Home » Eclipse Projects » GEF » F3 Action
F3 Action [message #200068] Thu, 20 October 2005 12:20 Go to next message
Originally posted by: ingo.koch[nospam].sap.com
I want to implement a "Navigate into" - like functionality in my editor,
which means, if you press F3, you can navigate into the selected editpart
(opens another editor).
But
sharedKeyHandler.put(KeyStroke.getPressed(SWT.F3,0),
getActionRegistry().getAction(NavigateIntoAction.ID));
doesn
Re: F3 Action [message #200156 is a reply to message #200068] Thu, 20 October 2005 17:04 Go to previous messageGo to next message
Did you register your KeyHandler in
GraphicalEditor#configureGraphicalViewer()?
I have something like
viewer.setKeyHandler( new GraphicalViewerKeyHandler(
viewer ).setParent( sharedKeyHandler ) );
"Ingo Koch" <ingo.koch[nospam]@sap.com> wrote in message
news:dj8g4t$87i$1@news.eclipse.org...
> But
> doesn
Re: F3 Action [message #200214 is a reply to message #200068] Thu, 20 October 2005 23:23 Go to previous messageGo to next message
FYI, F3 is defined as open selection (in another editor). Navigate->Go Into
has no assigned default keybinding.
But, to find out if the workbench is stealing the key, you could reassign
the Open Selection keybinding to anything else and see if that helps. You
could also print out the KeyEvent to see if it is what you expected. You may
be registering the wrong keystroke.
> But
> doesn
Re: F3 Action [message #200258 is a reply to message #200156] Fri, 21 October 2005 04:10 Go to previous messageGo to next message
Yes, I did, otherwise, any key would not work.
"Felix L J Mayer" <felix.mayer@objectaid.com> wrote in message
news:dj90ph$vj4$1@news.eclipse.org...
> > Hi,
editpart
> > But
> > doesn
Re: F3 Action resolved [message #200273 is a reply to message #200214] Fri, 21 October 2005 05:30 Go to previous messageGo to next message
Ok, two lines of code did the trick:
1. navigationAction.setAccelerator(SWT.F3);
2. getEditorSite().getActionBars().
setGlobalActionHandler("org.eclipse.jdt.ui.actions.Open",
getActionRegistry().getAction(NavigationAction.ID));
While testing, I couldn
Re: F3 Action resolved [message #200360 is a reply to message #200273] Fri, 21 October 2005 15:32 Go to previous messageGo to next message
news:djacg6$gse$1@news.eclipse.org...
Re: F3 Action resolved [message #200480 is a reply to message #200360] Mon, 24 October 2005 13:35 Go to previous messageGo to next message
Now I have the same problem, did you ever find out a 'proper' solution?
And where did you find the String "org.eclipse.jdt.ui.actions.Open"? It
works for me too, but I cannot get it to open a type hierarchy with F4.
Or to be more precise, my F3 and F4 work just fine in the Run-time
Workbench, but not in the IDE proper.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:djbfo0$1s7$1@news.eclipse.org...
Re: F3 Action resolved [message #200517 is a reply to message #200480] Tue, 25 October 2005 04:56 Go to previous messageGo to next message
news:djj61t$1s8$1@news.eclipse.org...
Well, I don
Re: F3 Action resolved [message #200565 is a reply to message #200517] Tue, 25 October 2005 10:03 Go to previous messageGo to next message
Thanks, now I got it to work. It looks to like you did the right thing
(except maybe for not using the constant in JdtActionConstants ;).
news:djkrvp$8ul$1@news.eclipse.org...
> Well, I don
Re: F3 Action resolved [message #200607 is a reply to message #200565] Tue, 25 October 2005 12:59 Go to previous messageGo to next message
That's not the only problem. For example, you should not be setting the
accelerator explicitly. Instead, set the Command ID and let the workbench
set the appropriate accelerator, which may have been changed by the user.
news:djldvc$571$1@news.eclipse.org...
Re: F3 Action resolved [message #203213 is a reply to message #200607] Sat, 19 November 2005 21:30 Go to previous message
I am setting the commandId/definitionId now, but I still need to set the
accelerator in the KeyHandler in order for things to work. Is this supposed
to work automatically or should I get the accelerator from the action and
put the appropriate KeyStroke with the action into the KeyHandler? In the
latter case, is there a simple way to convert the accelerator into a
KeyStroke?
news:djlo8l$ll2$1@news.eclipse.org...
Previous Topic:how to create a connection?
Next Topic:Getting previews of editor contents
Current Time: Sun Jun 01 07:34:15 EDT 2025
Powered by FUDForum. Page generated in 0.04635 seconds
