Home » Archived » BIRT » passing JDBC parameter at runtime
passing JDBC parameter at runtime [message #200364] |
Fri, 10 November 2006 20:00  |
When I design a report, I create the dataset by configuring the JDBC
parameter. However, is it possible at run time, I would be able to send the
user id, password and schema information? Because that way, the report is
not bound to the hard-coded information.
Bidyut
Re: passing JDBC parameter at runtime [message #200626 is a reply to message #200568] |
Mon, 13 November 2006 19:00   |
Thanks Jason. That sounds interesting. Is there any documentation you can
point me to, so that I can get a better idea about that.
Bidyut
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:eja70t$bjl$1@utils.eclipse.org...
> You can also use script or property binding to change the user, password,
> driver and dburl on the fly.
> Jason
> "Bidyut Pattanayak" <bidyut@yahoo.com> wrote in message
> news:ej37bi$h8c$1@utils.eclipse.org...
>> Hi,
>> the user id, password and schema information? Because that way, the
>> report is not bound to the hard-coded information.
>> Thanks
>> Bidyut
Re: passing JDBC parameter at runtime [message #200634 is a reply to message #200626] |
Mon, 13 November 2006 19:24  |
There is information on this page:
http://www.eclipse.org/birt/phoenix/deploy/reportScripting.p hp
Here are a few examples of how to swap url and user using property binding
or script.
Jason
news:ejb0ve$msb$1@utils.eclipse.org...
> Thanks
> Bidyut
>> Jason
>>> Hi,
>>> Thanks
>>> Bidyut
Attachment: examples.zip
(Size: 55.75KB, Downloaded 96 times)
Current Time: Mon Sep 01 02:45:11 EDT 2025
Powered by FUDForum. Page generated in 0.06892 seconds
