Home » Eclipse Projects » GEF » What editpolicy shall I use to get double click message? & what's wrong with my code?
What editpolicy shall I use to get double click message? & what's wrong with my code? [message #197473] Mon, 03 October 2005 17:16 Go to next message
Hi, all,
I have read the help doc and couldn't find such editpolicy, so I write my
own DoubleClickEditPolicy.java as below
public abstract class DoubleClickEditPolicy
extends AbstractEditPolicy
protected Command createOpenCommand(GroupRequest request) {
return null;
public Command getCommand(GroupRequest request) {
//According to the documents, every EditPolicy will receive every message,
// and they just deal with what they are interested in.
//So I expect to see what the variable "request" is by setting up
breakpoint here when debugging.
//However, actually, it didn't stop, which quitely confused me.
//What's wrong with my understanding?
//And what's the right way to catch double click message? Thank you!
if (REQ_OPEN.equals(request.getType()))
return getOpenCommand(request);
return null;
protected Command getOpenCommand(GroupRequest request) {
return createOpenCommand(request);
Re: What editpolicy shall I use to get double click message? & what's wrong with my code? [message #197496 is a reply to message #197473] Tue, 04 October 2005 03:04 Go to previous messageGo to next message
Originally posted by: ingo.koch[nospam].sap.com
Hi Vince,
you have to catch the open-request in your editpart by overriding
public void performRequest(Request request).
Then you could pass the request to one of
editpolicy to have them do the request-command-handling.
regards, Ingo
"vince" <fiustudent@hotmail.com> wrote in message
news:dhs740$ofr$1@news.eclipse.org...
> Hi, all,
> return null;
> return null;
Re: What editpolicy shall I use to get double click message? & what's wrong with my code? [message #197664 is a reply to message #197496] Tue, 04 October 2005 21:44 Go to previous messageGo to next message
It works! Thank you very much!
However, it remains something that I don't understand.
That is, why I can't catch open-request by installing my EditPolicy
(compared to delete-request catched if ComponentEditPolicy is installed)? I
read the source code of AbstractEditPart, it does with every installed
EditPolicy:
public Command getCommand(Request request) {
Command command = null;
EditPolicyIterator i = getEditPolicyIterator();
while (i.hasNext()) {
if (command != null)
command = command.chain(i.next().
getCommand(request));
else
command = i.next().
getCommand(request);
return command;
I could get more information by debugging, but the method is called too
often. So I would be very appreciated if someone happens to know does GEF
have different policies with open-request or not?
Vince
"Ingo Koch" <ingo.koch[nospam]@sap.com> wrote in message
news:dht9ir$1l0$1@news.eclipse.org...
> Hi Vince,
> regards, Ingo
>> Hi, all,
>> return null;
>> message,
>> return null;
Re: What editpolicy shall I use to get double click message? & what's wrong with my code? [message #197673 is a reply to message #197664] Wed, 05 October 2005 02:57 Go to previous message
Hi Vince,
I could imagine that in most cases an open-request won
Previous Topic:Linux: java.lang.ClassNotFoundException: java.text.Bidi when opening a gef editor.
Next Topic:Custom Grid Layer
Current Time: Tue Nov 04 07:10:36 EST 2025
Powered by FUDForum. Page generated in 0.04174 seconds
