Home » Modeling » GMF (Graphical Modeling Framework) » trying to add GMF plugin
trying to add GMF plugin [message #199228] Mon, 28 July 2008 09:02 Go to next message
Originally posted by: claude.dutreilly.imag.fr
hello,
I'm using Eclipse SDK v 3.3.1 linux, (M20070921-1145) on which I'm trying
to install the GMF plugin.
I used the "zip" method as describe on the web site (ie "unzipped" the
gmf-sdk-2.1.0, and moved the "features/" and "plugins/" files to the right
place (I mean under /eclipse/3.3/features/ and plugins/)
I re-launch "eclipse" but le GMF plugins doesn't appears in the Menu: File
-> New -> Other , as sbdy told me it should appears there (? is it true ?)
What's wrong with my Eclipse GMF plugin ?
thanks
claude
Re: trying to add GMF plugin [message #199251 is a reply to message #199228] Mon, 28 July 2008 09:15 Go to previous messageGo to next message
Did you also unzip all of GMF's dependencies into your eclipse installation
(e.g. EMF, GEF, EMF Transaction, etc.)
On 7/28/08 9:02 AM, in article
4fbf8e1e12f139b2827647b6176ac47e$1@www.eclipse.org, "claude dutreilly"
<claude.dutreilly@imag.fr> wrote:
> hello,
> thanks
> claude
Re: trying to add GMF plugin [message #199259 is a reply to message #199251] Mon, 28 July 2008 09:23 Go to previous messageGo to next message
no, I don't.Only EMFfile:emf-sdo-xsd-SDK-2.4.0
But do I need to install these dependencies according to my "old" Eclipse
? (or get all new GMF and dependencies), and if so, where can I get them ?
claude
>> hello,
>> thanks
>> claude
Re: trying to add GMF plugin [message #199266 is a reply to message #199259] Mon, 28 July 2008 09:50 Go to previous messageGo to next message
Yes, you'll need to install all dependencies. You should be using the 3.4
platform SDK if you want to use GMF 2.1 and EMF 2.4. There are links to
dependencies from the download page, or you can use the preconfigured Europa
(3.3) or Ganymede (3.4) update sites to obtain them all.
- Rich
On 7/28/08 9:23 AM, in article
3040e211aa74a0de8cfce3f1211252e5$1@www.eclipse.org, "claude dutreilly"
> claude
>>> hello,
>>> thanks
>>> claude
Re: trying to add GMF plugin [message #199274 is a reply to message #199266] Mon, 28 July 2008 10:18 Go to previous message
ok,
I'll try this.
I understand that I was doing *wrong" things mixing GMF 2.1 and EMF 2.4
with Eclipse 3.3
regards
Claude
Previous Topic:about getPrimaryDragEditPolicy()
Next Topic:Diagram configuration option
Current Time: Mon Jun 16 01:38:58 EDT 2025
Powered by FUDForum. Page generated in 0.04675 seconds
