Home » Archived » BIRT » Where is the documentation
Where is the documentation [message #197041] Mon, 23 October 2006 10:35 Go to next message
Originally posted by: trevor.l.torrez.accenture.com
Hi, I'm new to using birt.
We have plans to integrate birt into a custom web application, after
much fuss I got the servlet integrated into an example application in a
way that meshes with our continuous build process and dependency management.
I have a few questions about the framework in general. Aside from the
flash tutorials, where is the general documentation? I'm looking for
something along the lines of explaining the overall interactions of the
main components, ie: how do the modelapi, coreapi, dte-api
(data-engine?), report-engine-api, and other api's interact? What are
the main responsibilities and features of each? I have a few other
specific questions which I'll post as separate threads.
-t.
Re: Where is the documentation [message #197044 is a reply to message #197041] Mon, 23 October 2006 10:54 Go to previous messageGo to next message
Originally posted by: m.kortas.net
Hi Trevor,
perhaps this is what you are looking for:
- http://help.eclipse.org/help31/index.jsp?
- http://wiki.eclipse.org/index.php/BIRT_Project
greetings
Michael
> -t.
Re: Where is the documentation [message #197048 is a reply to message #197044] Mon, 23 October 2006 11:34 Go to previous messageGo to next message
Michael wrote:
> Hi Trevor,
> greetings
> Michael
>> a way that meshes with our continuous build process and dependency
>> management.
>> the main components, ie: how do the modelapi, coreapi, dte-api
>> Thanks,
>> -t.
That should do nicely; thanks. I didn't see the help31 link referenced
anywhere; or did i just miss it?
-t.
Re: Where is the documentation [message #197049 is a reply to message #197048] Mon, 23 October 2006 11:42 Go to previous messageGo to next message
He's right those sites are the best online sources of documentation.
One side note: we just heard from Amazon that the book's release date
has been pushed to February. So, all of those plans to give the BIRT book
as Christmas Stocking Stuffers will have to be put on hold.
Ty
Re: Where is the documentation [message #197085 is a reply to message #197049] Mon, 23 October 2006 13:10 Go to previous messageGo to next message
Ty,
The Amazon date isn't correct and will be updated soon. Both books
should be available before December, so you can use them for stocking
stuffers! ;-)
--Mark
> book as Christmas Stocking Stuffers will have to be put on hold.
> Regards,
> Ty
Re: Where is the documentation [message #197138 is a reply to message #197049] Mon, 23 October 2006 13:56 Go to previous messageGo to next message
The help system is available with the designer as well.
Just select on the help contents.
Jason
"Tyrone Hed" <tyronehed@earthlink.net> wrote in message
news:23bfa47c9267199f1da3a521f99dd0d9$1@www.eclipse.org...
> Regards,
> Ty
Re: Where is the documentation [message #197735 is a reply to message #197044] Wed, 25 October 2006 20:24 Go to previous message
The help31 link has documentation for BIRT 2.0, which is now out of date.
You should use the help that installs with BIRT. The BIRT Report Developer
Guide section explains how to use the Report Designer UI. The reference
materials are now split into separate sections, BIRT Programmer Reference
and BIRT Charting Programmer Reference.
Jane Tatchell
BIRT documentation lead
"Michael" <m@kortas.net> wrote in message
news:0eab1b1cc48f19c63e5e63ec1ebab5e4$1@www.eclipse.org...
> Hi Trevor,
> greetings
> Michael
>> We have plans to integrate birt into a custom web application, after much
>> fuss I got the servlet integrated into an example application in a way
>> Thanks,
>> -t.
Previous Topic:hibernate+birt: resources missing...
Next Topic:Report designer: custom dataset not asked for metadata
Current Time: Wed Sep 03 10:06:53 EDT 2025
Powered by FUDForum. Page generated in 0.03956 seconds
