Hot-edit of JSP files with Tomcat 6.0 - should it require a republish? [message #200106] |
Thu, 20 September 2007 10:08  |
When I edit a JSP (actually .jspx) WTP detects the change and republishes
the whole application. This really slows things down. Isn't it possible to
simply reload the file that changed? I'm sure Tomcat can do it (haven't
tried it standalone in an exploded war for a while, but it used to work last
time I looked).
Re: Hot-edit of JSP files with Tomcat 6.0 - should it require a republish? [message #201725 is a reply to message #200378] |
Wed, 10 October 2007 03:52   |
Larry,
In case it helps with your 3.0 effort...
I had some success with editing the Tomcat server.xml manually. It seems to
work (reloading JSPs) as long as the only thing I change is a JSP and that
is in the web project. The change to server.xml is to set
autoDeploy="false" in the <Host/> element. Can't say I understand what that
did, but maybe someone else can explain?
Dave.
"Larry Isaacs" <Larry.Isaacs@sas.com> wrote in message
news:fd8euq$dno$1@build.eclipse.org...
> The text at the top of the Server Locations section likely explains it,
> i.e. "Server must be published with no modules present to make changes."
> Also, with respect to publishing just a changed JSP causing a republish or
> reload, it should not normally occur. The only situation that I'm aware
> of that it will always occur is if you have selected "Use Tomcat
> installation..." and the project added to that server has a Java utility
> project as a J2EE Module Dependency. The utility project's jar gets
> rebuilt on every publish, triggering the reload. I hope to fix that in
> WTP 3.0.
> Cheers,
> Larry
> Dave Syer wrote:
>> That option is greyed out. What else am I doing differently?
>> "adam hardy" <adam.hardy@no.spam.cyberspaceroad.spam> wrote in message
>> news:fd6a00$vj4$1@build.eclipse.org...
>>> Double-click your server in the Servers view. In the left-hand half of
>>> the 'Overview' window that appears, the second box down is the 'Server
>>> locations' config.
>>> Dave Syer on 21/09/07 13:30, wrote:
>>>> My org.*.component file looks identical to yours (except for some
>>>> additional <dependent-module/> elements). So I guess it's not that.
>>>> What was the other thing you mentioned "* (takes control)"? I don't
>>>> remember ever having the choice. Where did that show up?
>>>> news:fcu0e7$dsp$1@build.eclipse.org...>
>>>>> Now I have tomcat set up with the 'use tomcat installation (takes
>>>>> control)' option, which is one config option that might control when
>>>>> the context is reloaded. Another option could be the xml in your
>>>>> .settings/org.eclipse.wst.common.component file. Do you have it like
>>>>> this (or similar - mine's for maven):
>>>>> <wb-resource deploy-path="/" source-path="/src/main/webapp"/>
>>>>> <wb-resource deploy-path="/WEB-INF/classes"
>>>>> source-path="/src/main/java"/>
>>>>> source-path="/src/main/resources"/>
>>>>> source-path="/src/test/java"/>
>>>>> source-path="/src/test/resources"/>
>>>>> <wb-resource deploy-path="/WEB-INF/classes" source-path="/adam"/>
>>>>> <property name="java-output-path" value="build/classes"/>
>>>>> <property name="context-root" value="tradingcode"/>
Re: Hot-edit of JSP files with Tomcat 6.0 - should it require a republish? [message #210633 is a reply to message #200378] |
Thu, 20 March 2008 10:29  |
Originally posted by: sheremeta.greg.gmail.com
For anyone else who stumbles across this... I had the same problem, and
it wasn't caused by the use case Larry suggested. My problem was that I
had imported a co-worker's RAD project into my Europa install. Needless
to say, not a WTP problem and pretty stupid on my part. Everything
seemed to work just fine, except it would always reload the context
every time I changed a JSP.
I ripped out the .project, .classpath, .settings, and .metadata, made a
new Dynamic Web project (over the existing code), and now I'm enjoying
the beauty of hot-editing my JSPs. :-)
Thanks guys!
Greg
> or reload, it should not normally occur. The only situation that I'm
> aware of that it will always occur is if you have selected "Use Tomcat
> WTP 3.0.
> Cheers,
> Larry
>>> of the 'Overview' window that appears, the second box down is the
>>> 'Server locations' config.
>>>> message news:fcu0e7$dsp$1@build.eclipse.org...>
>>>>> when the context is reloaded. Another option could be the xml in
>>>>> your .settings/org.eclipse.wst.common.component file. Do you have
>>>>> it like this (or similar - mine's for maven):
FUDForum. Page generated in 0.05551 seconds
