Home » Eclipse Projects » GEF » laying out child figures in 2 columns
laying out child figures in 2 columns [message #199245] |
Fri, 14 October 2005 09:45  |
Originally posted by: christian.sell.netcologne.de
can somebody give me a hint how to lay out child figures in 2 columns,
such that the row contents are left-aligned in each columnn? Each row is
one edit part which has 2 text items. Example:
_________________________
|row1text row2text |
|moretexttext moretext |
thanks,
Christian
Re: laying out child figures in 2 columns [message #199402 is a reply to message #199326] |
Fri, 14 October 2005 11:47   |
Okay, here is your example, I just removed some code that is specific to my
stacked layout to make it more readable.
public class StackedLayout extends AbstractLayout {
* @see
org.eclipse.draw2d.AbstractLayout#calculatePreferredSize(org .eclipse.draw2d.IFigure,
int, int)
protected Dimension calculatePreferredSize( IFigure container, int wHint,
int hHint ) {
Dimension preferred = new Dimension( 0, 0 );
if( container.isVisible() ) {
for( Iterator i = container.getChildren().iterator(); i.hasNext(); ) {
IFigure child = (IFigure) i.next();
Dimension current = child.getPreferredSize();
// compute preferred here
}//for
Insets insets = container.getInsets();
preferred.expand( insets.getWidth(), insets.getHeight() );
}//if
return preferred;
}//calculatePreferredSize()
* @see
org.eclipse.draw2d.LayoutManager#getMinimumSize(org.eclipse. draw2d.IFigure,
int, int)
public Dimension getMinimumSize( IFigure container, int wHint, int hHint )
// Compute the minimum size as the preferred size of the first
// Compartment, which should be the title of the classifier.
return ((IFigure) container.getChildren().get( 0 )).getPreferredSize();
}//getMinimumSize()
* @see
org.eclipse.draw2d.AbstractLayout#layout(org.eclipse.draw2d. IFigure)
public void layout( IFigure container ) {
Rectangle clientArea = container.getClientArea();
LOG.finest( "container=" + container + " clientArea=" + clientArea );
int maxHeight = clientArea.height;
Rectangle previous = new Rectangle( clientArea.x, clientArea.y,
clientArea.width, 0 );
Rectangle bounds = // Whatever you need, previous probably helps
child.setBounds( bounds );
previous = bounds;
}//for
}//layout()
"Christian Sell" <christian.sell@netcologne.de> wrote in message
news:diofvo$e5e$1@news.eclipse.org...
> thanks, thats the answer I feared. My preference would have been "look at
> example XYZ", or "see the code sample below". Should this turn out to be a
> case of YCAGWYW (You Cant Always Get What You Want)?
> christian
> Felix L J Mayer wrote:
>> You need to write a LayoutManager for the parent figure.
>> news:diocps$98a$1@news.eclipse.org...
>>>Hello,
>>>|row1text row2text |
>>>thanks,
>>>Christian
Re: laying out child figures in 2 columns [message #199425 is a reply to message #199402] |
Fri, 14 October 2005 12:38  |
thanks, I'll check this out.
chris
> * @see
> int, int)
> int hHint ) {
> }//for
> }//if
> return preferred;
> * @see
> int, int)
> }//getMinimumSize()
> * @see
> previous = bounds;
> }//for
> }//layout()
>>christian
>>>>Hello,
>>>>|row1text row2text |
>>>>thanks,
>>>>Christian
Current Time: Wed Jul 30 21:47:06 EDT 2025
Powered by FUDForum. Page generated in 1.28407 seconds
