Create aspects with .aj extension [message #19718] |
Tue, 29 April 2003 13:47  |
Originally posted by: rsteele.etracksolutions.com
I just started looking into AspectJ and AJDT, so pardon me if this is a
silly question, but how can I create an aspect in Eclipse that has an *.aj
extension instead of a *.java extension?
Rich
Re: Create aspects with .aj extension [message #21064 is a reply to message #20004] |
Mon, 12 May 2003 13:11  |
Adrian Colyer wrote:
> This is a feature we hope to support via preference setting that will
> control what file extension the AspectJ Wizard uses when it creates
> aspects.
I saw this is already an open issue after I made the post.
> Unfortunately that ability has proven surprisingly difficult to
> implement
Isn't it funny the world sometimes works that way? :-)
> and we had to drop the feature temporarily from the last release.
Bummer.
> The only way to get a ".aj" extension right now is to create the aspect as
> normal (".java" extension) and then go into the resources view, where
> refactor->rename gives you the opportunity to change the file extension
> (whereas the same action from the package explorer does not).
Yep, I did discover that. It's a pain, but it does seem to work.
There's another way I might solve this: put all of our aspects into a
package with "aspect" in it. Another might be to just allow AspectJ code
and Java code intermingle; however, keeping the two separate for as long
as possible was one of our "risk mitigation" strategies...
Thanks again!
Rich
Re: Create aspects with .aj extension [message #566201 is a reply to message #19718] |
Thu, 08 May 2003 11:29  |
On Tue, 29 Apr 2003 17:47:29 +0000 (UTC), Richard A. Steele
> *.aj
aspects. Unfortunately that ability has proven surprisingly difficult to
implement and we had to drop the feature temporarily from the last release.
-- Adrian
Re: Create aspects with .aj extension [message #566484 is a reply to message #20004] |
> aspects.
> implement
Bummer.
Thanks again!
Rich
FUDForum. Page generated in 1.06017 seconds
