Home » Eclipse Projects » GEF » zooming support endless loop
zooming support endless loop [message #70371] |
Fri, 14 March 2003 09:15  |
Originally posted by: Raymond_Tsui.ca.ibm.co
Randy Can you look at the attached stack trace?
I'm trying to add zoom support and followed the logic example to add a free
form editpart to do so. It works great some of the time but other times, the
code gets into an endless loop after a change in zoom. I suspended the
program in the middle of one of these loops. Can you look at the stack trace
and see if that looks about right?
How would you diagnose this problem?
Ray
Re: zooming support endless loop [message #70414 is a reply to message #70371] |
Fri, 14 March 2003 10:25   |
Do you have a FlowLayout set as the Layout for a Freeform layer? This
doesn't work, only FreeformXYLayout works. The reason is that a freeform
figure can extend in all directions, as needed by the location of its
children. So, the top-left corner of a freeform figure is a function of the
location of the children. But, with flowlayout, the locations of the
children are a function of the top-left corner of the container (the
freeform layer).
Do you currently allow the user to drag things into negative x or y
coordinates? Or, does you automatic layout ever place things in negative x
coordinates (for really large flows, perhaps). If not, you don't need
freeform anything.
"Ray Tsui" <Raymond_Tsui@ca.ibm.co> wrote in message
news:b4so8a$h37$1@rogue.oti.com...
free
the
trace
> Ray
Re: zooming support endless loop [message #70564 is a reply to message #70414] |
Fri, 14 March 2003 12:40   |
Ahh, that could explain things. We *are* using FlowLayouts in the parent
part that has a FreeformLayer as its figure. But I'm not sure what to do
now.
I tried changing the figure to a regular Layer but then all the children
objects disappear. Why does it work in the case of a FreeformLayout and not
a regular Layout?
Ray
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b4sscm$l4m$1@rogue.oti.com...
the
> freeform layer).
x
> freeform anything.
> free
> the
> trace
> > Ray
Re: zooming support endless loop [message #70582 is a reply to message #70564] |
Fri, 14 March 2003 12:42   |
Typos...the last sentence should read this way
Why does it work in the case of a FreeformLayer and not
a regular Layer?
news:b4t487$sb9$1@rogue.oti.com...
> now.
not
> a regular Layout?
> Thanks
> Ray
freeform
> the
> > freeform layer).
negative
> x
> > freeform anything.
Re: zooming support endless loop [message #70632 is a reply to message #70582] |
Fri, 14 March 2003 15:57   |
If you look at the difference between XYLayout and FreeformXYLayout, you
will get an idea.
Basically, you want a FlowLayout which, instead of position children
relative to its getClientArea().getLocation(), you position them relative to
0,0, all the time.
But then this begs the question, why use Freeform at all? It sounds like
you are just using it for its Zoom support.
news:b4t4db$sha$1@rogue.oti.com...
> a regular Layer?
> > now.
> not
> > a regular Layout?
> > Thanks
> > Ray
> freeform
of
> > the
> > > freeform layer).
> negative
> > x
> > > freeform anything.
Re: zooming support endless loop [message #70648 is a reply to message #70632] |
Fri, 14 March 2003 16:19   |
Zooming support is the whole reason I got into this mess in the first place
:-) We do need zooming support.
The way I added zooming support is to set the root edit part to be
ScaleableFreeformRootEditPart as per logic example. As I said, that was
enough to cause the infinite loops in our otherwise well behaved editor.
So if I can extropolate, I should then modify/subclass FlowLayout to force
the position of them to relative to 0,0????? That would be enough to solve
the problem? Please say yes :)
Ray
news:b4tfq7$65t$1@rogue.oti.com...
> will get an idea.
to
> 0,0, all the time.
> > a regular Layer?
parent
do
> > > now.
children
and
> > not
> > > a regular Layout?
> > > Thanks
> > > Ray
This
> > freeform
its
function
> of
> > > the
the
> > > > freeform layer).
> > negative
> > > x
need
> > > > freeform anything.
Re: zooming support endless loop [message #196189 is a reply to message #70414] |
Fri, 16 September 2005 15:52   |
> freeform layer).
I now have a similar problem. I am using FreeformLayout in a
FreeformLayer and the system goes into an endless loop when I try to
zoom. I believe since the previous post FreeformLayout has replaced
FreeformXYLayout, but I could be wrong.
By not setting the layout manager, I avoid this problem, but of course,
nothing is positioned properly within the diagram. I have tried also
using XYLayout, but I fall into the same endless loop.
Any thoughts?
Nick
Re: zooming support endless loop [message #196256 is a reply to message #196241] |
Fri, 16 September 2005 21:18  |
> I have found that it infinitely loops in the for loop of the
> DeferredUpdateManager.validateFigures() method.
It appears that it was caused by a buggy Locator that I had implemented.
I have found that RelativeLocator with the proper constant provides
the same function, so I have switched to using that.
Current Time: Sat Sep 13 19:29:21 EDT 2025
Powered by FUDForum. Page generated in 0.05207 seconds
