Home » Modeling » GMF (Graphical Modeling Framework) » node customization
node customization [message #200732] Wed, 06 August 2008 06:25 Go to next message
Hi, a wish to generate a node with the following shape
____________
| |__
| attribute| |
|____________| |
|____________|
Any ideas how i could make this shape (rounded rectangel with a second
rounded rectangle behind slightly right and down so it is visable)
Any help would be appreciated!
Thanks in advance,
Gary
Re: node customization [message #200872 is a reply to message #200732] Wed, 06 August 2008 09:20 Go to previous messageGo to next message
does anyone have any ideas how i could do this? I can't find anything to
help!!
Thank you,
Gary
Re: node customization [message #200950 is a reply to message #200732] Wed, 06 August 2008 22:56 Go to previous messageGo to next message
If you can't create it using .gmfgraph composition somehow, the tutorial
provides information on how to create custom shapes
(http://wiki.eclipse.org/GMF_Tutorial_Part_3).
Jevon
> ____________
> | |__
> | attribute| |
> |____________| |
> |____________|
> Thanks in advance,
> Gary
Re: node customization [message #201103 is a reply to message #200732] Fri, 08 August 2008 02:13 Go to previous messageGo to next message
I have code which does this, but not with rounded rectangles, just
normal ones. Since it uses line drawing, you will need to adjust it a
bit. If you are interested, I can send it to you.
Chris
> ____________
> | |__
> | attribute| |
> |____________| |
> |____________|
> Thanks in advance,
> Gary
Re: node customization [message #201183 is a reply to message #201103] Fri, 08 August 2008 09:41 Go to previous message
yeh that would be awsome!!!
Previous Topic:file location
Next Topic:[Announce] GMF 2.2.0 I200808071700 is available
Current Time: Wed Jul 23 05:58:47 EDT 2025
Powered by FUDForum. Page generated in 0.29032 seconds
