Home » Eclipse Projects » GEF » How can I create new geometrical shapes?
How can I create new geometrical shapes? [message #201104] Fri, 28 October 2005 18:33 Go to next message
Originally posted by: ciulbecca.yahoo.it
How can I create new geometrical shapes to increase the shapes of draw2d
with the same feature?
Re: How can I create new geometrical shapes? [message #201134 is a reply to message #201104] Sat, 29 October 2005 17:07 Go to previous messageGo to next message
Follow the steps below ...
1. Create a new class (say Triangle) as subclass of Shape.
2. Implement outlineShape and fillShape methods for your new class (Triange). Use the methods available with the Graphics parameter passed to those two methods.
Graphics has methods like ...
public abstract class Graphics
	public final void drawArc(Rectangle r, int offset, int length)
	public abstract void fillArc(int x, int y, int w, int h, int offset, int length)
	public final void drawLine(Point p1, Point p2)
	public final void drawOval(Rectangle r)
	public final void fillOval(Rectangle r)
	public abstract void drawPolygon(PointList points)
	public abstract void fillPolygon(PointList points)
	public final void drawRectangle(Rectangle r)
	public final void fillRectangle(Rectangle r)
	public abstract void drawText(String s, int x, int y)
Thats it. You should be get going with wonderful geometrical shapes close to your heart.
Venkat
Re: How can I create new geometrical shapes? [message #201148 is a reply to message #201134] Sun, 30 October 2005 05:54 Go to previous messageGo to next message
thanks venkataramana,
I have now a rhombus,...how can i do a connectionanchor like
elliptseanchor or chopboxanchor for the bounds of my new figure?...the
chopboxanchor leave empty space!
Re: How can I create new geometrical shapes? [message #201155 is a reply to message #201148] Sun, 30 October 2005 07:02 Go to previous messageGo to next message
I could not understand your question clearly. If you are looking for how to make connection-ends of different shapes, then may go through some sample tutorials listed below.
Check this link. http://www.eclipse.org/gef/reference/articles.html
You will get many references to tutorials and worked examples.
1. To start with read http://www.eclipse.org/gef/reference/GEF%20Tutorial%202005.p pt
2. Then read the Draw2D example from http://eclipse.org/articles/Article-GEF-Draw2d/GEF-Draw2d.ht ml
3. Then go ahead with Shapes example.http://eclipse.org/articles/Article-GEF-diagram-edit or/shape.html
4. After that I suggest you to go through Japanese GEF tutorials at http://www13.plala.or.jp/observe/index.html#draw2d
Though the samples are in Japanese, source-code could be understood very easily. The best examples available without any confusion for a novice.
5. After that, go to advanced examples like logic, flow, schema editors. etc.,
~Venkat
Re: How can I create new geometrical shapes? [message #201163 is a reply to message #201155] Sun, 30 October 2005 15:07 Go to previous messageGo to next message
No....I could like to know how clip the connection against the bounds of
my polygonal figure without the standard chopbox.
Re: How can I create new geometrical shapes? [message #201202 is a reply to message #201163] Mon, 31 October 2005 01:32 Go to previous messageGo to next message
Try this anchor ...
class WhereYouPlaceThereYouGetAnchor extends AbstractConnectionAnchor
	private Point fLocation;
	private final int fRelativeDX;
	private final int fRelativeDY;
	public WhereYouPlaceThereYouGetAnchor(IFigure owner, Point p)
		super(owner);
		fLocation = p;
		Point ownerOrigin = getOwnerAbsoluteOrigin();//owner.getBounds().getLocation();
		fRelativeDX = p.x - ownerOrigin.x;
		fRelativeDY = p.y - ownerOrigin.y;
		//System.out.println("RelativeDX: " + fRelativeDX + " RelativeDY" + fRelativeDY);
	private Point getOwnerAbsoluteOrigin() {
		Point ownerOrigin = getOwner().getBounds().getLocation();
		getOwner().translateToAbsolute(ownerOrigin);
		return ownerOrigin;
	public Point getLocation(Point reference)
		Point ownerOrigin = getOwnerAbsoluteOrigin();//getOwner().getBounds().getLocation();
		Point newLocation = new Point(ownerOrigin.x + fRelativeDX, ownerOrigin.y + fRelativeDY);
		//System.out.println("OWNER_ORIGIN: " + ownerOrigin + " NEWLOCATION: " + newLocation);
		return newLocation;
	public Point getReferencePoint() {
		return getLocation(null);
class GraphElementEditpart ...implements NodeEditpart
	public ConnectionAnchor getSourceConnectionAnchor(ConnectionEditPart connection) {
		//return new ChopboxAnchor(getFigure()); /* TODO Change anchors */
		return new WhereYouPlaceThereYouGetAnchor(getFigure(),
				((GraphEdgeEditPart)connection).getGraphEdge().getSourceAnchorLocation());
	public ConnectionAnchor getTargetConnectionAnchor(ConnectionEditPart connection) {
				((GraphEdgeEditPart)connection).getGraphEdge().getTargetAnchorLocation());
	public ConnectionAnchor getSourceConnectionAnchor(Request request) {
				((CreateConnectionRequest)request).getLocation());
	public ConnectionAnchor getTargetConnectionAnchor(Request request) {
From the CreateRequest, collect the position passed by getLocation() method and pass it to the constructor of WhereYouPlaceThereYouGetAnchor. Also pass the figure you are connecting to.
Whereever you click on a node, the connection stops there. So it can even be inside of your rhombus.
Venkat
Re: How can I create new geometrical shapes? [message #201209 is a reply to message #201202] Mon, 31 October 2005 04:36 Go to previous message
In this part of code:..
[code/
connection) {
((GraphEdgeEditPart)connection).getGraphEdge().getSourceAnch orLocation());
connection) {
((GraphEdgeEditPart)connection).getGraphEdge().getTargetAnch orLocation());
/]code
How must rename or which import i must do to not obtain error in this part:
"GraphElementEditpart ..."
"GraphEdgeEditPart"
Previous Topic:The presentation of the label text
Next Topic:Problem with GraphicalEditor and EditorPart
Current Time: Thu Jul 17 04:09:53 EDT 2025
Powered by FUDForum. Page generated in 4.41655 seconds
