Home » Modeling » TMF (Xtext) » Re: [xtext] Error in the generated PartitionScanner
Re: [xtext] Error in the generated PartitionScanner [message #19952] Fri, 08 August 2008 12:47 Go to next message
--------------030806020307050809080108
Sven Efftinge wrote:
> Hi Lorenzo,
> it would be best if you could provide a patch and file it in bugzilla,
> so that the issue is fixed for everybody :-)
there seem to be problems with bugzilla, so for the moment I'm posting
the patch here
hope this helps
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Content-Type: text/x-diff;
name="scanner_with_escape_chars_for_strings.patch"
Content-Disposition: inline;
filename="scanner_with_escape_chars_for_strings.patch"
### Eclipse Workspace Patch 1.0
#P xtext.generator
Index: main/src/org/openarchitectureware/xtext/editor/Utilities.xpt
RCS file: /cvsroot/architecturware/oaw_v4/xtext/xtext.generator/main/s rc/org/openarchitectureware/xtext/editor/Utilities.xpt,v
retrieving revision 1.6.2.3.2.1
diff -u -r1.6.2.3.2.1 Utilities.xpt
--- main/src/org/openarchitectureware/xtext/editor/Utilities.xpt 31 May 2008 12:57:18 -0000 1.6.2.3.2.1
+++ main/src/org/openarchitectureware/xtext/editor/Utilities.xpt 8 Aug 2008 16:16:50 -0000
@@ -103,8 +103,8 @@
rules.add(new MultiLineRule("/*","*/", comment));
rules.add(new SingleLineRule("//", "", comment));
�ENDIF-�
- rules.add(new MultiLineRule("\"","\"", string));
- rules.add(new MultiLineRule("'","'", string));
+ rules.add(new MultiLineRule("\"","\"", string, '\\'));
+ rules.add(new MultiLineRule("'","'", string, '\\'));
return rules;
--------------030806020307050809080108--
Re: [xtext] Error in the generated PartitionScanner [message #20034 is a reply to message #19952] Fri, 08 August 2008 12:52 Go to previous messageGo to next message
>> Hi Lorenzo,
> the patch here
OK: https://bugs.eclipse.org/bugs/show_bug.cgi?id=243608
Re: [xtext] Error in the generated PartitionScanner [message #21385 is a reply to message #20034] Wed, 13 August 2008 11:23 Go to previous messageGo to next message
Originally posted by: sven.efftinge.de
This also has already been applied by Patrick.
Thank you!
>>> Hi Lorenzo,
>>> bugzilla, so that the issue is fixed for everybody :-)
>> the patch here
Re: [xtext] Error in the generated PartitionScanner [message #21402 is a reply to message #21385] Wed, 13 August 2008 12:35 Go to previous messageGo to next message
thank you for xtext :-)
> Thank you!
>>>> Hi Lorenzo,
>>> posting the patch here
Re: [xtext] Error in the generated PartitionScanner [message #21418 is a reply to message #21402] Fri, 22 August 2008 04:22 Go to previous messageGo to next message
It seems to me that the problem is that the STRING definition is
incorrect. See this thread for my explanation of why I think this:
http://www.openarchitectureware.org/forum/viewtopic.php?show topic=9640
Also, should I be posting on this newsgroup or that one?
-- Scott
Re: [xtext] Error in the generated PartitionScanner [message #21428 is a reply to message #21418] Fri, 22 August 2008 07:50 Go to previous messageGo to next message
For the currently released xtext (shipped with oAW 4.3) it's best to use
the forum over at openarchitectureware.org.
If people have questions about the new Xtext (the one currently
developed under TMF) they should aks here (eclipse.modeling.tmf).
Since there are no releases yet, there are no questions :-)
regards,
Sven
> -- Scott
Re: [xtext] Error in the generated PartitionScanner [message #21435 is a reply to message #21418] Sat, 23 August 2008 13:10 Go to previous message
As I also answered to that thread:
Actually, concerning the bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=243608, which
now should be fixed in the CVS, the strings with backslashed quotes used
to work correctly as before (the parser used to parse it correctly), it
was the highlighter that was wrong...
Previous Topic:[xText] code completion
Next Topic:support of packrat parser generator
Current Time: Sat Nov 08 06:57:32 EST 2025
Powered by FUDForum. Page generated in 0.05120 seconds
