Home » Language IDEs » ServerTools (WTP) » Tomcat 6 and Eclipse 3.3 trouble
Tomcat 6 and Eclipse 3.3 trouble [message #196624] Wed, 18 July 2007 03:03 Go to next message
Originally posted by: sagene31.hotmail.com
Anyone else experiencing:
INFO: Starting Servlet Engine: Apache Tomcat/6.0.13
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 88)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:41 3)
Caused by: java.lang.SecurityException: Servlet of class
org.apache.catalina.servlets.InvokerServlet is privileged and cannot be
loaded by this web application
at
org.apache.catalina.core.StandardWrapper.loadServlet(Standar dWrapper.java:1134)
at org.apache.catalina.core.StandardWrapper.load(StandardWrappe r.java:981)
at
org.apache.catalina.core.StandardContext.loadOnStartup(Stand ardContext.java:4042)
at org.apache.catalina.core.StandardContext.start(StandardConte xt.java:4348)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1045)
at org.apache.catalina.core.StandardHost.start(StandardHost.jav a:719)
at org.apache.catalina.core.StandardEngine.start(StandardEngine .java:443)
at org.apache.catalina.core.StandardService.start(StandardServi ce.java:516)
at org.apache.catalina.core.StandardServer.start(StandardServer .java:710)
at org.apache.catalina.startup.Catalina.start(Catalina.java:566 )
Hope anyone can help.
Thanks in advance.
Re: Tomcat 6 and Eclipse 3.3 trouble [message #196660 is a reply to message #196624] Wed, 18 July 2007 10:22 Go to previous message
Because the InvokerServlet represents a security hole, you will have to
include privileged="true" in the <context> element for any webapp that
tries to deploy it. You would add this to appropriate <context>
elements in the server.xml found under the Servers project in your
workspace.
If you uncommented the InvokerServlet in the web.xml found under the
Servers project, then it applies to all webapps. In this case, if one
of the projects added to the server isn't a default webapp (i.e. one
with context-root set to an empty string), then you will need to add a
<context> for the "ROOT" webapp that is provided by default, i.e.:
<Context docBase="<path-to-default-webapp>" path="" privileged="true" />
For the Tomcat server created by default, the path to the default webapp
will be something like:
<workspace-path> \.metadata\.plugins\org.eclipse.wst.server.core\tmp?\wtpweba pps\ROOT
Larry
> at
> at
> at
> at
> Thanks in advance.
Previous Topic:Some Problem during launching websphere 6.1 from eclipse WTP 1.5.3
Next Topic:WTP 3.0 Release Themes DRAFT document published...
Current Time: Tue Jul 22 02:47:01 EDT 2025
Powered by FUDForum. Page generated in 0.27608 seconds
