| problems starting eclipse with commandline [message #197869] |
Thu, 19 February 2004 11:56  |
I have been struggling to start my own application from the DOS command
line with eclipse, but I keep on getting "Unable to locate application
extension".
This is how my plugin.xml looks like:
<?eclipse version="3.0"?>
<plugin
id="de.lilith.authentification"
name="Authentification Plug-in"
version="1.0.0"
provider-name="lilith.de"
class="de.lilith.authentification.AuthentificationPlugin">
<runtime>
<library name="authentification.jar">
<export name="*"/>
</library>
</runtime>
<requires>
<import plugin="org.eclipse.ui"/>
<import plugin="org.eclipse.core.resources"/>
<import plugin="org.eclipse.core.runtime.compatibility"/>
</requires>
<extension
id="LoginApplication"
point="org.eclipse.core.runtime.applications">
<application>
<run
class="de.lilith.authentification.LoginShell">
</run>
</application>
</extension>
</plugin>
the plugin is also exported in the plugin directory. My path hierarchy is
eclipse\workspace\de.lilith.authentification
Can someone please tell me how the command should look like in order to
get the application start with eclipse.
thanks & cheers,
Lilith
FUDForum. Page generated in 0.03920 seconds
