Home » Modeling » GMF (Graphical Modeling Framework) » Properties view add buttons
Properties view add buttons [message #199829] Fri, 01 August 2008 08:34 Go to next message
Originally posted by: sk_stani.gbg.bg
Hallo,
Is there any way to put buttons instead of cells in the properties view
and of course get notification for pressing them.
Best Regards,
Stanislav
Re: Properties view add buttons [message #199879 is a reply to message #199829] Fri, 01 August 2008 09:19 Go to previous messageGo to next message
Stanislav,
Have a look at
http://wiki.eclipse.org/EMF/Recipes#Recipe:_Create_your_own_ property_editor_in_a_generated_application
and also at DialogCellEditor.
Stanislav wrote:
> Hallo,
> view and of course get notification for pressing them.
> Best Regards,
> Stanislav
Re: Properties view add buttons [message #199887 is a reply to message #199879] Fri, 01 August 2008 10:01 Go to previous messageGo to next message
It looks as nice solution but unfortunately my diagram never even execute
the editor code generated by the .genmodel. How can I force it to work?
Re: Properties view add buttons [message #199901 is a reply to message #199887] Fri, 01 August 2008 10:25 Go to previous messageGo to next message
--------------040707030704030709080802
Stanislav,
In the editor you have, find where it creates the properties view and
apply this same solution there. It's created like this in the base
class of the generated GMF editor so I imagine you'll need to override
that. I've not looked closely at the details...
/* (non-Javadoc)
* @see
org.eclipse.core.runtime.IAdaptable#getAdapter(java.lang.Cla ss)
public Object getAdapter(Class type) {
if (type == IPropertySheetPage.class) {
return new PropertiesBrowserPage(this);
return super.getAdapter(type);
> execute the editor code generated by the .genmodel. How can I force it
> to work?
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Stanislav,<br>
<br>
Re: Properties view add buttons [message #199910 is a reply to message #199901] Fri, 01 August 2008 11:24 Go to previous messageGo to next message
Thanks Ed
i found where the view is created so i only have to implement the solution.
Re: Properties view add buttons [message #200097 is a reply to message #199910] Mon, 04 August 2008 08:42 Go to previous messageGo to next message
As i said i founded where the properties view is created but i just can't
get my properties to show in a customed way. every thing is fine before
the method setPropertySourceProvider which in my opinion doesn't even
executes. I don't get any exception but the properties view is blank. Can
you please help me.
Re: Properties view add buttons [message #200105 is a reply to message #200097] Mon, 04 August 2008 08:52 Go to previous messageGo to next message
Stanislav,
My psychic debugging skills have limits. The debugger is your best
friend. You've looked in the Error Log view? You've set breakpoints on
your property source provider's method to see what's being called. If
you set breakpoints in the default one that works, you can see what code
paths get you there and hence can look at how those function when you
inject your alternative.
Stanislav wrote:
> can't get my properties to show in a customed way. every thing is fine
> before the method setPropertySourceProvider which in my opinion
> doesn't even executes. I don't get any exception but the properties
> view is blank. Can you please help me.
Re: Properties view add buttons [message #200142 is a reply to message #200105] Mon, 04 August 2008 10:09 Go to previous messageGo to next message
propertySheetPage.setPropertySourceProvider
(new AdapterFactoryContentProvider(adapterFactory)
protected IPropertySource createPropertySource(Object object,
IItemPropertySource itemPropertySource)
return
new PropertySource(object, itemPropertySource)
protected IPropertyDescriptor
createPropertyDescriptor(IItemPropertyDescriptor itemPropertyDescriptor)
return
new PropertyDescriptor(object, itemPropertyDescriptor)
public CellEditor createPropertyEditor(Composite
composite)
// Test for your case based on the feature or the
type of the feature.
// See the super method for details.
Object feature =
temPropertyDescriptor.getFeature(this.object);
return super.createPropertyEditor(composite);
Sorry for wasting your time but i really got stuck. In this code where and
how should i call the overridden methods. Because as my inspections showed
that they are never called?
Re: Properties view add buttons [message #200165 is a reply to message #200142] Mon, 04 August 2008 11:33 Go to previous messageGo to next message
Stanislav,
Did you override getAdatper? Where is this "set" being called?
> @Override
> object, IItemPropertySource itemPropertySource)
> return new PropertySource(object,
> itemPropertySource)
> @Override
> return new
> @Override
> composite)
> the type of the feature.
> Object feature =
> and how should i call the overridden methods. Because as my
> inspections showed that they are never called?
Re: Properties view add buttons [message #200171 is a reply to message #200165] Mon, 04 August 2008 11:38 Go to previous messageGo to next message
Yes in the main edir class of *.diagram.part. and this is the overridden
getAdapter
if (type.equals(IPropertySheetPage.class)) {
MindmapEditor editor = new MindmapEditor();
return editor.getPropertySheetPage();
} else
and the set method i called inside getPropertySheetPage();
Re: Properties view add buttons [message #200185 is a reply to message #200171] Mon, 04 August 2008 12:00 Go to previous messageGo to next message
Stanislav,
Comments below.
> overridden getAdapter
> @Override
This looks like bad news. You need to create a new property sheet page
here, not create some editor and then try to reuse that other editor's
property sheet page for this editor. Copy the code that's in your base
class and try change how the new PropertiesBrowserPage(this) is
initialized. I can't help you with that because I don't know how these
tabbed properties views work. So I'll just stop answering your
questions and assume that someone with GMF knowledge will help.
> } else
Re: Properties view add buttons [message #200209 is a reply to message #200185] Mon, 04 August 2008 13:24 Go to previous messageGo to next message
Thank you a lot for your help.
And if anyone else knows something about my problem?
Re: Properties view add buttons [message #200294 is a reply to message #200185] Tue, 05 August 2008 03:03 Go to previous message
I think I solved the case. There is class *PropertySection where we have
if (af != null) {
IItemPropertySource ips = (IItemPropertySource) af.adapt(object,
IItemPropertySource.class);
if (ips != null) {
return new PropertySource(object, ips);
just change of return new PropertySource(object, ips); with
return new CustomizedPropertySource(object, ips);
and then you can try the second part of the article
http://eclipser-blog.blogspot.com/2007/10/custom-property-so urce-for-emf.html
Previous Topic:element drawn in the compartment and outside compartment
Next Topic:implementing ILayoutNodeProvider - best practices
Current Time: Sat Jul 26 07:46:57 EDT 2025
Powered by FUDForum. Page generated in 0.08176 seconds
