Crash with empty Labels on Linux [message #198469] |
Wed, 12 October 2005 03:00  |
instantiating Labels (from draw2D) with no initial text the application
crashes with following error (only on linux, on windows the application
works fine):
------------------------------------------------------ The
program 'SWT' received an X Window System error. This probably reflects a
bug in the program. The error was 'BadAlloc (insufficient resources for
operation)'.
(Details: serial 4345 error_code 11 request_code 53 minor_code 0) (Note
to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it. To debug
your program, run it with the --sync command line option to change this
behavior. You can then get a meaningful backtrace from your debugger if
you break on the gdk_x_error() function.)
----------------------------------------------------- Trying to find a
workaround I set a MarginBorder(1) on the Label the problem seems to be
resolved.
regards
Re: Crash with empty Labels on Linux [message #198931 is a reply to message #198723] |
Thu, 13 October 2005 09:48   |
I will provide a snippet as soon as possible. Unfortunately I can
reproduce the problem only on our application, but not in a simple
standalone.
On Wed, 12 Oct 2005 13:03:44 -0400, Billy Biggs wrote:
> A snippet would be very helpful. X is asynchronous, but in SWT there is
> a way to put it in synchronous mode so you can get a stack trace of
> where the failure occurs. When creating the display:
> Device.DEBUG = true;
> DeviceData data = new DeviceData();
> data.debug = true;
> Display display = new Display (data);
> The X request which is failing here is an XCreatePixmap, so this might
> have to do with an icon somewhere failing...
> Randy Hudson wrote:
>> This sounds like a nasty bug. Can you please provide us with a snippet that
>> reproduces it?
>> "Max" <mbrigl@gmx.net> wrote in message
>> news:pan.2005.10.12.07.00.57.225057@gmx.net...
>>>works fine):
>>>operation)'.
>>>resolved.
>>>regards
Re: Crash with empty Labels on Linux [message #199138 is a reply to message #198939] |
Thu, 13 October 2005 16:24  |
Originally posted by: bbiggs.ca.ibm.com
Randy Hudson wrote:
> "Billy Biggs" <bbiggs@ca.ibm.com> wrote in message
> news:dijflh$a39$1@news.eclipse.org...
>> data.debug = true;
> Billy, can this be done by using the PDE launcher's Tracing Tab?
Good call. If you enable tracing for org.eclipse.ui, one of
the options is "debug/swtdebug". This _should_ enable both Device.DEBUG
and data.debug, but it may only do the latter which would be less useful
in this case.
Try swtdebug, and if you don't get a stack trace, file a bug against
Platform > UI asking for more tracing options :)
-Billy
FUDForum. Page generated in 0.05171 seconds
