Home » Modeling » GMF (Graphical Modeling Framework) » where to disable the Duplicate button on the right-click menu
where to disable the Duplicate button on the right-click menu [message #199665] Thu, 31 July 2008 09:48 Go to next message
Hi Everyone,
I would like to disable or customize the duplicate button on the
right-click menu. Does anybody know how to do this or know where to locate
the class that is responsible for this 'duplicate' action? Please help me!
Toyin
Re: where to disable the Duplicate button on the right-click menu [message #199681 is a reply to message #199665] Thu, 31 July 2008 10:16 Go to previous message
Originally posted by: michael.wohlfart.proceedinnovation.com
Hello!
the duplicate action is contributed to the ContextMenu through the
" org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProvider "
extension point in the gmf plugin
"org.eclipse.gmf.runtime.diagram.ui.providers"
The according implementation of the ContributionItemProvider is done by
the class
" org.eclipse.gmf.runtime.diagram.ui.providers.DiagramContribu tionItemProvider ",
The ContextMenuProvider is
" org.eclipse.gmf.runtime.diagram.ui.providers.DiagramContextM enuProvider "
both in the "org.eclipse.gmf.runtime.diagram.ui.providers".
I found this out by importing the gmf plugins as source projects into my
workspace. This is very helpful when you don't know some ids or
implementing classes, since you can debug into this code then.. (just a
tip ;-)
Greetings,
Michael
Toyin Johnson Fakorede schrieb:
> Hi Everyone,
> locate the class that is responsible for this 'duplicate' action? Please
> help me!
> Thanks
> Toyin
Previous Topic:Property Tab: Enable change value
Next Topic:Remove Load Resource object contribution
Current Time: Fri Jul 25 21:31:38 EDT 2025
Powered by FUDForum. Page generated in 0.27812 seconds
