Home » Eclipse Projects » GEF » EditPart can't receive REQ_OPEN and REQ_SELECTION request
EditPart can't receive REQ_OPEN and REQ_SELECTION request [message #198584] Wed, 12 October 2005 11:16 Go to next message
Most of you should be familiar with Shape.
I implemented public void performRequest(Request req) for
shapeTreeEditPart,
hoping to do something when some nodes in the outline treeview are selected
or double-clicked.
The code is like this: (ENV: WindowsXP, Eclipse 3.1M7, JRE1.5, RCPed
Shape-Plugin)
void performRequest(Request req){
if (REQ_SELECTION.equals(req.getType())){
doMySelection();
else if (REQ_OPEN.equals(req.getType())){
doMyOpen();
However, doMySelection() and doMyOpen() were never called when debugging,
even though I selected or double-clicked on the nodes in the outline tree.
Does someone have any idea to get the requests?
Miaohua Xu
Re: EditPart can't receive REQ_OPEN and REQ_SELECTION request [message #198620 is a reply to message #198584] Wed, 12 October 2005 11:42 Go to previous messageGo to next message
Originally posted by: greg.gigon.tugulu.com
Well, I have
installEditPolicy(EditPolicy.SELECTION_FEEDBACK_ROLE,
new CallflowSelectionEditPolicy());
in my createEditPolicies() method and I have those requests.
Try to see what is req anyway?
What type do You get?
Hope that helps, Greg
> shapeTreeEditPart,
> or double-clicked.
> Shape-Plugin)
> doMySelection();
> doMyOpen();
> Miaohua Xu
Re: EditPart can't receive REQ_OPEN and REQ_SELECTION request [message #198628 is a reply to message #198584] Wed, 12 October 2005 11:43 Go to previous messageGo to next message
Well, I have
new SelectionEditPolicy());
> shapeTreeEditPart,
> or double-clicked.
> Shape-Plugin)
> doMySelection();
> doMyOpen();
> Miaohua Xu
Re: EditPart can't receive REQ_OPEN and REQ_SELECTION request [message #198663 is a reply to message #198584] Wed, 12 October 2005 11:55 Go to previous messageGo to next message
I'm not sure if DragTrackers are used in the tree since reordering is done
using native drag-and-drop.
Are you returning the drag tracker in the tree editpart? BTW, pick one
place/thread to discuss this problem.
"vince" <fiustudent@hotmail.com> wrote in message
news:dij9da$18l$1@news.eclipse.org...
> shapeTreeEditPart,
> selected or double-clicked.
> Shape-Plugin)
> doMySelection();
> doMyOpen();
> Miaohua Xu
Re: EditPart can't receive REQ_OPEN and REQ_SELECTION request [message #199102 is a reply to message #198628] Thu, 13 October 2005 15:15 Go to previous messageGo to next message
Thank you for your reply.
I tried that and did get breakpoint in SelectionEditPolicy.showSelection()
if a node was selected. But still can't to handle double-click because still
no REQ_OPEN and REQ_SELECTION found in performRequest(Request req).
Actually I didn't find any request. But I don't think it's because
EditPolicies were not installed. In another view of my program, there is no
editpolicy handling REQ_OPEN, either, but I got REQ_OPEN in that editpart's
performRequest(). Is it because the outline TreeViewer has handled many
requests so that it doesn't dispatch them?
Miaohua Xu
"Greg" <greg.gigon@tugulu.com> wrote in message
news:dijav6$3hu$1@news.eclipse.org...
> Well, I have
>> shapeTreeEditPart,
>> Shape-Plugin)
>> doMySelection();
>> doMyOpen();
>> tree. Does someone have any idea to get the requests?
>> Thanks,
>> Miaohua Xu
Re: EditPart can't receive REQ_OPEN and REQ_SELECTION request [message #199110 is a reply to message #198663] Thu, 13 October 2005 15:19 Go to previous messageGo to next message
Thank you for your reply!
I am guessing the outline TreeViewer has handled such request so that it
doesn't dispatch them. Could you please point out a direction for me? Say,
shall I look into the source code of treeViewer? or something else?
Additional, what do you mean by saying "pick one place/thread to discuss
this problem"? I am kind of new to Eclipse.
Thanks!
Miaohua Xu
"Randy Hudson" <none@us.ibm.com> wrote in message
news:dijbkt$4i4$1@news.eclipse.org...
>> shapeTreeEditPart,
>> Shape-Plugin)
>> doMySelection();
>> doMyOpen();
>> Thanks,
>> Miaohua Xu
Re: EditPart can't receive REQ_OPEN and REQ_SELECTION request [message #199347 is a reply to message #199110] Fri, 14 October 2005 10:50 Go to previous messageGo to next message
news:dimbvr$uhk$1@news.eclipse.org...
You should be looking at the editpart's getDragTrackerMethod, and at
SelectEditPartTracker, which is the tool that sends the open request. You'll
note that AbstractTreeEditPart does return a drag tracker, so this request
never gets sent.
Please open a bug for a special drag tracker just for treeitems which only
sends these requests, but doesn't perform any selection
I am referring to the different places on this newsgroup that you are asking
about the same problem
Re: EditPart can't receive REQ_OPEN and REQ_SELECTION request [message #199882 is a reply to message #199347] Wed, 19 October 2005 17:18 Go to previous messageGo to next message
With your help, I finally figured it out it's because
AbstractTreeEditpart.getDragTracker simply return null while actually a
SelectEditPartTracker is needed.
Thank you very much!
Miaohua Xu
news:diogk5$f4p$1@news.eclipse.org...
>> Say, shall I look into the source code of treeViewer? or something else?
> You'll note that AbstractTreeEditPart does return a drag tracker, so this
> request never gets sent.
> asking about the same problem
Re: EditPart can't receive REQ_OPEN and REQ_SELECTION request [message #199906 is a reply to message #199882] Wed, 19 October 2005 17:25 Go to previous message
SelectEditPartTracker is going to select the part when it will already have
been selected by the native Tree.
news:dj6d6t$h73$1@news.eclipse.org...
Previous Topic:draw2d Newbie question
Next Topic:sticky tool selected on the palette
Current Time: Sat Jul 26 05:15:59 EDT 2025
Powered by FUDForum. Page generated in 0.08986 seconds
