Home » Archived » BIRT » computed column has errors in preview
| computed column has errors in preview [message #198772] |
Thu, 02 November 2006 14:49  |
Originally posted by: ndesai.applocation.net
I have a computed column called minutes. When I run the "preview results"
it all works perfectly. However, when I run the full preview of the
report, all of a sudden I get an error saying: The data type of computed
column "minutes" is java.lang.Integer, but one of its value is "null",
which cannot be converted to java.lang.Integer.
Anyone know how I can fix this?
Neesha
| Re: computed column has errors in preview [message #199107 is a reply to message #199083] |
Fri, 03 November 2006 16:35   |
Here's my computed column code:
if (row["details"].equalsIgnoreCase("STOP")) {
params["StopTime"] = row["reporttime"];
currentIsStart = false;
} else {
params["StartTime"] = row["reporttime"];
currentIsStart = true;
MinutesStopped = DateTimeSpan.seconds(params["StopTime"],
params["StartTime"]);
params["StartTime"] = "01/01/2006 00:00:00 AM";
MinutesStopped
And this is the code used to display it in the report:
<VALUE-OF>if (row["Minutes"] > 60) {
hours = Math.floor(row["Minutes"] / 60);
mins = row["Minutes"] % 60;
result = hours + " minutes " + mins + " seconds";
} else {
result = row["Minutes"] + " seconds";
result</VALUE-OF>
(Yeah, I know it looks funny, but it was originaly hours and minutes, and
then got changed to mins and seconds and I haven't gone through and
changed the variable names. :))
Neesha
Jason Weathersby wrote:
> Can you post the expression?
> This is happening most likely becuase one of the fields is returning null.
> You may want to put in your expression
> if(row["mycol"]){
> buildcomputed
> }else{
> 0;
> "Neesha" <ndesai@applocation.net> wrote in message
> news:6c41140eba441a69cca4c43dd5d934f2$1@www.eclipse.org...
>> Hi,
>> Neesha
| Re: computed column has errors in preview [message #199301 is a reply to message #199107] |
Mon, 06 November 2006 11:59   |
You can do a check before you use the row values like
if ( row["details"] ){
This should remove the nulls.
Jason
news:5cda25f925be7831cf98a1df765c3c79$1@www.eclipse.org...
> } else {
> MinutesStopped
> } else {
> result</VALUE-OF>
> Neesha
>> null.
>> if(row["mycol"]){
>> buildcomputed
>> }else{
>> 0;
>>> Hi,
>>> results" it all works perfectly. However, when I run the full preview of
>>> the report, all of a sudden I get an error saying: The data type of
>>> computed column "minutes" is java.lang.Integer, but one of its value is
>>> "null", which cannot be converted to java.lang.Integer.
>>> Neesha
| Re: computed column has errors in preview [message #199426 is a reply to message #199301] |
Mon, 06 November 2006 14:56   |
So I changed my code to the following, and I still get the same problem
when I try to preview the report.
if (row["details"] != null) {
} else {
} else {
MinutesStopped = -2;
MinutesStopped
Neesha
> Jason
>> } else {
>> MinutesStopped
>> } else {
>> result</VALUE-OF>
>> Neesha
>>> null.
>>> if(row["mycol"]){
>>> buildcomputed
>>> }else{
>>> 0;
>>>> Hi,
>>>> Neesha
| Re: computed column has errors in preview [message #199516 is a reply to message #199426] |
Mon, 06 November 2006 19:53   |
Can you try
if (row["details"] ){
Also I would imagine the error is in something like
row["reporttime"];
So you may want to check it as well.
Jason
news:636df9d1ef9fbbd3832d9ac4cf037cff$1@www.eclipse.org...
> } else {
> } else {
> MinutesStopped
> Neesha
>> Jason
>>> } else {
>>> MinutesStopped
>>> } else {
>>> result</VALUE-OF>
>>> and then got changed to mins and seconds and I haven't gone through and
>>> Neesha
>>>> null.
>>>> if(row["mycol"]){
>>>> buildcomputed
>>>> }else{
>>>> 0;
>>>>> Hi,
>>>>> of the report, all of a sudden I get an error saying: The data type of
>>>>> is "null", which cannot be converted to java.lang.Integer.
>>>>> Neesha
| Re: computed column has errors in preview [message #199715 is a reply to message #199516] |
Tue, 07 November 2006 12:44   |
So I changed it to if (row["details"]) and it still didn't work. So then I
added in if (row["reporttime"]) and it still doesn't work. :(
Here's what my code looks like now.
if (row["details"]) {
if (row["reporttime"]) {
} else {
} else {
MinutesStopped = -3;
} else {
MinutesStopped
> Can you try
> row["reporttime"];
> Jason
>> } else {
>> } else {
>> MinutesStopped
>> Neesha
>>> Jason
>>>> } else {
>>>> MinutesStopped
>>>> } else {
>>>> result</VALUE-OF>
>>>> Neesha
>>>>> null.
>>>>> if(row["mycol"]){
>>>>> buildcomputed
>>>>> }else{
>>>>> 0;
>>>>>> Hi,
>>>>>> Neesha
| Re: computed column has errors in preview [message #199738 is a reply to message #199715] |
Tue, 07 November 2006 13:54   |
Remember that an expression returns a value and it is always the last
statement you run, so
make sure the last statement has a value. It looks like you are using
MinutesStopped. Can you initialize that to 1?
Can you post your report?
Jason
news:184b5a5d1d05d5d52ca8808d2cc1851b$1@www.eclipse.org...
> } else {
> } else {
> } else {
> MinutesStopped
>> Can you try
>> row["reporttime"];
>> Jason
>>> } else {
>>> } else {
>>> MinutesStopped
>>> Neesha
>>>> Jason
>>>>> } else {
>>>>> MinutesStopped
>>>>> } else {
>>>>> result</VALUE-OF>
>>>>> and changed the variable names. :))
>>>>> Neesha
>>>>>> null.
>>>>>> if(row["mycol"]){
>>>>>> buildcomputed
>>>>>> }else{
>>>>>> 0;
>>>>>>> Hi,
>>>>>>> preview of the report, all of a sudden I get an error saying: The
>>>>>>> data type of computed column "minutes" is java.lang.Integer, but one
>>>>>>> of its value is "null", which cannot be converted to
>>>>>>> java.lang.Integer.
>>>>>>> Neesha
| Re: computed column has errors in preview [message #199762 is a reply to message #199738] |
Tue, 07 November 2006 17:51   |
So I looked at it some more, and fiddled around and it still doesn't work.
I changed the expression I was using as I came up with a way better one
(easier to follow and actually works more in the way the last one was
intended to work).
Here it is:
MinutesStopped = -1;
if (row["details"] && row["reporttime"]) {
if (params["LastWasStop"] && row["details"].equalsIgnoreCase("START")) {
row["reporttime"]);
params["LastWasStop"] = false;
} else if (row["details"].equalsIgnoreCase("START")) {
} else {
params["LastWasStop"] = true;
MinutesStopped
I can't post the report, but I could email it to you if you could tell me
your email address.
Neesha
> Jason
>> } else {
>> } else {
>> } else {
>> MinutesStopped
>>> Can you try
>>> row["reporttime"];
>>> Jason
>>>> } else {
>>>> } else {
>>>> MinutesStopped
>>>> Neesha
>>>>> Jason
>>>>>> } else {
>>>>>> MinutesStopped
>>>>>> } else {
>>>>>> result</VALUE-OF>
>>>>>> Neesha
>>>>>>> null.
>>>>>>> if(row["mycol"]){
>>>>>>> buildcomputed
>>>>>>> }else{
>>>>>>> 0;
>>>>>>>> Hi,
>>>>>>>> java.lang.Integer.
>>>>>>>> Neesha
| Re: computed column has errors in preview [message #199817 is a reply to message #199762] |
Wed, 08 November 2006 06:22   |
Neesha,
This is a bug. Please see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=163786.
Mingxia
news:a2381f68e81261568f4bafde11b79b9b$1@www.eclipse.org...
> intended to work).
> Here it is: MinutesStopped = -1;
> row["reporttime"]);
> } else { params["LastWasStop"] = true;
> MinutesStopped
> your email address.
> Neesha
>> Jason
>>> I added in if (row["reporttime"]) and it still doesn't work. :(
>>> } else {
>>> } else {
>>> } else {
>>> MinutesStopped
>>>> Can you try
>>>> row["reporttime"];
>>>> Jason
>>>>> problem when I try to preview the report.
>>>>> } else {
>>>>> } else {
>>>>> MinutesStopped
>>>>> Neesha
>>>>>> Jason
>>>>>>> } else {
>>>>>>> MinutesStopped
>>>>>>> } else {
>>>>>>> result</VALUE-OF>
>>>>>>> minutes, and then got changed to mins and seconds and I haven't gone
>>>>>>> through and changed the variable names. :))
>>>>>>> Neesha
>>>>>>>> returning null.
>>>>>>>> if(row["mycol"]){
>>>>>>>> buildcomputed
>>>>>>>> }else{
>>>>>>>> 0;
>>>>>>>>> Hi,
>>>>>>>>> one of its value is "null", which cannot be converted to
>>>>>>>>> java.lang.Integer.
>>>>>>>>> Neesha
| Re: computed column has errors in preview [message #199897 is a reply to message #199817] |
Wed, 08 November 2006 17:25  |
Hmm... I don't suppose there's anyway around this bug? Certain types of
things I need to leave out of the expression so it would work?
Neesha
mwu wrote:
> Neesha,
> Thanks
> Mingxia
>> Hi,
>> intended to work).
>> row["reporttime"]);
>> MinutesStopped
>> your email address.
>> Neesha
>>> Jason
>>>> } else {
>>>> } else {
>>>> } else {
>>>> MinutesStopped
>>>>> Can you try
>>>>> row["reporttime"];
>>>>> Jason
>>>>>> } else {
>>>>>> } else {
>>>>>> MinutesStopped
>>>>>> Neesha
>>>>>>> Jason
>>>>>>>> } else {
>>>>>>>> MinutesStopped
>>>>>>>> } else {
>>>>>>>> result</VALUE-OF>
>>>>>>>> Neesha
>>>>>>>>> returning null.
>>>>>>>>> if(row["mycol"]){
>>>>>>>>> buildcomputed
>>>>>>>>> }else{
>>>>>>>>> 0;
>>>>>>>>>> Hi,
>>>>>>>>>> java.lang.Integer.
>>>>>>>>>> Neesha
Current Time: Wed Nov 05 01:46:05 EST 2025
Powered by FUDForum. Page generated in 0.16858 seconds
