Home » Modeling » GMF (Graphical Modeling Framework) » Remove Load Resource object contribution
Remove Load Resource object contribution [message #199674] Thu, 31 July 2008 10:10 Go to next message
Originally posted by: michael.wohlfart.proceedinnovation.com
I have changed my generated editor in a way that resources don't need to
be attached manually to the diagram's resource set (through the "Load
Resource..." action)
Now when I want to remove the action (or better, its objectContribution)
I'm running into problems, since regenerating the diagram afterwards
overwrites my prior removal of the objectContribution in the plugin.xml.
I also don't want to abandon the ability to regenerate, since subsequent
model changes could require this...
Any idea how to persistently remove this contribution from plugin xml?
Maybe it's possible to protect some of plugin.xml's contents from
regeneration?
Thanks in advance,
Michael
Re: Remove Load Resource object contribution [message #199689 is a reply to message #199674] Thu, 31 July 2008 10:28 Go to previous message
Hello Michael,
Currently - only by overriding corresponding part of templates by custom
around/custom template.
Alex Shatalin
Previous Topic:where to disable the Duplicate button on the right-click menu
Next Topic:How to get outer data in model.
Current Time: Fri Jul 18 18:59:26 EDT 2025
Powered by FUDForum. Page generated in 0.03576 seconds
