Home » Language IDEs » ServerTools (WTP) » Server is always "Starting..."
Server is always "Starting..." [message #193986] Tue, 05 June 2007 17:38 Go to next message
I have a Tomcat 5.5 server config and a single web app project assigned
to it. Everything was fine until today, but now whenever I start the
application, the status shows "Starting..." forever. I can use the web
application, but if I change a file, it doesn't publish -- I assume this
is because Eclipse/WTP thinks the app is still "Starting...". How can I
diagnose this? I've already tried restarting Eclipse with -clean,
deleting the server config and recreating it, even restarting the
computer (just for fun).
Ideas?
This is Eclipse 3.2, WTP 1.5.4.
Thanks in advance,
Noel
Re: Server is always "Starting..." [message #194018 is a reply to message #193986] Tue, 05 June 2007 21:02 Go to previous messageGo to next message
One additional note (sorry to reply to self) -- it seems that this
problem started after I first ran the project in Debug mode. I've tried
cleaning the project and rebuilding, but this problem persists. It's
really a drag.
Noel Bush wrote on 06/05/2007 05:38 PM:
> Ideas?
> Thanks in advance,
> Noel
Re: Server is always "Starting..." [message #194051 is a reply to message #194018] Wed, 06 June 2007 08:35 Go to previous messageGo to next message
By "Debug mode", do you mean the "Debug on server" command or the
"Enable Tomcat Debug mode (v4.x and above only)" checkbox in the server
editor?
Larry
> really a drag.
>> assigned to it. Everything was fine until today, but now whenever I
>> start the application, the status shows "Starting..." forever. I can
>> use the web application, but if I change a file, it doesn't publish --
>> I assume this is because Eclipse/WTP thinks the app is still
>> "Starting...". How can I diagnose this? I've already tried
>> restarting Eclipse with -clean, deleting the server config and
>> recreating it, even restarting the computer (just for fun).
>> Ideas?
>> Thanks in advance,
>> Noel
Re: Server is always "Starting..." [message #194075 is a reply to message #194051] Wed, 06 June 2007 10:24 Go to previous messageGo to next message
Sorry, by "Debug mode" I meant Run > Debug...
More on this: I have found that by recreating my workspace and
re-checking out this project from my svn repo, I was able to eliminate
the bad behavior for a few hours (last night). But this morning, after
starting up Eclipse again, I'm seeing the same frustrating behavior.
This is really problematic, because every time I make the smallest
change to any file -- even a .js or .css or other static file -- I have
to stop the server and restart it to get the publish to take effect.
Noel
Larry Isaacs wrote on 06/06/2007 08:35 AM:
> editor?
> Cheers,
> Larry
>> tried cleaning the project and rebuilding, but this problem persists.
>> It's really a drag.
>>> -- I assume this is because Eclipse/WTP thinks the app is still
>>> Ideas?
>>> Thanks in advance,
>>> Noel
Re: Server is always "Starting..." [message #194083 is a reply to message #194075] Wed, 06 June 2007 11:03 Go to previous messageGo to next message
This isn't something I'm currently able to duplicate, so I'm left to
asking questions and/or guessing. You mention having to stop and
restart the server. Does this mean you are not seeing the server's
Status in the Servers view still sticking on ""Starting..."?
In theory, when you save a static file, the server's State in the
Servers view should briefly switch from Synchronized and then return to
Synchronized when the change has been auto-published. Is this
happening? If so, can you see the changed file in the running Tomcat?
To determine where catalina.base is pointing, see:
http://www.eclipse.org/webtools/faq/TomcatServerFAQ.php#info _04
Your webapp should appear under the "webapps" folder at this location.
Larry
> Noel
>> server editor?
>> Cheers,
>> Larry
>>> persists. It's really a drag.
>>>> can use the web application, but if I change a file, it doesn't
>>>> publish -- I assume this is because Eclipse/WTP thinks the app is
>>>> still "Starting...". How can I diagnose this? I've already tried
>>>> Ideas?
>>>> Thanks in advance,
>>>> Noel
Re: Server is always "Starting..." [message #194091 is a reply to message #194083] Wed, 06 June 2007 11:57 Go to previous messageGo to next message
Thanks for your replies. No, I am still seeing the server's Status in
the Servers view sticking on "Starting...". The behavior you describe
about what happens when I change a static file doesn't happen -- it's
just permanently on "Starting...". And when I look in the
catalina.base, I don't see the changed file.
I am giving things a try with WTP 2.0RC2 now. If the issue doesn't
recur there I won't pursue it with 1.5.4.
Thank you again,
Noel
Larry Isaacs wrote on 06/06/2007 11:03 AM:
> Cheers,
> Larry
>> after starting up Eclipse again, I'm seeing the same frustrating
>> behavior.
>> have to stop the server and restart it to get the publish to take effect.
>> Thanks,
>> Noel
>>> server editor?
>>> Cheers,
>>> Larry
>>>>> I start the application, the status shows "Starting..." forever. I
>>>>> Ideas?
>>>>> Thanks in advance,
>>>>> Noel
Re: Server is always "Starting..." [message #194114 is a reply to message #194091] Wed, 06 June 2007 14:10 Go to previous messageGo to next message
At this point, I would guess that the server not reaching the "Started"
Status is interfering with publishing the static file changes. It would
seem the "ping" test that tries to determine when the server is ready to
serve requests isn't succeeding for some unknown reason. I'm not aware
of any changes in WTP 2.0 that would affect this kind of issue, but who
knows. Let us know how it turns out.
Larry
> Thank you again,
> Noel
>> to Synchronized when the change has been auto-published. Is this
>> Cheers,
>> Larry
>>> eliminate the bad behavior for a few hours (last night). But this
>>> morning, after starting up Eclipse again, I'm seeing the same
>>> effect.
>>> Thanks,
>>> Noel
>>>> server editor?
>>>> Cheers,
>>>> Larry
>>>>>> I can use the web application, but if I change a file, it doesn't
>>>>>> Ideas?
>>>>>> Thanks in advance,
>>>>>> Noel
Re: Server is always "Starting..." [message #197908 is a reply to message #194114] Fri, 03 August 2007 15:04 Go to previous messageGo to next message
When I upgraded to WTP 2.0, this problem went away. Until today. It
seems to have started just after I install oXygenXML. I'm using Europa,
with all current updates.
You mentioned a "ping" test -- what precisely does that do, and how
could I check whether/why it's failing?
Noel
Larry Isaacs wrote on 06/06/2007 02:10 PM:
> Larry
>> Thank you again,
>> Noel
>>> Tomcat? To determine where catalina.base is pointing, see:
>>> Cheers,
>>> Larry
>>>> effect.
>>>> Thanks,
>>>> Noel
>>>>> server editor?
>>>>> Cheers,
>>>>> Larry
>>>>>>> whenever I start the application, the status shows "Starting..."
>>>>>>> forever. I can use the web application, but if I change a file,
>>>>>>> it doesn't publish -- I assume this is because Eclipse/WTP thinks
>>>>>>> the app is still "Starting...". How can I diagnose this? I've
>>>>>>> already tried restarting Eclipse with -clean, deleting the server
>>>>>>> config and recreating it, even restarting the computer (just for
>>>>>>> fun).
>>>>>>> Ideas?
>>>>>>> Thanks in advance,
>>>>>>> Noel
Re: Server is always "Starting..." [message #197916 is a reply to message #197908] Fri, 03 August 2007 15:26 Go to previous messageGo to next message
Disabling oXygenXML makes this problem go away.
I should file a bug with oXygen. Any tips on what I should direct them
to be looking at? Anything I could possibly do to stop oXygen from
interfering with Eclipse knowing that my Tomcat server has successfully
started up?
Thanks again,
Noel
Noel Bush wrote on 08/03/2007 03:04 PM:
> Noel
>> "Started" Status is interfering with publishing the static file
>> changes. It would seem the "ping" test that tries to determine when
>> the server is ready to serve requests isn't succeeding for some
>> unknown reason. I'm not aware of any changes in WTP 2.0 that would
>> affect this kind of issue, but who knows. Let us know how it turns out.
>> Larry
>>> in the Servers view sticking on "Starting...". The behavior you
>>> describe about what happens when I change a static file doesn't
>>> happen -- it's just permanently on "Starting...". And when I look in
>>> the catalina.base, I don't see the changed file.
>>> Thank you again,
>>> Noel
>>>> Cheers,
>>>> Larry
>>>>> effect.
>>>>> Thanks,
>>>>> Noel
>>>>>> server editor?
>>>>>> Cheers,
>>>>>> Larry
>>>>>>> this problem started after I first ran the project in Debug
>>>>>>> mode. I've tried cleaning the project and rebuilding, but this
>>>>>>> problem persists. It's really a drag.
>>>>>>>> thinks the app is still "Starting...". How can I diagnose
>>>>>>>> Ideas?
>>>>>>>> Thanks in advance,
>>>>>>>> Noel
Re: Server is always "Starting..." [message #197924 is a reply to message #197916] Fri, 03 August 2007 16:42 Go to previous message
> started up?
Just give them the details of what the symptoms are. Particularly what
version of web tools you have installed, what version of eclipse, and
what version of Oxygen. If you are using OxygenXML and are on Eclipse
3.3, make sure you have the 3.3 compatible version of that plugin
otherwise you will get some weird results.
The oxygenXML folks are pretty quick at responding to issues.
Dave
Previous Topic:Can I customize the "new xml file" wizard?
Next Topic:content assist within XHTML pages
Current Time: Sat Jul 26 11:27:56 EDT 2025
Powered by FUDForum. Page generated in 0.07029 seconds
