Home » Archived » BIRT » Buddy Classloading for POJOs Access?
Buddy Classloading for POJOs Access? [message #200080] Thu, 09 November 2006 15:30 Go to next message
Originally posted by: flori.docufy.de
Hi!
I'm actually trying to use BIRT in a RCP application to create some nice
reports in PDF. I'm using hibernate, so I want to use some POJOs as data
source for my report. I found all these tutorials saying that I have to
put my classes into the WEB-INF/lib directory of the viewer plug-in -
but I'm not using this plug-in! So where to put the classes?
I am not very comfortable with putting an artifact under development
into a folder of my target platform.
As far as I understand, this whole WEB-INF hack is only necessary to
give the scripting engine access to my classes. But why not simply using
buddy classloading for that? Then I would simply have to put something like
Eclipse-RegisterBuddy: org.eclipse.birt.core
into my MANIFEST.MF and everything will be fine - at least at runtime.
Am I totally on the wrong track? Did you ever think about this?
Sincerely,
Florian
Re: Buddy Classloading for POJOs Access? [message #200324 is a reply to message #200080] Fri, 10 November 2006 13:33 Go to previous messageGo to next message
The WEB-INF/lib or the scriptlib directories are intended for web
deployment. The engine should be able to get at them if they are in your
classpath.
I have not attempted buddy loading with this but I would imagine it would
work. In addition you can set a system propery like
System.setProperty( EngineConstants.WEBAPP_CLASSPATH_KEY,"c:/myclasses" );
Jason
"Florian Thienel" <flori@docufy.de> wrote in message
news:ej033r$s0m$1@utils.eclipse.org...
> Hi!
> like
> Sincerely,
> Florian
Re: Buddy Classloading for POJOs Access? [message #200340 is a reply to message #200324] Fri, 10 November 2006 14:58 Go to previous message
Buddy classloading did not help either - I could not find out where to
register the buddy. I tried birt.core, birt.data and birt.report.engine.
So I gave up this idea.
But I found another solution: I set an array with all objects via the
IRunAndRenderTask.addScriptableJavaObject method and used this variable
to get access to my objects (varName is the name of the scriptable java
object):
open:
count = 0;
fetch:
if (count < varName.length) {
row["row1"] = varName[0].getName();
count++;
return true;
return false;
This works. I don't know if I found a new solution for this problem, but
I thought I better write it down anyways. Maybe that helps anybody.
Best Regards,
Florian
> classpath.
> Jason
>> Hi!
>> like
>> Sincerely,
>> Florian
Previous Topic:Setting step on chart axis with type Date/Time
Next Topic:ScriptEvaluationError: Invalid Field name
Current Time: Sat Nov 08 22:51:28 EST 2025
Powered by FUDForum. Page generated in 0.02753 seconds
