Home » Newcomers » Newcomers » Starting the debugger as root without starting Eclipse as root
Starting the debugger as root without starting Eclipse as root [message #198416] Thu, 08 March 2007 05:41 Go to next message
Originally posted by: lambert_anne.club.lemonde.fr
I am developing a small C program that uses the libpcap library. For the
program to work it need to be started it as root. How do I get the
debugger to start itself with root??
I tried adding an alias: gdb 'sudo gdb' but when started with eclipse I am
still the owner of the process... If I try to start gdb outside of
Eclipse, no problem, owner is root.
Any idea?
Thanks for any help,
Anne
Re: Starting the debugger as root without starting Eclipse as root [message #198603 is a reply to message #198416] Thu, 08 March 2007 11:01 Go to previous message
Hi Anne,
You are more likely to get an answer in the eclipse.tools.cdt newsgroup
HTH
Darins
"Anne Lambert" <lambert_anne@club.lemonde.fr> wrote in message
news:7bab7c9679cc1a2ed79fe78191eae2e2$1@www.eclipse.org...
> debugger to start itself with root?? I tried adding an alias: gdb 'sudo
> gdb' but when started with eclipse I am still the owner of the process...
> If I try to start gdb outside of Eclipse, no problem, owner is root.
> Any idea? Thanks for any help,
> Anne
Previous Topic:Programmatically backup workspace
Next Topic:Error On Startup
Current Time: Tue May 13 13:38:42 EDT 2025
Powered by FUDForum. Page generated in 0.08433 seconds
