Creating EditParts where the user click in the editor [message #200728] |
Wed, 26 October 2005 09:38  |
Originally posted by: harsh.ti.com
All,
I want to set the bounds of my figure so the x,y is the location of the
mouse cursor and the height and width are fixed. The problem is, my model
does not handle bounds related data and I would prefer it that way. In
some of the examples I have see, in the XYLayoutPolicy the
getCreateCommand method sets the bounds and sets the initial bounds and
then when the command is executed it it is stored in the model. Then in
the Refresh Visuals, when the edit parts are updated/created the bounds of
the figure are there. I know this is the ideal method but is there
another way so the model is not in play?
Thank you,
Harsh
Re: Creating EditParts where the user click in the editor [message #200867 is a reply to message #200728] |
Thu, 27 October 2005 18:59   |
Harsh, I understand your requirement legitimate in a situation like this ..
1. First time visuals are going to be created based on some model objects like some text-elements to be displayed etc.,(not visual model like x,y, w,h etc.,)
2. Once the visuals are rendered, then figure classes should store the x,y, w,h info. i.e, if a user moves a figure, then visual should update/refresh itself without having to get x,y from model, ofcourse model doesn't have it.
But finally when closing the diagram, where do you want to save your layout data ? Some visual model represention right ? Or you dont need to persist user modifications in diagram-layout..I mean user-changes in layout are never persisted..so everytime he is gonna get similar look.
Consider the above and may be rephrase your requirement once more. Then some solutions can be thought of to not make a roundtrip like this ;-)...
Tool -> Editpart -> Editpolicy - Command -> Model -> Editpart -> Figure
Indeed a sequence diagram will have all the messages in the chain above.
Venkat
Re: Creating EditParts where the user click in the editor [message #200991 is a reply to message #200867] |
Fri, 28 October 2005 10:23  |
Venkat,
We are storing our model layout in an xml file and persisting this with an
even greater solution. When the user opens a file recognized by our
editor, we concatenate information from 2 files, namely the model and the
layout file.
I figured out how to do it. Perhaps, there is a better solution but this
will do for now.
Thank you all for your help.
Harsh
FUDForum. Page generated in 0.26766 seconds
