Home » Modeling » GMF (Graphical Modeling Framework) » Re: Mutiple Deletes issue
Re: Mutiple Deletes issue [message #199783] Fri, 01 August 2008 07:27 Go to next message
Originally posted by: awm_abu.yahoo.com
Hi Christian,
Thanks for getting back to me on this.
One issue I am having with the solution below is that the read-only
transaction is not the same for each command that is being built.
Now maybe I am doing something wrong or looking in the wrong place but it
seems to me that in the EditHelperAdvice a different transaction comes in
with each request and therefore the map idea is not working.
Any ideas whats going wrong ?
thanks,
Alan.
Hi, Alan,
You can take advantage of the fact that the edit-helper constructs its
edit command in the context of a read-only transaction. You can use the
InternalTransactionalEditingDomain::getActiveTransaction() API to get
the current transaction and, in a map of some kind, cache your prompting
command with the transaction as the key.
Subsequent invocations of your advice can find the cached prompt command
and append elements to it instead of returning new advice commands.
Just be sure to purge the transaction from the cache when your prompting
command is dispose()d.
HTH,
Christian
Re: Mutiple Deletes issue [message #199855 is a reply to message #199783] Fri, 01 August 2008 09:05 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Alan,
Sorry, I had expected that the transactions would be optimized to a
single read. Perhaps these transactions all share a common root; follow
the getParent() references to find it.
HTH,
Christian
Alan wrote:
> Hi Christian,
> thanks,
> Alan.
> Hi, Alan,
> HTH,
> Christian
Re: Mutiple Deletes issue [message #199895 is a reply to message #199855] Fri, 01 August 2008 10:18 Go to previous messageGo to next message
Ya tried that one too as that thought did occur to me but still no go.
The transactions have no parents.
Any other ideas ?
thanks,
Alan.
"Christian W. Damus" <cdamus@zeligsoft.com> wrote in message
news:g6v1n3$e6m$1@build.eclipse.org...
> Hi, Alan,
> Sorry, I had expected that the transactions would be optimized to a single
> read. Perhaps these transactions all share a common root; follow the
> HTH,
> Christian
> Alan wrote:
>> Hi Christian,
>> thanks,
>> Alan.
>> Hi, Alan,
>> HTH,
>> Christian
Re: Mutiple Deletes issue [message #199923 is a reply to message #199895] Sat, 02 August 2008 12:12 Go to previous messageGo to next message
Hi, Alan,
Is there some request object that is passed around through all of the
edit-helper processing? I seem to recall, for example, that the
DeleteDependentsRequest has a reference to the originating
DeleteElementRequest (or whatever it's called). I imagine that the
delete requests for the nested elements similarly track the original
request. Look in the request's parameters map to see what you can find.
HTH,
Christian
Alan wrote:
> Any other ideas ?
> thanks,
> Alan.
-----8<-----
Re: Mutiple Deletes issue [message #200389 is a reply to message #199923] Tue, 05 August 2008 06:30 Go to previous messageGo to next message
Hi Christian,
I have had a look at the parameter map and the only thing in there is a key
of "edit policy command" and a value of DestroyElementCommand.
There does not seem to be any link back to anything I can use.
It just seems to be two seperate DestroyElementRequests not linked in any
way
Unless I am missing something of course.
I was thinking of using the configureRequest method to add something to the
paramter map
but again how do I know how to link them ?
Should I be coming at it in another way....like trying to figure out which
nodes are selected in the diagram when the delete is invoked for example ?
thanks,
Alan.
news:g7211d$cce$1@build.eclipse.org...
> Hi, Alan,
> DeleteElementRequest (or whatever it's called). I imagine that the delete
> requests for the nested elements similarly track the original request.
> HTH,
> Christian
> Alan wrote:
>> Hi,
>> Any other ideas ?
>> thanks,
>> Alan.
> -----8<-----
Re: Mutiple Deletes issue [message #200506 is a reply to message #200389] Tue, 05 August 2008 09:45 Go to previous message
Hi, Alan,
Yeah, I'm afraid you exhausted my store of ideas, such as it was.
My knee always jerks against such measures as looking back to a diagram
editor from a reusable component like edit-helper advice that really
shouldn't have knowledge of that context. It should be as usable in the
Project Explorer or any other view (e.g., EcoreTools inheritance
browser) as in the diagram editor.
Perhaps somebody else with more GMF experience than I can help you further.
Christian
Alan wrote:
> Hi Christian,
> way
> paramter map
> thanks,
> Alan.
>> Hi, Alan,
>> HTH,
>> Christian
>> Alan wrote:
>>> Hi,
>>> Any other ideas ?
>>> thanks,
>>> Alan.
>> -----8<-----
Previous Topic:[Announce] EuGENia
Next Topic:visual element
Current Time: Sun Jul 27 04:40:48 EDT 2025
Powered by FUDForum. Page generated in 0.04991 seconds
