Home » Newcomers » Newcomers » System.out.printf in Eclipse 3.2 with java 6
System.out.printf in Eclipse 3.2 with java 6 [message #197745] Sun, 04 March 2007 12:05 Go to next message
Originally posted by: mathew4152.yahoo.com
The following code compiles fine on command line. However, eclipse gives
an error saying : The method Printf( String, Object[] ) in the PrintStream
is not applicable for the arguments ( String, String ).
Can anybody tell me what am I missing with eclipse?
public class TestA {
String a = "Testing";
System.out.printf("%s\n", a);
Re: System.out.printf in Eclipse 3.2 with java 6 [message #197753 is a reply to message #197745] Sun, 04 March 2007 13:44 Go to previous messageGo to next message
Look under Preferences->Java->Installed JREs
and ensure that you are compiling with a jre that supports printf
Charlie
> PrintStream is not applicable for the arguments ( String, String ).
> public static void main(String[] args) {
Re: System.out.printf in Eclipse 3.2 with java 6 [message #197769 is a reply to message #197753] Sun, 04 March 2007 14:16 Go to previous messageGo to next message
I have only Java 6 installed and that is the only jre seen from eclipse.
It is the same jre that I can compile and run command line with. But,
eclipse is giving trouble. Again, I have only java 6 installed.
Re: System.out.printf in Eclipse 3.2 with java 6 [message #197777 is a reply to message #197745] Sun, 04 March 2007 16:13 Go to previous messageGo to next message
It compiles and runs fine for me (Eclipse 3.2.1, Java 6, Win XP). Did
you try cleaning the project (Project -> Clean...)?
/Paul
Re: System.out.printf in Eclipse 3.2 with java 6 [message #197785 is a reply to message #197769] Sun, 04 March 2007 16:22 Go to previous message
I found the answer. The eclipse "Compiler Compliance" by default is set to
1.4. I had to change it to 6.
Previous Topic:Visual Editor and RCP appliacions
Next Topic:Display fixed point numbers
Current Time: Thu Nov 06 22:07:32 EST 2025
Powered by FUDForum. Page generated in 0.10202 seconds
