Home » Archived » BIRT » Generating Charts in JBOSS Portlets
Generating Charts in JBOSS Portlets [message #199150] Sat, 04 November 2006 07:58 Go to next message
Originally posted by: mike.harper.atkinsglobal.com
Hi all, I am trying to run reports within a JBOSS Portal. Straight html
reports are fine but I have problems with Charts. The behaviour is as
follows.
First JBoss reports and error.
2006-11-04 12:44:19,024 INFO [org.jboss.system.server.Server] JBoss (MX
MicroKernel) [4.0.3SP1 (build: CVSTag=JBoss_4_0_3_SP1 date=200510231054)]
Started in 1m:21s:33ms
2006-11-04 12:44:58,718 INFO [STDOUT] [warn] Could not find class
org.eclipse.core.internal.runtime.auth.AuthorizationHandler that
org.eclipse.core.internal.runtime.InternalPlatform references. It may not
be in your classpath and you may not be getting field and constructor
weaving for this class.
2006-11-04 12:45:00,135 INFO [STDOUT] [warn] Could not find class
org.eclipse.core.runtime.Platform references. It may not be in your
classpath and you may not be getting field and constructor weaving for
this class.
2006-11-04 12:45:07,739 INFO [STDOUT] [warn] AOP Instrumentor failed to
transform org.eclipse.emf.ecore.impl.EPackageRegistryImpl
2006-11-04 12:45:07,740 INFO [STDOUT]
org.jboss.aop.instrument.TransformationException: Failed to aspectize
class org.eclipse.emf.ecore.impl.EPackageRegistryImpl. Could not find
class it references org.eclipse.emf.ecore.plugin.EcorePlugin It may not
2006-11-04 12:45:07,742 INFO [STDOUT] at
org.jboss.aop.instrument.Instrumentor.convertReferences(Inst rumentor.java:593)
org.jboss.aop.instrument.Instrumentor.transform(Instrumentor .java:646)
org.jboss.aop.AspectManager.translate(AspectManager.java:792 )
org.jboss.aop.AspectManager.transform(AspectManager.java:704 )
org.jboss.aop.standalone.AOPTransformer.aspectTransform(AOPT ransformer.java:62)
2006-11-04 12:45:07,743 INFO [STDOUT] at
org.jboss.aop.standalone.AOPTransformer.transform(AOPTransfo rmer.java:54)
Secondly the image is generated in the bin folder of jboss - although the
has the correct path for an images folder in the jboss deploy directory.
As I have org.eclipse.emf.ecore.plugin.EcorePlugin on the classpath I
don't know where to go from here.
Please could anybody help?
Re: Generating Charts in JBOSS Portlets [message #200372 is a reply to message #199150] Sat, 11 November 2006 04:51 Go to previous message
Please could anybody help with this as it is now critcal - I've been
trying to get the charting working for a while now. If there is anymore
information I can supply I am happy to. Thanks in advance
Previous Topic:Error: Invalid expression to retrieve value in presentation
Next Topic:Birt Charts In JBoss Portal Portlets
Current Time: Sat Nov 08 14:54:32 EST 2025
Powered by FUDForum. Page generated in 0.04216 seconds
