Home » Eclipse Projects » GEF » How can I run my gef design?
How can I run my gef design? [message #200819] Thu, 27 October 2005 15:00 Go to next message
Originally posted by: ciulbecca.yahoo.it
I have designed my model,I have created my
XYZcreationWizard,XYZEditor,XYZActionBarContributor,XYZconte xtMenuProvider,XYZPaletteFactory,XYZplugIn,the
packages command and parts...now what must I do to run the projet?
...I have lunch "run as Eclipse application"but after the opening
workbench i don't know what do(the plugIn exist in the plugin's list and
is the only trace of my project in all "new"workbench!!)
Re: How can I run my gef design? [message #200921 is a reply to message #200819] Fri, 28 October 2005 05:44 Go to previous messageGo to next message
In the file MANIFEST.MF you can add your editor as an extension and in
the "Extension Element Details" Tab you have to fill in the
extensions-property of your editor. The name you filled in there, is the
Extension of your editor-file. After done this, lunch your editor
with "run as Eclipse application", create a new simple project and then
create an new file with the right extension e.g. "test.XYZEditor" when
you have filled in "XYZEditor" in the extension-property. Then your
editor should start up.
Re: How can I run my gef design? [message #200968 is a reply to message #200921] Fri, 28 October 2005 08:58 Go to previous messageGo to next message
I haven't the manifest.mf!...How can I create it?
Re: How can I run my gef design? [message #201037 is a reply to message #200968] Fri, 28 October 2005 14:34 Go to previous messageGo to next message
but u should have a plugin.xml. open that one there u should have 2
links which allow u to open a new workspace either in debug or normal mode
regards
Astrid
Re: How can I run my gef design? [message #201069 is a reply to message #201037] Fri, 28 October 2005 15:32 Go to previous messageGo to next message
iHave not a plugin.xml...I have created a new empty project with my
packages..
Re: How can I run my gef design? [message #201082 is a reply to message #201069] Fri, 28 October 2005 15:39 Go to previous messageGo to next message
> packages..
if in the package explorer, u right click on the folder ,there u find
PDE tools, do u have a "convert to plugin projects" if so this will
create a manifest.xml
HTH
kind regards
Astrid
Re: How can I run my gef design? [message #201091 is a reply to message #201082] Fri, 28 October 2005 15:40 Go to previous message
>> packages..
> HTH
> kind regards
> Astrid
manifest.mf (sorry typo)
Previous Topic:how create new geometrical shapes
Next Topic:The presentation of the label text
Current Time: Fri Nov 07 17:23:08 EST 2025
Powered by FUDForum. Page generated in 0.05132 seconds
