
>> unable to run
>> the ant editor.
>> Regards
>> Daniel
>>Y
Previous Topic:how to get full path editor dropdown list
Next Topic:ant build parameters
Current Time: Sat Jul 26 09:31:45 EDT 2025
Powered by FUDForum. Page generated in 0.05279 seconds
