Home » Eclipse Projects » GEF » NullPointerException in palette
NullPointerException in palette [message #197697] Wed, 05 October 2005 05:39 Go to next message
Hi there,
I'm kind of stuck with a problem and I'm running out of ideas :(
A NullPointerException is thrown somewhere in the middle of a palette update
In FigureUtilities:
protected static void setFont(Font f) {
if (appliedFont == f || f.equals(appliedFont))
return;
getGC().setFont(f);
appliedFont = f;
metrics = null;
.... the passed Font is null - now I'm kind of confused how this can happen.
In ParagraphTextLayout.layout(), textFlow.getFont() (line 181) returns the
null that is passed all the way up to FigureUtilities and causes the
Exception.
Does anyone have an idea what I'm doing wrong? The DetailedLabeledFigure
alread has the null-Font entry, why is this happening only on certain
palette entries - they're all added and created the same way...
Any help is greatly appreciated!!
at org.eclipse.draw2d.FigureUtilities.setFont(FigureUtilities.j ava:369)
at
org.eclipse.draw2d.FigureUtilities.getFontMetrics(FigureUtil ities.java:58)
at
org.eclipse.draw2d.text.FlowUtilities.getAverageCharWidth(Fl owUtilities.java:66)
at
org.eclipse.draw2d.text.FlowUtilities.wrapFragmentInContext( FlowUtilities.java:189)
at
org.eclipse.draw2d.text.ParagraphTextLayout.layout(Paragraph TextLayout.java:181)
at
org.eclipse.draw2d.text.FlowFigureLayout.layout(FlowFigureLa yout.java:101)
at org.eclipse.draw2d.Figure.layout(Figure.java:1033)
at org.eclipse.draw2d.Figure.validate(Figure.java:1736)
at
org.eclipse.draw2d.text.FlowContainerLayout.layoutChildren(F lowContainerLayout.java:112)
at
org.eclipse.draw2d.text.FlowContainerLayout.layout(FlowConta inerLayout.java:98)
at
at org.eclipse.draw2d.text.BlockFlow.validate(BlockFlow.java:30 0)
at org.eclipse.draw2d.text.FlowPage.validate(FlowPage.java:132)
at
org.eclipse.draw2d.DeferredUpdateManager.validateFigures(Def erredUpdateManager.java:271)
at
org.eclipse.draw2d.DeferredUpdateManager.performUpdate(Defer redUpdateManager.java:143)
at
org.eclipse.draw2d.LightweightSystem.controlResized(Lightwei ghtSystem.java:147)
at
org.eclipse.draw2d.LightweightSystem$1.controlResized(Lightw eightSystem.java:99)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:149)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1036)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1060)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1041)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:620)
at org.eclipse.swt.widgets.Composite.setBounds(Composite.java:9 68)
at org.eclipse.swt.widgets.Canvas.setBounds(Canvas.java:239)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:482)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite$PaletteCom posite.layout(FlyoutPaletteComposite.java:1000)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite$10.handleE vent(FlyoutPaletteComposite.java:966)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:510)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite.layoutComp onentsWest(FlyoutPaletteComposite.java:408)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite.layout(Fly outPaletteComposite.java:356)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite$22.handleE vent(FlyoutPaletteComposite.java:211)
at org.eclipse.swt.layout.FillLayout.layout(FillLayout.java:198 )
at org.eclipse.swt.widgets.Composite.updateLayout(Composite.jav a:1143)
at org.eclipse.swt.widgets.Composite.setBounds(Composite.java:9 71)
at org.eclipse.swt.custom.CTabFolderLayout.layout(CTabFolderLay out.java:78)
at org.eclipse.ui.internal.LayoutPart.setBounds(LayoutPart.java :299)
at
org.eclipse.ui.internal.presentations.PresentablePart.setBou nds(PresentablePart.java:131)
at
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.layoutContent(PresentablePartFolder.java:131)
at
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.layout(PresentablePartFolder.java:418)
at
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:289)
at
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:387)
at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1131)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1084)
at
org.eclipse.ui.internal.WorkbenchPage.internalBringToTop(Wor kbenchPage.java:713)
at org.eclipse.ui.internal.WorkbenchPage.activate(WorkbenchPage .java:551)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2334)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2258)
at org.eclipse.ui.internal.WorkbenchPage.access$9(WorkbenchPage .java:2250)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2236)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2231)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2204)
Thanks a lot!!
Fabian
Re: NullPointerException in palette [message #197732 is a reply to message #197697] Wed, 05 October 2005 10:27 Go to previous messageGo to next message
Originally posted by: mvsteenbergen.eljakim.scratch-this.nl
Are you by any chance using a MPE with several GraphicalEditors? :)
I have the same problem, but only when my MPE contains more than one
GraphicalEditor (it contains an arbitrary number of GraphicalEditors,
depending on the contents of the input file). I have no idea yet what's
causing this, but I thought I'd add this; maybe it helps.
Martijn.
Re: NullPointerException in palette [message #197770 is a reply to message #197732] Wed, 05 October 2005 11:43 Go to previous messageGo to next message
>> update (?).
Uh, yes I am using a MPE with several GraphicalEditors,...
There was no problem however until recently I added a new entry to the
palette which is no different than any other palette entry - this is what
puzzles me. It happens somewhere in DetailedLabelFigure that the Font is
not set or somehow set to null?!?
Maybe I should offer the source ...
http://www.enstage.de/ferkelsrc.zip
http://www.enstage.de/ferkel.linux.gtk.x86.tar.bz2 (exported RCP)
http://www.enstage.de/ferkel.win32.win32.x86.zip (exportet RCP)
Steps to reproduce:
Start Ferkel -> New Project -> Add Milestone 1 -> Add Milestone 2
-> Add "Dialog" to Editor "Dialogstrukturdiagramm" -> Add "Interaktion" as a
child to the added "Dialog"
-> Save All -> Restart Ferkel and Load Project.
A NullPointerException should occur on making the palette of
"Dialogstrukturdiagramm" visible.
This code is part of a university project - it's open source and alright for
others to use as a template (lots of people are seeking help on
implementing GEF with MPE - here's an example).
The code is not really pretty, but wer're in kind of a hurry on getting it
finished.
Thanks for any help and hints!!
Fabian
Re: NullPointerException in palette [message #197778 is a reply to message #197732] Wed, 05 October 2005 12:07 Go to previous messageGo to next message
Here's the stack trace.
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.NullPointerException)
at
org.eclipse.draw2d.FigureUtilities.getStringDimension(Figure Utilities.java:112)
at
org.eclipse.draw2d.text.FlowUtilities.measureString(FlowUtil ities.java:140)
at
org.eclipse.draw2d.text.FlowUtilities.wrapFragmentInContext( FlowUtilities.java:237)
at
at
at
at
at
at
at
at
org.eclipse.draw2d.DeferredUpdateManager$UpdateRequest.run(D eferredUpdateManager.java:40)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 18 more
M.
Re: NullPointerException in palette [message #197786 is a reply to message #197770] Wed, 05 October 2005 12:22 Go to previous messageGo to next message
You're right; if I create an empty PaletteRoot instead of my usual
palette filled with tools, the error doesn't occur. I can create drawers
and groups, but as soon as I fill a drawer or group with an entry
(PanningSelectionToolEntry, CombinedTemplateCreationEntry, it doesn't
seem to matter) *and* open more than two GraphicalEditors in one MPE,
the NPE is thrown.
Martijn.
Re: NullPointerException in palette [message #197797 is a reply to message #197697] Wed, 05 October 2005 13:34 Go to previous messageGo to next message
Originally posted by: none.unknown.com
This has been fixed in 3.1.1 (and 3.2M2). Try a newer build. If a figure's
font returns null, it means the figure is not a part of the figure hierarchy
anymore.
"Fabian Wolf" <Fabian.Wolf@informatik.uni-ulm.de> wrote in message
news:di070l$5c5$1@news.eclipse.org...
> Hi there,
update
> In FigureUtilities:
> return;
> getGC().setFont(f);
> appliedFont = f;
> metrics = null;
happen.
> Exception.
> at
> at
> at
:66)
> at
va:189)
> at
181)
> at
> at
ut.java:112)
> at
98)
> at
> at
er.java:271)
> at
..java:143)
> at
47)
> at
:99)
> at
> at
> at
> at
> at
> at
> at
ite.java:356)
> at
> at
> at
> at
> at
> at
> at
> at
> at
art.java:131)
> at
> at
> at
> at
> at
> at
a:1131)
> at
> at
713)
> at
> at
va:2334)
> at
> at
> at
> at
> at
> at
> Thanks a lot!!
> Fabian
Re: NullPointerException in palette [message #197828 is a reply to message #197797] Wed, 05 October 2005 14:47 Go to previous messageGo to next message
Hi Pratik,
thanks a lot,... updating worked well!
Are there any changelogs available for the different builds?
Back to the previous post: How can the figure become "kicked off" its figure
hierarchy? That does sound more like I did something wrong... anything I
have to look into?
Fabian
> figure's font returns null, it means the figure is not a part of the
> figure hierarchy anymore.
>> Hi there,
> update
> happen.
>> the null that is passed all the way up to FigureUtilities and causes the
>> Exception.
Re: NullPointerException in palette [message #197859 is a reply to message #197828] Wed, 05 October 2005 15:32 Go to previous message
The readme file for all maintenance releases contains the list of bugs fixed
in there. Similarly, you can just find out all bugs fixed in milestone
builds by just using appropriate bugzilla queries.
Every build page has a link to a build log at the top. Currently, it's
empty. We do plan to fix it so that the bugs fixed in that build would
actually be in there.
The figure was removed because its editpart was disposed. This may happen
when refreshing an editpart's children (as happens when you reload the
palette, for instance), deleting an editpart, etc.
For more information about the bug that you ran into, see:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=77941
news:di174o$ml6$1@news.eclipse.org...
> Hi Pratik,
figure
> have to look into?
> Regards,
> Fabian
> >> Hi there,
> > update
> > happen.
the
> >> Exception.
Previous Topic:Design Question
Next Topic:Restoring connections
Current Time: Wed Nov 05 13:36:03 EST 2025
Powered by FUDForum. Page generated in 0.06288 seconds
