Home » Eclipse Projects » Eclipse Platform » New Folder, File
New Folder, File [message #195758] Mon, 16 February 2004 20:51 Go to next message
Originally posted by: vralphvREMOVE.yahoo.com
Hello. I am new to Eclipse. I am using Eclipse 2.1.2 on Windows 98 with
JDK1.3.
In the Basic Tutorial in Help, a picture is given for "New Folder" and
"New File". When I try to create a new folder, my "New Folder" window has a
field called "Enter or select the parent folder", but lacks the "Folder
Name:" field, the "Advanced " button, and the "Link to folder in the file
system" checkbox. Same for "New File".
So I am stuck at the very beginning. Any tips? Thanks in advance.
Ralph
Re: New Folder, File [message #196370 is a reply to message #195758] Tue, 17 February 2004 13:24 Go to previous messageGo to next message
Originally posted by: nick_edgar._no.spam.please_.ca.ibm.com
Strange. Those fields should be there. Does the dialog look like it's
complete, or did it get truncated or clipped?
What display resolution are you running at? Is there anything in the
workspace/.metadata/.log file?
Nick
"pageV" <vralphvREMOVE@yahoo.com> wrote in message
news:c0rrr4$3ap$1@eclipse.org...
> JDK1.3.
and
a
> Ralph
Re: New Folder, File [message #196682 is a reply to message #196370] Tue, 17 February 2004 20:19 Go to previous messageGo to next message
"Nick Edgar" <nick_edgar@_no.spam.please_.ca.ibm.com> wrote in message
news:c0tm3v$95q$1@eclipse.org...
> Nick
The dialog looks complete. My display is 800 by 600.
Nothing in the .log file. I was wondering if I need a
different JVM. I'm using the JDK1.3 that comes with JBuilder4.
Ralph
with
> > JDK1.3.
> and
has
> a
file
> > Ralph
Re: New Folder, File [message #196996 is a reply to message #196682] Wed, 18 February 2004 10:47 Go to previous messageGo to next message
Originally posted by: John_Arthorne.oti.com_
When all else fails, it's useful to try a different VM to see if it
solves the problem. A 1.3 VM is sufficient for Eclipse 2.1.x. You can
specify the VM using the "-vm" command line argument to the eclipse
executable.
> Ralph
Re: New Folder, File [message #197695 is a reply to message #196682] Thu, 19 February 2004 09:06 Go to previous messageGo to next message
Strange. The only thing I can think of is that you ran out of GDI or User
resources (graphics or window handles in the OS), which is a known problem
with Eclipse on Win98. Are you running any other apps at the same time? If
so, try rebooting your machine, avoid starting any other apps, start Eclipse
and try creating a new folder, and see if you get any further.
Nick
news:c0uec3$66b$1@eclipse.org...
> > Nick
> Ralph
> with
> > > JDK1.3.
Folder"
> > and
> has
> > a
"Folder
> file
> > > Ralph
Re: New Folder, File [message #198154 is a reply to message #197695] Thu, 19 February 2004 21:59 Go to previous messageGo to next message
news:c12fn1$rp8$1@eclipse.org...
If
Eclipse
> Nick
Yesterday I tried making a new class. The sixth button along the right side
was cut off to a sliver. Also, under "Which method stubs would you like to
create" , the second stub's check box is cut off to 1/4 height and the tops
only of the method showed. Tried rebooting today, but it still does it. The
cutting off happens a couple of inches from the bottom of the dialog. The
finish and cancel buttons at the bottom are still there. This is with 800 by
600 resolution. When I try a lower resolution, even more gets cut off. So
I think it is a resolution problem. I don't have a higher resolution, so I
am stuck. Does Java require a higher resolution?
Ralph
it's
> > > Nick
> > Ralph
> > with
> > > > JDK1.3.
> Folder"
> > > and
window
> > has
> > > a
> "Folder
> > file
> > > > Ralph
Re: New Folder, File [message #198162 is a reply to message #196996] Thu, 19 February 2004 22:01 Go to previous messageGo to next message
"John Arthorne" <John_Arthorne@oti.com_> wrote in message
news:40338910.7090708@oti.com_...
> executable.
Tried 1.4 yesterday. Still the same. See other response for more details on
what else I tried.
Ralph
> > Ralph
Re: New Folder, File [message #198473 is a reply to message #198154] Fri, 20 February 2004 09:52 Go to previous messageGo to next message
The minimum display resolution for Eclipse 2.1.2 is 1024x768 (see the
eclipse/readme/readme_eclipse.html under Platform UI). Also note that Win98
is not a supported platform and there are known problems with running out of
OS resources (Win98 has very few GDI resources available to apps).
I'm still puzzled about the disappearing controls though.
Nick
news:c13svg$hc3$1@eclipse.org...
User
problem
> If
> Eclipse
> > Nick
side
tops
The
by
So
I
> Ralph
> it's
the
> > > > Nick
> > > Ralph
98
> > > with
> > > > > JDK1.3.
> > Folder"
> > > > and
> window
> > > has
> > > > a
> > "Folder
the
> > > file
advance.
> > > > > Ralph
Re: New Folder, File [message #199085 is a reply to message #198473] Sat, 21 February 2004 19:15 Go to previous messageGo to next message
news:c156ps$q8$1@eclipse.org...
Win98
of
I think one panel is partly covered by another panel. Does any earlier
version of Eclipse work with 800by600?
Ralph
> Nick
> User
> problem
time?
> > If
> > Eclipse
> > > Nick
> side
to
> tops
> The
The
800
> by
> So
so
> I
> > Ralph
message
> > it's
> the
> > > > > Nick
> > > > Ralph
Windows
> 98
> > > > with
> > > > > > JDK1.3.
> > > Folder"
> > > > > and
> > window
> > > > has
> > > > > a
> > > "Folder
> the
> > > > file
> advance.
> > > > > > Ralph
Re: New Folder, File [message #200891 is a reply to message #199085] Tue, 24 February 2004 10:53 Go to previous message
Eclipse 2.0 was spec'ed to work at 800x600.
news:c18s3n$obn$1@eclipse.org...
> Win98
out
> of
> Ralph
> > Nick
or
> > User
> > problem
> time?
> > > If
> > > Eclipse
> > > > Nick
> > side
like
> to
> > tops
it.
> > The
> The
> 800
> > by
off.
> > So
> so
> > I
> > > Ralph
> message
like
> > > it's
in
> > the
> > > > > > Nick
> > > > > Ralph
> Windows
> > 98
> > > > > with
> > > > > > > JDK1.3.
"New
> > > > Folder"
> > > > > > and
Folder"
> > > window
> > > > > has
> > > > > > a
the
> > > > "Folder
in
> > the
> > > > > file
> > advance.
> > > > > > > Ralph
Previous Topic:Incremental Compiler bug when accessing a protected attribute?
Next Topic:[Bug?] Eclipse Unable to nest output folders
Current Time: Tue Jul 22 14:01:24 EDT 2025
Powered by FUDForum. Page generated in 0.09909 seconds
