Home » Modeling » GMF (Graphical Modeling Framework) » How to Rename a Diagram
How to Rename a Diagram [message #195592] Thu, 03 July 2008 06:52 Go to next message
Originally posted by: youchy.gmail.com
Hi everybody,
I want to have an Action to Rename the diagram, so rename the files, and
all content inside the files that references to the old Nam.
How can I do this?? I think make my parser is a bad solution, and I'm sure
this is implemented, or not?
Thanks everyone!
Re: How to Rename a Diagram [message #195639 is a reply to message #195592] Thu, 03 July 2008 08:14 Go to previous messageGo to next message
Hello Carlos,
Eacy way is: load all "cross-referenced" EMF resources into the single ResourceSet,
change name for the Resource you'd like to rename and save all the resoruces.
Alex Shatalin
Re: How to Rename a Diagram [message #196174 is a reply to message #195639] Wed, 09 July 2008 03:54 Go to previous messageGo to next message
Hi Alex,
I don't understand what is a Cross Reference. Can you show me a little bit
of code, doing what you say??
Re: How to Rename a Diagram [message #196219 is a reply to message #196174] Wed, 09 July 2008 05:26 Go to previous messageGo to next message
Hello Carlos,
ResourceSet rs = new ResourceSetImpl();
Resource resource1 = rs.getResource(model1URI, true);
Resource resource2 = rs.getResource(model2URI, true);
.... <all the resources with possible references>
resource1.serURI(newModel1URI);
resource1.save(..);
resource2.save(..);
By "cross references" i meant references between EObjects stored in different
resources. For example, elements of .diagram file are keeping references
to the elements of .domain file (resource).
Alex Shatalin
Re: How to Rename a Diagram [message #196267 is a reply to message #196219] Wed, 09 July 2008 06:32 Go to previous messageGo to next message
yes, thats make me another Pair of Files .diagram and .model, but for
example:
if I have the diagram A (i've the Pair [.mode, .driagram]
now I want to Rename this diagram to B.
I must rename the files .mode .diagram , but I must rename the references
that are in the .diagram to the .model...
your code makes the first step, rename the files, but I can't fins how to
rename the refernces inside the file.
can you Understand Me??
Re: How to Rename a Diagram [message #196282 is a reply to message #196267] Wed, 09 July 2008 06:53 Go to previous messageGo to next message
Hello Carlos,
Then you change URI for one of the resources and then save both you should
get all references updated in the second resource by EMF...
Alex Shatalin
Re: How to Rename a Diagram [message #196299 is a reply to message #196282] Wed, 09 July 2008 07:15 Go to previous messageGo to next message
hi alex,
It's true sorry, the references are modified, but the name of the diagram
is not correct, i must set it' manually?? creating a transactional command
or with a SetValueCommand??
Re: How to Rename a Diagram [message #196305 is a reply to message #196299] Wed, 09 July 2008 07:29 Go to previous messageGo to next message
Hello Carlos,
> diagram is not correct, i must set it' manually?? creating a
> transactional command or with a SetValueCommand??
Yes. In case of loading all the resources into ResourceSetImpl (without any
EditingDomain associated) you can just call .setName() for the diagram instance
before saving models.
Alex Shatalin
Re: How to Rename a Diagram [message #506595 is a reply to message #196282] Fri, 08 January 2010 04:27 Go to previous messageGo to next message
unfortunately, this didn't work for me. I'm having a .diagram and a
..model file and I want to rename the .model (that is referenced by the
diagram for some graphic elements). So this is what I did:
Resource diag_res = rs.getResource( diagramURI, true);
Resource res = rs.getResource( modelURI, true);
res.setURI(newModelURI);
diag_res.save( ShmDiagramEditorUtil.getSaveOptions());
Unfortunately, this creates me just a copy of the model file in
newModelURI but doesn't adjust the references from my diagram-File to
the new model file.
Any ideas what I'm doing now? Maybe the problem is that we're using our
own URI-Handler?
For now, I'm working around this by doing a string-replace of
href="oldModel.shm#" to href="newModel.shm#". But I consider this very
ugly :-(
Johannes
Alex Shatalin wrote:
> Hello Carlos,
> should get all references updated in the second resource by EMF...
> Alex Shatalin
Re: How to Rename a Diagram [message #506606 is a reply to message #506595] Fri, 08 January 2010 00:14 Go to previous messageGo to next message
Am 08.01.2010, 10:27 Uhr, schrieb Johannes Michler <orgler@gmail.com>:
> .model file and I want to rename the .model (that is referenced by the=
> ResourceSet rs =3D new ResourceSetImpl();
> Resource diag_res =3D rs.getResource( diagramURI, true);
> Resource res =3D rs.getResource( modelURI, true);
> the new model file.
> Any ideas what I'm doing now? Maybe the problem is that we're using ou=
r
> own URI-Handler?
> href=3D"oldModel.shm#" to href=3D"newModel.shm#". But I consider this =
very
> ugly :-(
> Best regards,
> Johannes
>> Hello Carlos,
>> Alex Shatalin
Erstellt mit Operas revolution=E4rem E-Mail-Modul: http://www.opera.com/=
mail/
Re: How to Rename a Diagram [message #506609 is a reply to message #506595] Fri, 08 January 2010 05:23 Go to previous message
Hi Johannes,
you need to replace the references the diagram references items from old
model elements to the corresponding new one.
URI diagramUri = ...;
URI newModelUri = ...;
URI oldModelUri = ...;
Resource diagRes = rs.getResource(diagramUri, true);
Resource newModelRes = rs.getResource(newModelUri, true);
Resource oldModelRes = rs.getResource(oldModelUri, true);
Diagram diagram = null;
EList<EObject> contents = diagRes.getContents();
for (Iterator<EObject> iterator = contents.iterator(); diagram == null
&& iterator.hasNext();) {
EObject eObject = iterator.next();
if (eObject instanceof Diagram) {
diagram = (Diagram) eObject;
for(TreeIterator<EObject> it = EcoreUtil.getAllContents(diagram, true);
it.hasNext();) {
EObject next = it.next();
if (next instanceof View) {
View view = (View) next;
EObject oldElement = view.getElement();
EObject newElement =
newModelRes.getEObject(oldModelRes.getURIFragment(oldElement ));
view.setElement(newElement);
> the new model file.
> own URI-Handler?
> ugly :-(
> Best regards,
> Johannes
>> Hello Carlos,
>> Alex Shatalin
Previous Topic:Avoid obstructions only works for toplevel elements
Next Topic:Refresh command on diagram modification
Current Time: Sun Jul 27 04:03:34 EDT 2025
Powered by FUDForum. Page generated in 0.12500 seconds
