Home » Modeling » GMF (Graphical Modeling Framework) » GMF Diagram-EMF Model Sync problem
GMF Diagram-EMF Model Sync problem [message #199473] Tue, 29 July 2008 23:04 Go to next message
Originally posted by: s.gil.gmx.com
Im currently having a sync problem between the GMF diagram and the EMF
Model, in my application.
The situation is as the following:
In my application, when I change a property on one of my nodes in the GMF
diagram I need to make an Elist, non modifiable.
So when i do that, the diagram keeps "seeing" the list as modifiable, while
the EMF model doesnt allow to modify the list.
I assume it is a SYNC problem, because when i close and open the GMF diagram
again, the list behaves as it should, as an unmodifiable list.
the following is the code used to turn the list as non-modifiable:
In the example the List is called: "this.iports".
this.iports = new EcoreEList.UnmodifiableEList<IPort>(this,
InTmlDevToolsV02Package.eINSTANCE.getFilter_Iports(),
newIPorts.size(), newIPorts.toArray());
eNotify(new ENotificationImpl(this, Notification.SET,
InTmlDevToolsV02Package.FILTER__FILTER_CLASS, oldFilterClass, filterClass));
InTmlDevToolsV02Package.FILTER__IPORTS, oldIports, this.iports));
(i have tryied a lot of posible notifications, but with no effect).
I assume the problem is that the GMF diagram does NOT sees the EMF propertiy
chage (make the list non-modifiable).
Anyone has an idea what might be my problem here? any clues to solve it?
Or anyone know how to "REFRESH" the whole GMF diagram programatically?
thanks in advance.
-Santiago Gil
Re: GMF Diagram-EMF Model Sync problem [message #199532 is a reply to message #199473] Wed, 30 July 2008 08:52 Go to previous messageGo to next message
There is no natural sync between the EMF model and the GMF mapping file.
I use a transformation process in ATL to generate the mapping from the
EMF model.
see http://opensource.urszeidler.de/ATLflow/html1/samples/genera teGMF.html
I think there are one or more projects addressing this also.
greetings, urs.
Re: GMF Diagram-EMF Model Sync problem [message #199720 is a reply to message #199532] Thu, 31 July 2008 23:13 Go to previous message
thnask urs,
i ll check and i ll let you iknow. I was planning on using
OpenArchitectureWare for code generation, is ATLSync similar to OAW, in some
ways?
cheers.
"urs zeidler" <ich@urszeidler.de> wrote in message
news:g6po6k$cab$1@build.eclipse.org...
> I use a transformation process in ATL to generate the mapping from the EMF
> model.
> greetings, urs.
Previous Topic:remember pallete selection ?
Next Topic:A tree outline in GMF
Current Time: Sat Jul 26 07:44:36 EDT 2025
Powered by FUDForum. Page generated in 0.24127 seconds
