Home » Eclipse Projects » GEF » Problems Opening GEF Editor: Migration from 3.1 M6 -> 3.1.1
Problems Opening GEF Editor: Migration from 3.1 M6 -> 3.1.1 [message #198593] Wed, 12 October 2005 11:25 Go to next message
We just migrated to 3.1.1 from 3.1 M6 and are having trouble opening our GEF
editor. It is a multi-page editor and the stack trace seems to point to
something in SWT. We have three other multi-page editors that do not use
GEF and they open fine in 3.1.1. I am also posting this to the SWT
newsgroup.
The problem is in the SWT class FillLayout whereby a class cast exception is
thrown since the returned object is always a GridData and not a FillData
object. This exception is thrown upon attempting to open the editor and on
the selection of any tab once the editor is opened. There are no references
to our code beyond the action that invokes open editor functionality.
class org.eclipse.swt.layout.FillLayout {
Point computeChildSize (Control control, int wHint, int hHint, boolean
flushCache) {
FillData data = (FillData)control.getLayoutData (); // LINE 141
!ENTRY org.eclipse.jface 4 2 2005-10-12 09:01:49.781
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
java.lang.ClassCastException: org.eclipse.swt.layout.GridData
at org.eclipse.swt.layout.FillLayout.computeChildSize(FillLayou t.java:141)
at org.eclipse.swt.layout.FillLayout.computeSize(FillLayout.jav a:119)
at org.eclipse.swt.widgets.Composite.computeSize(Composite.java :213)
at org.eclipse.swt.layout.GridData.computeSize(GridData.java:47 8)
at org.eclipse.swt.layout.GridLayout.layout(GridLayout.java:207 )
at org.eclipse.swt.layout.GridLayout.layout(GridLayout.java:186 )
at org.eclipse.swt.widgets.Composite.updateLayout(Composite.jav a:869)
at org.eclipse.swt.widgets.Composite.WM_SIZE(Composite.java:124 8)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3107 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3706 )
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:1651 )
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable .java:77)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3123 )
at org.eclipse.swt.internal.win32.OS.SetWindowPos(Native Method)
at org.eclipse.swt.widgets.Widget.SetWindowPos(Widget.java:1140 )
at org.eclipse.swt.widgets.Control.setBounds(Control.java:1952)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:1933)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:1929)
at org.eclipse.swt.layout.FillLayout.layout(FillLayout.java:198 )
at org.eclipse.swt.internal.win32.OS.EndDeferWindowPos(Native Method)
at org.eclipse.swt.widgets.Composite.resizeChildren(Composite.j ava:653)
at org.eclipse.swt.widgets.Composite.resizeChildren(Composite.j ava:619)
at org.eclipse.swt.widgets.Composite.setResizeChildren(Composit e.java:786)
at org.eclipse.swt.widgets.Composite.WM_SIZE(Composite.java:125 2)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:1999)
at org.eclipse.ui.internal.LayoutPart.setBounds(LayoutPart.java :299)
at
org.eclipse.ui.internal.presentations.PresentablePart.setBou nds(PresentableP
art.java:118)
at
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.layoutConte
nt(PresentablePartFolder.java:131)
at
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.layout(Pres
entablePartFolder.java:405)
at
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(Pres
entablePartFolder.java:289)
at
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftTo
RightTabOrder.java:65)
at
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPar
t(TabbedStackPresentation.java:391)
at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.jav
a:1102)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1051)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:12 56)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:442)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:109 )
at
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.ja
va:60)
at
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:2
12)
at
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:202
at
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:758
at
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager
..java:665)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:628)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.ja
va:2360)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2295
at org.eclipse.ui.internal.WorkbenchPage.access$9(WorkbenchPage .java:2287)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2273)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2268)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2249)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:371)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:334)
at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileActio n.java:98)
at
org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystem EditorAction.jav
a:98)
at
com.eyeris.eyeprofit.ui.core.views.navigator.EPOpenActionGro up.runDefaultAct
ion(EPOpenActionGroup.java:109)
Re: Problems Opening GEF Editor: Migration from 3.1 M6 -> 3.1.1 [message #198604 is a reply to message #198593] Wed, 12 October 2005 11:35 Go to previous messageGo to next message
Please read the 3.1.0 release notes for Eclipse.
Re: Problems Opening GEF Editor: Migration from 3.1 M6 -> 3.1.1 [message #198641 is a reply to message #198604] Wed, 12 October 2005 11:46 Go to previous messageGo to next message
Thanks Randy, I just found it! That took care of that problem but we still
have other issues, I'll post again if we can't resolve them.
15. ClassCastException using FillLayout
What is affected: Plug-ins that incorrectly use FillLayout.
Description: In Eclipse 3.0, no layout data was associated with the
FillLayout and if an application assigned layout data to a child that was
managed by a FillLayout, it was ignored. In Eclipse 3.1, support was added
to FillLayout to cache size information in order to improve resize
performance. The cached data is stored in a FillData object associated with
each child managed by the FillLayout. If an application has incorrectly
assigned layout data to a child, a ClassCastException will be thrown when
computeSize is called on the parent.
Action required: Find any children in a FillLayout that have layout data
assigned and stop assigning the layout data.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:dijaf5$2qb$1@news.eclipse.org...
Re: Problems Opening GEF Editor: Migration from 3.1 M6 -> 3.1.1 [message #198683 is a reply to message #198641] Wed, 12 October 2005 11:57 Go to previous message
It would be great if you moved to 3.1.0 first, and then moved to 3.1.1.
There should be *NO* breaking changes between 3.1.0 and 3.1.1, anywhere.
Whereas if you find breaking stuff between M6 and something later, that's a
normal part of the release development cycle. You'll still get help, but
they probably aren't "bugs".
"Paul Wuethrich" <paul.wuethrich@eye-ris.com> wrote in message
news:dijb59$3s9$1@news.eclipse.org...
> still
Previous Topic:REQ_OPEN issue.
Next Topic:Help for layout
Current Time: Sun Aug 31 08:07:14 EDT 2025
Powered by FUDForum. Page generated in 0.03393 seconds
