Home » Modeling » GMF (Graphical Modeling Framework) » GMF Wizards
GMF Wizards [message #197758] Thu, 17 July 2008 10:46 Go to next message
Originally posted by: lwrage.sei.cmu.edu
is there a way to sort the domain model elements in the GMF wizards
alphabetically? I have a domain model with about 200 metaclasses which
are all listed in the wizards in some seemingly arbitrary order, which
makes it very tedious to use the wizards at all. Also, for large models
it would be nice to have the possibility to collapse all model
elements in the gmfgraph and gmftool wizards.
Lutz
Re: GMF Wizards [message #198252 is a reply to message #197758] Tue, 22 July 2008 05:59 Go to previous messageGo to next message
Lutz Wrage pisze:
> Hello,
> it would be nice to have the possibility to collapse all model elements
> Lutz
Did you look at the Eclips Bugzilla if there is a request for
enhancement like this? If there isn't, could you sumbit one?
kind regards,
Jakub
http://eclipser-blog.blogspot.com/
http://eclipse-po-polsku.blogspot.com/
Re: GMF Wizards [message #198265 is a reply to message #197758] Tue, 22 July 2008 06:21 Go to previous messageGo to next message
Hello Lutz,
If you so much classes and want them in your editor you may want to have a
look at the GenGMF project:
http://gengmf.randomice.net/
regards
Enrico
Lutz Wrage wrote:
> Hello,
> Lutz
Re: GMF Wizards [message #198274 is a reply to message #198265] Tue, 22 July 2008 06:42 Go to previous message
An other solution might be ATLflow, it uses annotations at the ecore
model to generate the corresponding gmf artifacts via model transformation.
http://opensource.urszeidler.de/ATLflow/html1/samples/genera teGMF.html
greetings, urs.
Previous Topic:Fixed size Diagram Editor
Next Topic:How to get root DiagramImpl from the sub-diagram editor
Current Time: Sat Nov 01 09:51:55 EDT 2025
Powered by FUDForum. Page generated in 0.03557 seconds
