Home » Archived » BIRT » what jars are required to run the example program
what jars are required to run the example program [message #197870] Thu, 26 October 2006 12:56 Go to next message
Originally posted by: lingtai.earthlink.net
I have tried to run the Parameter Details example (i.e.
ParametersTask.java) posted on the BIRT Wiki RE API examples site. I
have added the following jars to my build path:
c:/birt-runtime-2_1_1/ReportEngine/lib/coreapi.jar
c:/birt-runtime-2_1_1/ReportEngine/lib/modelapi.jar
c:/birt-runtime-2_1_1/ReportEngine/lib/engienapi.jar
and was able to compile the example successfully. But, when I try to
run the example, I got following error. What additional jar files are
required? Please help.
Many thanks,
Ling
Exception in thread "main" java.lang.NoClassDefFoundError:
org.apache.commons.codec.binary.Base64
at
org.eclipse.birt.report.model.metadata.SimpleEncryptionHelpe r. <clinit>(SimpleEncryptionHelper.java:29)
at java.lang.J9VMInternals.initializeImpl(Native Method)
at java.lang.J9VMInternals.initialize(J9VMInternals.java:161)
at
org.eclipse.birt.report.model.metadata.MetaDataDictionary.<init >(MetaDataDictionary.java:203)
at
org.eclipse.birt.report.model.metadata.MetaDataDictionary.<clinit >(MetaDataDictionary.java:107)
at
org.eclipse.birt.report.model.api.impl.DesignEngineImpl.newS essionHandle(DesignEngineImpl.java:122)
at
org.eclipse.birt.report.model.api.DesignEngine.newSessionHan dle(DesignEngine.java:106)
at
org.eclipse.birt.report.model.api.DesignEngine.newSession(De signEngine.java:128)
at
org.eclipse.birt.report.engine.parser.ReportParser.getDesign Handle(ReportParser.java:145)
at
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:243)
at
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:191)
at
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:125)
at
org.eclipse.birt.report.engine.api.impl.ReportEngine.openRep ortDesign(ReportEngine.java:224)
at com.ibm.report.ParametersTask.executeReport(ParametersTask.j ava:96)
at com.ibm.report.ParametersTask.main(ParametersTask.java:356)
Re: what jars are required to run the example program [message #197886 is a reply to message #197870] Thu, 26 October 2006 14:30 Go to previous messageGo to next message
Originally posted by: home4slc.pacbell.net
Hi Ling,
I have not tried the example, but it looks like you are missing (at
least) the jakarta commons codec jar file. I believe it can be
downloaded from here:
http://jakarta.apache.org/commons/codec/
Susan
> Many thanks,
> Ling
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: what jars are required to run the example program [message #198363 is a reply to message #197886] Mon, 30 October 2006 14:28 Go to previous message
Susan:
Thank you very much for the help. After I added all the jar files under
the ../ReportEngine/lib/ to the build path, the sample example works.
Many thanks,
Ling
Susan Cline wrote:
> Hi Ling,
> Regards,
> Susan
>> Many thanks,
>> Ling
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Previous Topic:Average of grouped count column in line chart
Next Topic:Which CVS tag for org.eclipse.datatools.connectivity.oda.flatfile
Current Time: Sat Jul 19 02:32:50 EDT 2025
Powered by FUDForum. Page generated in 0.05287 seconds
