Home » Modeling » GMF (Graphical Modeling Framework) » configure palette dynamically
Re: configure palette dynamically [message #198816 is a reply to message #198805] |
Thu, 24 July 2008 10:37   |
Originally posted by: ajaykemparaj.in.bosch.com
Hi Jacek,
In the PaletteFactory (this is generated ) class (Search for
createPaletteRoot in your DiagramEditor ) there are methods where you can
add the tool entries programatically.
I am attaching a sample snippet which may be useful for you ,
* @generated
public class SamplePaletteFactory {
private Properties properties = null;
* @generated NOT
public void fillPalette(PaletteRoot paletteRoot) {
paletteRoot.add(createConnection2CreationGroup());
private PaletteContainer createConnection2CreationGroup() {
PaletteGroup paletteContainer = new PaletteGroup("SampleTools");
paletteContainer.add(createConnection2CreationTool());
return paletteContainer;
* @generated
private ToolEntry createContainer1CreationTool() {
ToolEntry entry = new ToolEntry(
mypackage.Messages.Container1CreationTool_title,
mypackage.Messages.Container1CreationTool_desc,
null, null) {
return entry;
* @generated NOT
private ToolEntry createConnection2CreationTool() {
List/*<IElementType>*/types = new ArrayList/*<IElementType>*/(1);
types
.add(mypackage.diagram.providers.DiagramElementTypes.Connect ion_3003);
LinkToolEntry entry = new LinkToolEntry("User Connections",
"Sample Connections", types);
entry.setSmallIcon(DiagramHelper.getDiagramHelper().getImage Descriptor( "Sample.gif"));
entry.setDescription("Sample user defined connections");
entry.setLargeIcon(entry.getSmallIcon());
return entry;
* @generated
private static class NodeToolEntry extends ToolEntry {
* @generated
private final List elementTypes;
* @generated
private NodeToolEntry(String title, String description,
List elementTypes) {
super(title, description, null, null);
this.elementTypes = elementTypes;
* @generated
public Tool createTool() {
Tool tool = new UnspecifiedTypeCreationTool(elementTypes);
tool.setProperties(getToolProperties());
return tool;
* @generated
private static class LinkToolEntry extends ToolEntry {
* @generated
private final List relationshipTypes;
* @generated
private LinkToolEntry(String title, String description,
List relationshipTypes) {
this.relationshipTypes = relationshipTypes;
* @generated
Tool tool = new UnspecifiedTypeConnectionTool(relationshipTypes);
return tool;
Ajay K
Jacek Pospychala wrote:
> I have read following article about configuring GMF palette:
http://help.eclipse.org/stable/index.jsp?topic=/org.eclipse. gmf.doc/tutorials/diagram/paletteConfigurationTutorial.html
> But is there a way to add/remove palette elements programatically,
> instead of static definition in plugin.xml (as described in above doc)?
> thanks
> Jacek
Re: configure palette dynamically [message #198992 is a reply to message #198816] |
Fri, 25 July 2008 09:35  |
Originally posted by: jacek.pospychala.pl.ibm.com
Ajay, thanks for your help.
I actually meant to add tools from external plugins to an already
existing editor, which code I can't change.
Ajay pisze:
> Hi Jacek,
> can add the tool entries programatically.
> * @generated
> * @generated NOT
> * @generated
> null, null) {
> return entry;
> * @generated NOT
> types
> return entry;
> * @generated
> * @generated
> * @generated
> * @generated
> return tool;
> * @generated
> * @generated
> * @generated
> * @generated
> Tool tool = new
> return tool;
> Regards,
> Ajay K
>> Hi,
>> thanks
>> Jacek
Current Time: Fri Jul 25 21:38:18 EDT 2025
Powered by FUDForum. Page generated in 0.45856 seconds
