Home » Language IDEs » ServerTools (WTP) » WST 2.0: Server for Tomcat: Enable Tomcat debug mode in WST 1.5
Re: WST 2.0: Server for Tomcat: Enable Tomcat debug mode in WST 1.5 [message #197129 is a reply to message #197122] |
Tue, 24 July 2007 12:26   |
Just so I'm clear on what you are expecting, if you turn off "Enable
Tomcat debug mode" in WTP 1.5, what "debugging" stops working?
Larry
user@domain.invalid wrote:
> I would like to debug Tomcat (Version 5.0.x) with its web application
> like it is installed and without modifications from WTP.
> In WTP 1.5 it works with Enable Tomcat debug mode fine.
> In WTP 2.0 I do not understand the server settings and the help is not
> working (showing a xml phars error cause of not ended <div>).
> org.xml.sax.SAXParseException: The element type "div" must be terminated
> by the matching end-tag "</div>" on page "Creating a Tomcat server".
> at
> com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(D OMParser.java:264)
> at
> com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl. parse(DocumentBuilderImpl.java:292)
> at
> org.eclipse.help.internal.dynamic.DocumentReader.read(Docume ntReader.java:56)
> at
> org.eclipse.help.internal.dynamic.XMLProcessor.process(XMLPr ocessor.java:49)
> Larry Isaacs schrieb:
>> In WTP 2.0, this option is still in the server editor like it is in
>> WTP 1.5. However, in WTP 2.0, it has been more correctly labeled
>> "Enable Tomcat debug logging". If your Tomcat is version 5.0 or
>> later, the label will include "(not supported by this Tomcat version)"
>> and the check box will be disabled. Logging in these Tomcat versions
>> is controlled by a completely different approach and this option has
>> little or no impact on the Tomcat server.
>> What from of "debugging" were you doing in WTP 1.5 that you aren't
>> able to do in WTP 2.0 without this option?
>> Cheers,
>> Larry
>>> Hello,
>>> in WST 1.5 I've used Enable Tomcat debug mode in my Tomcat server
>>> settings.
>>> So I was able to debug my installed tomcat without any changes.
>>> How can I do this with WST 2.0?
>>> Regards
>>> Georg
Re: WST 2.0: Server for Tomcat: Enable Tomcat debug mode in WST 1.5 [message #197151 is a reply to message #197129] |
Tue, 24 July 2007 16:48   |
Originally posted by: gthuelly.web.de
I've tried this flag. I was suprised that it is not neccessary for
debugging the web apps in the Tomcat!
I had to disable the flag "Run modules directly from the workspace" in
WPT 1.5.
How do I configure 2.0 to get the same result?
Georg
> Cheers,
> Larry
>> terminated by the matching end-tag "</div>" on page "Creating a Tomcat
>> server".
>> at
>> at
>> at
>> at
>>> version)" and the check box will be disabled. Logging in these
>>> Tomcat versions is controlled by a completely different approach and
>>> this option has little or no impact on the Tomcat server.
>>> Cheers,
>>> Larry
>>>> Hello,
>>>> settings.
>>>> Regards
>>>> Georg
Re: WST 2.0: Server for Tomcat: Enable Tomcat debug mode in WST 1.5 [message #197190 is a reply to message #197151] |
Wed, 25 July 2007 09:09   |
Thanks. That clears things up. The "-debug" option in Tomcat 4.0.x and
4.1.x was a quick way to enable debug logging in Tomcat's server related
classes. It Tomcat 5.x and later, logging is configured differently and
this option has little or no effect.
> WPT 1.5.
In WTP 2.0, the "Use Tomcat installation (takes control of Tomcat
installation)" selection in the Server Locations section is the
equivalent of unchecking "Run modules directly..." in WTP 1.5. The "Use
workspace metadata (does not modify Tomcat installation)" is equivalent
to checking "Run modules directly...".
The WTP 2.0 Tomcat plug-ins don't support moving projects from one
Tomcat server instance to another. As a result, all projects need to be
removed from the server and the server published before these selections
are enabled and changes can be made. Once the desired changes are made,
re-add the desired projects.
For an explanation of the "(takes control of Tomcat installation)", see:
http://www.eclipse.org/webtools/faq/TomcatServerFAQ.php#gett ing_started_4
I'm still working on updating this FAQ with WTP 2.0 information, but
this aspect is relevant to WTP 2.0 as well as WTP 1.5.
Larry
> Thanks
> Georg
>> Cheers,
>> Larry
>>> not working (showing a xml phars error cause of not ended <div>).
>>> Tomcat server".
>>> at
>>> at
>>> at
>>> at
>>>> Cheers,
>>>> Larry
>>>>> Hello,
>>>>> settings.
>>>>> Regards
>>>>> Georg
Re: WST 2.0: Server for Tomcat: Enable Tomcat debug mode in WST 1.5 [message #197291 is a reply to message #197190] |
Thu, 26 July 2007 03:08  |
Thank you for your informations.
I'll read your FAQ and your mails and I am sure to find a way to
configre WST 2.0 to do what I want.
Special thanks for your help
>> WPT 1.5.
> Cheers,
> Larry
>> Thanks
>> Georg
>>> Cheers,
>>> Larry
>>>> application like it is installed and without modifications from WTP.
>>>> Tomcat server".
>>>> at
>>>> at
>>>> at
>>>> at
>>>>> and this option has little or no impact on the Tomcat server.
>>>>> Cheers,
>>>>> Larry
>>>>>> Hello,
>>>>>> settings.
>>>>>> Regards
>>>>>> Georg
Current Time: Sat Jul 26 16:07:58 EDT 2025
Powered by FUDForum. Page generated in 0.08459 seconds
