| Combining two domain models into one application [message #195837] |
Sat, 05 July 2008 12:25  |
Originally posted by: milan.milanovic.org
I have one domain model for which I've done GMF-based application. Now, I
need to create another GMF application which will use some of the domain
model elements from the first application, where those elements should be
edited in the first application (when called from the second, of course).
But, also those domain model elements of the first application should be
possible to create in the second application.
I hope that it is not too complicated to explain. Just like that the first
application is UML Class diagram editor, and the second is UML Activity
diagram editor, where the Activity diagram editor use classes defined in
the UML Class diagram editor.
How can I do this with GMF ? Any tutorial on this ?
Thank you in advance, Milan Milanovic
FUDForum. Page generated in 0.05236 seconds
