Home » Language IDEs » ServerTools (WTP) » Eclipse 3.3 and JBoss 4.2 for JEE
Eclipse 3.3 and JBoss 4.2 for JEE [message #195860] Sun, 08 July 2007 10:18 Go to next message
Originally posted by: balajio.hotmail.com
Hi Everybody,
I just downloaded Eclipse Europa release and also JBoss AS 4.2.
I am trying to develop some simple EJBs to get a feel of the features
introduced in JEE 5. Both Eclipse and JBoss claim to support the latest
version of JEE but I am running into problems.
Specifically:
1. Eclipse is relying on XDoclet to generate the deployment descriptors
and XDoclet v1.2.3 is using J2EE v1.4 standard. I am getting errors about
SessionBean and EntityBean not found. These go away if I include the
jboss-j2ee.jar in the classpath.
2. I got the JBoss IDE plugin v1.6 for Eclipse. I am having similar issues
here as well.
So, my question is - if I want to write EJBs using annotations of JEE, how
should I configure Eclipse to generate all the required files conforming
to JEE 5 and used with JBoss v4.2 ? Or, are the plugins required for this
still in development/beta ?
TIA
balajio
Re: Eclipse 3.3 and JBoss 4.2 for JEE [message #195897 is a reply to message #195860] Tue, 10 July 2007 03:54 Go to previous messageGo to next message
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi !
You cannot use XDoclet for JavaEE5 ejbs. So, for adding an entity or session
bean to your project, you simply add a plain java class and add the necessary
annotations. I don't know any wizard for this, the WTP session and entity bean
wizards are only for J2EE <= 1.4.
Anyway, there should be no need to add "jboss-j2ee.jar" to your project because
the JBoss plugin in WTP 2.0 adds all JARs it finds in the common JBoss lib
directories.
Hope this helps
Wolfgang
balajio wrote:
> Hi Everybody,
> Specifically:
> about SessionBean and EntityBean not found. These go away if I include
> the jboss-j2ee.jar in the classpath.
> issues here as well.
> how should I configure Eclipse to generate all the required files
> conforming to JEE 5 and used with JBoss v4.2 ? Or, are the plugins
> required for this still in development/beta ?
> TIA
> balajio
Re: Eclipse 3.3 and JBoss 4.2 for JEE [message #196236 is a reply to message #195897] Wed, 11 July 2007 23:00 Go to previous messageGo to next message
Thank you for the reply. I agree with what you say about JEE EJBs.
I don't need to include jboss-j2ee.jar if I am not using xdoclet.
According to the documentation included with Eclipse 3.3, the examples
show creating EJBs with xdoclet and I thought that was dated (J2EE 1.4 or
earlier).
How are the deployment descriptor and other configuration files generated
for JBoss or any other application server ? I was hoping some wizard would
do that but if it has to be done manually, I can do that. I guess Eclipse
and application servers still have to implement all the features of JEE 5.
balajio
Re: Eclipse 3.3 and JBoss 4.2 for JEE [message #196252 is a reply to message #196236] Thu, 12 July 2007 04:25 Go to previous messageGo to next message
Hi Balajio,
the wizards for JavaEE5 modules provide an checkbox "create deployment
descriptors" which create default ejb-jar.xml, application.xml and so on.
But beware: this will not work if you create an EAR with default modules. You
have to create an empty EAR and add the modules one by one afterwards with this
option checked (https://bugs.eclipse.org/bugs/show_bug.cgi?id=181894).
For JBoss specific deployment descriptors there is no WTP support unfortunately.
Just for your information: JBoss 4.2 supports all JavaEE5 deployment descriptors.
Best regards
Wolfgang
> generated for JBoss or any other application server ? I was hoping some
> wizard would do that but if it has to be done manually, I can do that. I
> guess Eclipse and application servers still have to implement all the
> features of JEE 5.
> balajio
Re: Eclipse 3.3 and JBoss 4.2 for JEE [message #196492 is a reply to message #196252] Mon, 16 July 2007 16:56 Go to previous message
Wolfgang Knauf wrote:
> Hi Balajio,
You
this
unfortunately.
descriptors.
> Best regards
> Wolfgang
>> features of JEE 5.
>> balajio
Hi Wolfgang,
Thank you again for the response.
Best regards
balajio
Previous Topic:Integration of BIRT + Web application
Next Topic:BEA releases WebLogic Server Tools for Eclipse 3.3
Current Time: Wed Jul 23 15:31:43 EDT 2025
Powered by FUDForum. Page generated in 0.04001 seconds
