Home » Language IDEs » Java Development Tools (JDT) » hot code replace supported in remote debugging session?
hot code replace supported in remote debugging session? [message #198013] Tue, 08 March 2005 16:50 Go to next message
Originally posted by: zhangrusi.yahoo.com
Can anyone confirm whether or not the "hot code replace" feature is
supported when debugging a remote Java application? I am debugging Java
code in a JVM that resides in a remote process. I am able to successfully
attach the debugger to the remote JVM, set breakpoints, step through code,
etc. But when I try to edit the source code, Eclipse will not let me
change it (typing in the Java code editor has no effect).
I can use hot code replace successfully when debugging a simple Java
application that is launched via the debugger. That is, when I change the
source code and then save the file, it is automatically compiled and the
code running in the JVM is updated. I can see the changes in my debugging
session. (Note that I am simply trying to modify the body of a method,
not change any class or method signatures.)
I am using Eclipse 3.0.1. My remote JVM is:
java version "1.4.2_06"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2_06-b03)
Java HotSpot(TM) Client VM (build 1.4.2_06-b03, mixed mode)
I instantiate it via the invocation API, using the following startup
options:
-Xdebug
-Xrunjdwp:transport=dt_socket,address=7979,server=y,suspend= n
-Xnoagent
-Djava.compiler=NONE
-Xmx512M
Thanks and let me know if you need more info...
Re: hot code replace supported in remote debugging session? [message #198292 is a reply to message #198013] Thu, 10 March 2005 14:47 Go to previous messageGo to next message
Originally posted by: jaredburns.no.spam.acm.org
Yes, HCR works for remote VM debugging.
If you can't edit the Java source file, that has nothing to do with HCR.
Sounds like you're looking at source from a JAR, so it's marked read-only.
- Jared
zhangrusi wrote:
> Java code in a JVM that resides in a remote process. I am able to
> successfully attach the debugger to the remote JVM, set breakpoints,
> step through code, etc. But when I try to edit the source code, Eclipse
> will not let me change it (typing in the Java code editor has no effect).
> the source code and then save the file, it is automatically compiled and
> the code running in the JVM is updated. I can see the changes in my
> debugging session. (Note that I am simply trying to modify the body of
> a method, not change any class or method signatures.)
> options:
> -Xdebug
> -Xnoagent
> -Xmx512M
Re: hot code replace supported in remote debugging session? [message #198322 is a reply to message #198292] Thu, 10 March 2005 16:30 Go to previous message
Yes, using a .class file instead did the trick. Thanks!
> - Jared
> zhangrusi wrote:
>> Hi,
>> options:
>> -Xdebug
>> -Xnoagent
>> -Xmx512M
Previous Topic:Changing project and package/folder icon in package explorer
Next Topic:Expanding non java nodes in package explorer
Current Time: Thu Nov 06 13:10:06 EST 2025
Powered by FUDForum. Page generated in 0.03181 seconds
