Home » Language IDEs » ServerTools (WTP) » Tomcal server.xml out of sync - any way to refresh ?
Tomcal server.xml out of sync - any way to refresh ? [message #198765] Wed, 22 August 2007 12:25 Go to next message
Originally posted by: hypertree.yahoo.com
Hi Folks !
I am trying to import a webapp into Eclipse/WTP and since this app doesn't
use servlet mapping I have to use much maligned "invoker" servlet which
requires privileged="true" flag to be set in its context. Since I can't
set this property in Tomcat Modules editor, I edited server.xml in my
/Servers/..Tomcatserver.. folder. problem is that Eclipse now complains
that server.xml is out of sync with no aparant way to reload refresh it.
I have tried:
project - clean and refresh and build
Tomcat installation with clean build and publishing. But no help - the
error doesn't go away. How do you force Eclipse to reload hand-edited
server.xml or any such conf/*.xml file ?
thanks,
-Sanjay
Re: Tomcal server.xml out of sync - any way to refresh ? [message #198796 is a reply to message #198765] Wed, 22 August 2007 16:31 Go to previous messageGo to next message
Try right-clicking on the server.xml or a parent folder in a "navigator
type" view (i.e. Project Explorer, Package Explorer, Navigator view) and
select Refresh.
Larry
Sanjay Kumar wrote:
> Hi Folks !
> doesn't use servlet mapping I have to use much maligned "invoker"
> servlet which requires privileged="true" flag to be set in its context.
> Since I can't set this property in Tomcat Modules editor, I edited
> server.xml in my /Servers/..Tomcatserver.. folder. problem is that
> Eclipse now complains that server.xml is out of sync with no aparant way
> I have tried:
> thanks,
> -Sanjay
Re: Tomcal server.xml out of sync - any way to refresh ? [message #198827 is a reply to message #198796] Wed, 22 August 2007 18:37 Go to previous messageGo to next message
Thanks Larry.
I don't see server.xml anywhere in those three views. Only things close is
the Tomcat Version 6.0 tree in Package explorer and it has tomcat common
jars.
I did a refresh of the project in Package Explorer. No luck so far.
I will try to setup project again tomorrow and see if Navigator or Project
Explorer refresh helps.
thanks,
-Sanjay
> select Refresh.
> Larry
Re: Tomcal server.xml out of sync - any way to refresh ? [message #198888 is a reply to message #198827] Thu, 23 August 2007 09:11 Go to previous message
See http://www.eclipse.org/webtools/faq/TomcatServerFAQ.php#info _06 for
details about the location of the server.xml in those views.
Larry
Sanjay Kumar wrote:
> Thanks Larry.
> is the Tomcat Version 6.0 tree in Package explorer and it has tomcat
> common jars.
> Project Explorer refresh helps.
> thanks,
> -Sanjay
>> "navigator type" view (i.e. Project Explorer, Package Explorer,
>> Navigator view) and select Refresh.
>> Larry
Previous Topic:working with XML and XML schemas
Next Topic:scanning for tasks
Current Time: Thu Jul 24 22:18:08 EDT 2025
Powered by FUDForum. Page generated in 0.24868 seconds
