Home » Language IDEs » ServerTools (WTP) » creating a new key combination for a WTP command
creating a new key combination for a WTP command [message #200896] Mon, 01 October 2007 14:57 Go to next message
Originally posted by: adam.hardy.no.spam.cyberspaceroad.spam
How would I do this? Can I unzip a jar to edit the plugin.xml? If so, which jar
would it be and what command for mapping a key combination to the 'publish'
button on the servers view?
Adam
Re: creating a new key combination for a WTP command [message #201430 is a reply to message #200896] Sun, 07 October 2007 12:37 Go to previous messageGo to next message
> which jar would it be and what command for mapping a key combination to
> the 'publish' button on the servers view?
AFAIK I should be able to go into one of the WTP jars in the eclipse
installation to configure my desired key combination to the appropriate WTP
plugin.xml file.
Am I totally misguided here? Any answer would be most welcome.
Re: creating a new key combination for a WTP command [message #201437 is a reply to message #201430] Sun, 07 October 2007 13:50 Go to previous messageGo to next message
>> to the 'publish' button on the servers view?
> WTP plugin.xml file.
You can create a custom binding for any command. You don't have to
modify jars, or plugin.xml files to do this. Just do a search in the
Eclipse help for "key bindings" or "assigning custom key bindings".
This should get you going.
Dave
Re: creating a new key combination for a WTP command [message #201757 is a reply to message #201437] Wed, 10 October 2007 16:05 Go to previous messageGo to next message
>> appropriate WTP plugin.xml file.
> Eclipse help for "key bindings" or "assigning custom key bindings". This
Well I hope you can create a custom binding for any command, but it's not in the
General->Keys menu, even if you check the "include unbound commands" and
uncheck all the advanced filter options.
This Keys menu /just doesn't contain/ the 'publish' button.
Check it out.
I am asking about jars and plugin.xml files because that's what I was told would
be the most likely solution (on another eclipse list).
But thanks for answering! I was beginning to think this must be some sort of
taboo subject.
Adam
Re: creating a new key combination for a WTP command [message #202053 is a reply to message #201757] Sat, 13 October 2007 00:05 Go to previous message
> Check it out.
> told would be the most likely solution (on another eclipse list).
> sort of taboo subject.
I would suggest opening a bug/feature request in WTP to make this
available if it currently isn't. Unfortunately there are really only a
handful of the community and committer members that are active in these
forums, so it may take a while for a question to answered.
The bug requests are monitored a lot more closely in WST/WTP than the
newsgroups unfortunately.
Previous Topic:File name in editor tab
Next Topic:Flexible Project
Current Time: Wed Nov 05 10:59:08 EST 2025
Powered by FUDForum. Page generated in 0.18239 seconds
