Home » Eclipse Projects » GEF » Drag & Drop in GEF
Drag & Drop in GEF [message #198560] Wed, 12 October 2005 10:17 Go to next message
I'm trying to implement D&D functionality from package explorer to my GEF
diagram. I'm following the article in :
http://www.eclipse.org/articles/Article-GEF-dnd/GEF-dnd.html and somehow I'm
getting following exception when I'm dragging a file from package explorer
to the diagram:
at org.eclipse.swt.dnd.DropTarget.setEventData(DropTarget.java: 628)
at org.eclipse.swt.dnd.DropTarget.DragEnter(DropTarget.java:253 )
at org.eclipse.swt.dnd.DropTarget.access$4(DropTarget.java:247)
at org.eclipse.swt.dnd.DropTarget$3.method3(DropTarget.java:233 )
at
org.eclipse.swt.internal.ole.win32.COMObject.callback3(COMOb ject.java:90)
at org.eclipse.swt.internal.ole.win32.COM.DoDragDrop(Native Method)
at org.eclipse.swt.dnd.DragSource.drag(DragSource.java:277)
at org.eclipse.swt.dnd.DragSource.access$0(DragSource.java:267)
at org.eclipse.swt.dnd.DragSource$1.handleEvent(DragSource.java :161)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
This exception comes immeaditely when the mouse enters the diagram area.
What is going wrong?
Best Regards,
- Sami
Re: Drag & Drop in GEF [message #198946 is a reply to message #198560] Thu, 13 October 2005 10:16 Go to previous messageGo to next message
The following code in the article :
getGraphicalViewer().addDropTargetListener(
new FileTransferDropTargetListener(getGraphicalViewer()));should be
replaced with:
new
FileTransferDropTargetListener(getGraphicalViewer(),FileTran sfer.getInstance()));
"Sami Lakka" <sami.lakka@tut.fi> kirjoitti
viestiss
Re: Drag & Drop in GEF [message #198962 is a reply to message #198946] Thu, 13 October 2005 11:57 Go to previous messageGo to next message
Originally posted by: none.unknown.com
Please open a bug report.
"Sami Lakka" <sami.lakka@tut.fi> wrote in message
news:dilq8i$4qi$1@news.eclipse.org...
> replaced with:
> new
> viestiss
Re: Drag & Drop in GEF [message #198979 is a reply to message #198962] Thu, 13 October 2005 12:20 Go to previous messageGo to next message
Originally posted by: greg.gigon.tugulu.com
Article that describes D&D functionality is using methods that are
deprecated. How should it be done to be done properly?
Or there is no other way of doing this just the one described in article?
Cheers, Greg
>>replaced with:
>> new
>>viestissä:dij5tn$rnk$1@news.eclipse.org...
>>>Hello,
> GEF
Re: Drag & Drop in GEF [message #199037 is a reply to message #198979] Thu, 13 October 2005 13:21 Go to previous message
The javadoc of the deprecated methods mentions which methods should be used
instead. They have the same name.
"Greg" <greg.gigon@tugulu.com> wrote in message
news:dim1g3$fej$1@news.eclipse.org...
> Cheers, Greg
be
> >>replaced with:
> >> new
> >>viestiss
Previous Topic:Custom view and ... ??
Next Topic:Crash with empty Labels on Linux
Current Time: Mon Jun 16 17:37:42 EDT 2025
Powered by FUDForum. Page generated in 0.32136 seconds
