Home » Language IDEs » C / C++ IDE (CDT) » Remote gcc GNU toolchain from Windows?
Remote gcc GNU toolchain from Windows? [message #200357] Mon, 27 August 2007 16:00 Go to next message
Originally posted by: michael.kropinski.gm.com
I am using Eclipse 3.3.0 and CDT 4.0 on Windows, and would like to know if
it is possible to use a remote gcc GNU toolchain on Linux, instead of
using a local MinGW or Cygwin toolchain?
Mike
Re: Remote gcc GNU toolchain from Windows? [message #200411 is a reply to message #200357] Tue, 28 August 2007 04:16 Go to previous messageGo to next message
I'm not sure whether it works with Eclipse but distcc (a distributed
compiler) should do this ...
At least you can compile your program this way. There is probably also a
framework to debug and execute remotely but I don't remember the name.
You can of course also start Eclipse on the remote host and redirect the
output ... Seems to be the simplest solution.
Jens
Re: Remote gcc GNU toolchain from Windows? [message #200453 is a reply to message #200411] Tue, 28 August 2007 08:56 Go to previous messageGo to next message
> Jens
Thanks for the reply!
Do you think it would be possible via CDT extension points to use the
remote gcc GNU toolchain, instead of the local gcc GNU toolchain?
Mike
Re: Remote gcc GNU toolchain from Windows? [message #200461 is a reply to message #200357] Tue, 28 August 2007 08:59 Go to previous messageGo to next message
> if it is possible to use a remote gcc GNU toolchain on Linux, instead of
> Mike
Not currently, although people are looking at doing this.
Chris Recoskie
Team Lead, IBM CDT Team
IBM Toronto
http://www.eclipse.org/cdt
Re: Remote gcc GNU toolchain from Windows? [message #200526 is a reply to message #200461] Tue, 28 August 2007 09:43 Go to previous messageGo to next message
>> Hi,
>> Thanks,
>> Mike
Do you think this is at all possible with the current CDT (via extension
points)?
Mike
> Chris Recoskie
> IBM Toronto
Re: Remote gcc GNU toolchain from Windows? [message #200550 is a reply to message #200526] Tue, 28 August 2007 12:55 Go to previous messageGo to next message
>>> Hi,
>>> know if it is possible to use a remote gcc GNU toolchain on Linux,
>>> instead of using a local MinGW or Cygwin toolchain?
>>> Thanks,
>>> Mike
> points)?
> Mike
>> Chris Recoskie
>> IBM Toronto
Yes... that's how we're planning on doing it. Basically add a new
"Remote Builder" option for managed build projects. Similar to the
Internal Builder, but it would invoke the compile commands over SSH or
whatever protocol the user chose.
Chris Recoskie
IBM Toronto
Re: Remote gcc GNU toolchain from Windows? [message #200558 is a reply to message #200550] Tue, 28 August 2007 13:12 Go to previous messageGo to next message
>>>> Hi,
>>>> Thanks,
>>>> Mike
>> points)?
>> Mike
>>> Chris Recoskie
>>> IBM Toronto
> Chris Recoskie
> IBM Toronto
You state "we're planning on doing it". Any thoughts on when this might
be available? I’d rather not go down a path of developing a solution when
there are plans in the work.
Mike
Re: Remote gcc GNU toolchain from Windows? [message #200589 is a reply to message #200558] Tue, 28 August 2007 15:54 Go to previous messageGo to next message
>>>>> Hi,
>>>>> Thanks,
>>>>> Mike
>>> extension points)?
>>> Mike
>>>> Chris Recoskie
>>>> IBM Toronto
>> Chris Recoskie
>> IBM Toronto
> be available? I�d rather not go down a path of developing a solution
> when there are plans in the work.
> Mike
Guess I've been called :-)
The plan is for my team to crank out a remote version of standard make
for Ganymede (June 2008). Remote MBS is on our roadmap but I don't know
if we'll have time to get it for Ganymede, so I haven't committed to it.
Chris Recoskie
IBM Toronto
Re: Remote gcc GNU toolchain from Windows? [message #200853 is a reply to message #200589] Thu, 30 August 2007 12:30 Go to previous messageGo to next message
>>>>>> Hi,
>>>>>> Thanks,
>>>>>> Mike
>>>> extension points)?
>>>> Mike
>>>>> Chris Recoskie
>>>>> IBM Toronto
>>> Chris Recoskie
>>> IBM Toronto
>> be available? Iᅵd rather not go down a path of developing a solution
>> Mike
> Chris Recoskie
> IBM Toronto
Thanks for the date. Do you have a rough idea of how many man hours it
will take for full remote implementation?
Mike
Re: Remote gcc GNU toolchain from Windows? [message #200900 is a reply to message #200853] Fri, 31 August 2007 08:33 Go to previous message
>>>>>>> Hi,
>>>>>>> to know if it is possible to use a remote gcc GNU toolchain on
>>>>>>> Linux, instead of using a local MinGW or Cygwin toolchain?
>>>>>>> Thanks,
>>>>>>> Mike
>>>>> extension points)?
>>>>> Mike
>>>>>> Chris Recoskie
>>>>>> IBM Toronto
>>>> or whatever protocol the user chose.
>>>> Chris Recoskie
>>>> IBM Toronto
>>> might be available? Iᅵd rather not go down a path of developing a
>>> solution when there are plans in the work.
>>> Mike
>> know if we'll have time to get it for Ganymede, so I haven't committed
>> to it.
>> Chris Recoskie
>> IBM Toronto
> Mike
I ballparked it at 25 person-days of effort, but that was for me to do
it (already more or less knowing what I'm doing). For someone not
familar with Managed Build's internals, it would no doubt take longer.
Chris Recoskie
IBM Toronto
Previous Topic:Eclipse, CDT, SVN, MinGW
Next Topic:cc1plus.exe has stopped working
Current Time: Sat Jul 19 03:32:14 EDT 2025
Powered by FUDForum. Page generated in 0.05519 seconds
