Home » Language IDEs » C / C++ IDE (CDT) » switch to second desktop for debug in linux
switch to second desktop for debug in linux [message #200939] Sat, 01 September 2007 10:23 Go to next message
I have to debug a GUI-program which nearly fills the whole screen of my
monitor. But also the Eclipse-Window is filling the screen.
With linux there are two desktops between which I can switch with a mouse
click. A nice feature would be to have Eclipse on the first desktop and
the debugger perspective on the second.
Is this possible? Has somebody experience with it?
Nikosch
Re: switch to second desktop for debug in linux [message #200956 is a reply to message #200939] Sat, 01 September 2007 17:56 Go to previous messageGo to next message
Originally posted by: r_2.gmx.de
Hello Nikosch,
I haven't tried it for CDT, but you could open a second window in
eclipse (Menu Window\New Window) herein you could use the debugger.
To stitch it to a defined desktop it depends on your setup. I am using
devilspie (yes it IS its name ;-)) you can configure any
windowname/captionname to switch to a defined desktop.
hope it helps...
regards
Re: switch to second desktop for debug in linux [message #200981 is a reply to message #200956] Sun, 02 September 2007 14:57 Go to previous messageGo to next message
Kaiser, Hans wrote:
> Hello Nikosch,
> eclipse (Menu WindowNew Window) herein you could use the debugger.
> hope it helps...
> regards
this looks like the solution I am searching for.
But I have no idea how to configure a windowname to switch to a defined
desktop. Is this a function of eclipse or of linux?
I am working with openSuse 10.1. How do you do it with "devilspie"?
Nikosch
Re: switch to second desktop for debug in linux [message #200989 is a reply to message #200981] Sun, 02 September 2007 16:13 Go to previous messageGo to next message
okay fine part one of your request seems to be solved...
The next step is your desktop. Under Suse I think you are working with
kde. Here I am not sure if devilspie will work, afaik devilspie is a
gnome tool. Maybe it is also possible to manage kde desktops...
Your Eclipse caption/windowtitle changes, if you are in the debug
session. Isn't it? You can setup devilspie to use a regex for the
caption, so it will always move your regexed windowtitle to your wished
desktop.
regards
Re: switch to second desktop for debug in linux [message #201233 is a reply to message #200989] Fri, 07 September 2007 17:17 Go to previous message
> desktop.
> regards
Hi, my answer comes late, because I was on a business travel.
Thank you for the tip. But the solution with devilspie sounds quite
complicated for me as a newcomer. I will check it when I am more familiar
with my working environment.
Nikosch
Previous Topic:Qt Debug error
Next Topic:Custom indexer behaviour
Current Time: Sun Jun 08 05:44:25 EDT 2025
Powered by FUDForum. Page generated in 0.03568 seconds
