Home » Language IDEs » C / C++ IDE (CDT) » Remote gcc GNU toolchain from Windows?
Remote gcc GNU toolchain from Windows? [message #200357] |
Mon, 27 August 2007 16:00  |
Originally posted by: michael.kropinski.gm.com
I am using Eclipse 3.3.0 and CDT 4.0 on Windows, and would like to know if
it is possible to use a remote gcc GNU toolchain on Linux, instead of
using a local MinGW or Cygwin toolchain?
Mike
Re: Remote gcc GNU toolchain from Windows? [message #200589 is a reply to message #200558] |
Tue, 28 August 2007 15:54   |
>>>>> Hi,
>>>>> know if it is possible to use a remote gcc GNU toolchain on Linux,
>>>>> instead of using a local MinGW or Cygwin toolchain?
>>>>> Thanks,
>>>>> Mike
>>>> Not currently, although people are looking at doing this.
>>> Do you think this is at all possible with the current CDT (via
>>> extension points)?
>>> Mike
>>>> Chris Recoskie
>>>> Team Lead, IBM CDT Team
>>>> IBM Toronto
>>>> http://www.eclipse.org/cdt
>> Yes... that's how we're planning on doing it. Basically add a new
>> "Remote Builder" option for managed build projects. Similar to the
>> Internal Builder, but it would invoke the compile commands over SSH or
>> whatever protocol the user chose.
>> Chris Recoskie
>> IBM Toronto
> You state "we're planning on doing it". Any thoughts on when this might
> be available? I�d rather not go down a path of developing a solution
> when there are plans in the work.
> Mike
Guess I've been called :-)
The plan is for my team to crank out a remote version of standard make
for Ganymede (June 2008). Remote MBS is on our roadmap but I don't know
if we'll have time to get it for Ganymede, so I haven't committed to it.
Chris Recoskie
IBM Toronto
Re: Remote gcc GNU toolchain from Windows? [message #200853 is a reply to message #200589] |
Thu, 30 August 2007 12:30   |
>>>>>> Hi,
>>>>>> Thanks,
>>>>>> Mike
>>>> extension points)?
>>>> Mike
>>>>> Chris Recoskie
>>>>> IBM Toronto
>>> Chris Recoskie
>>> IBM Toronto
>> be available? Iᅵd rather not go down a path of developing a solution
>> Mike
> Chris Recoskie
> IBM Toronto
Thanks for the date. Do you have a rough idea of how many man hours it
will take for full remote implementation?
Mike
Re: Remote gcc GNU toolchain from Windows? [message #200900 is a reply to message #200853] |
Fri, 31 August 2007 08:33  |
>>>>>>> Hi,
>>>>>>> to know if it is possible to use a remote gcc GNU toolchain on
>>>>>>> Linux, instead of using a local MinGW or Cygwin toolchain?
>>>>>>> Thanks,
>>>>>>> Mike
>>>>> extension points)?
>>>>> Mike
>>>>>> Chris Recoskie
>>>>>> IBM Toronto
>>>> or whatever protocol the user chose.
>>>> Chris Recoskie
>>>> IBM Toronto
>>> might be available? Iᅵd rather not go down a path of developing a
>>> solution when there are plans in the work.
>>> Mike
>> know if we'll have time to get it for Ganymede, so I haven't committed
>> to it.
>> Chris Recoskie
>> IBM Toronto
> Mike
I ballparked it at 25 person-days of effort, but that was for me to do
it (already more or less knowing what I'm doing). For someone not
familar with Managed Build's internals, it would no doubt take longer.
Chris Recoskie
IBM Toronto
Current Time: Thu Jun 05 02:42:57 EDT 2025
Powered by FUDForum. Page generated in 0.03461 seconds
