Home » Language IDEs » ServerTools (WTP) » why am I recieving HTTP ERROR: 404
why am I recieving HTTP ERROR: 404 [message #195750] Thu, 05 July 2007 17:25 Go to next message
Originally posted by: tauberg.013.net
hi,
I am creating a simple dynamic web project,
and for some reason, when i starts the server
& try to access by url a simple servelet, I receive an http 404 error. (at
any browser)
(this error means that the server is accessible, but the specific resource
at the server is not accessible).
this happens when i use tomcat sever and when i use "J2ee preview server" or
any other.
my web.xml:
<web-app id="WebApp_ID" version="2.4"
xmlns="http://java.sun.com/xml/ns/j2ee"
xsi:schemaLocation="http://java.sun.com/xml/ns/j2ee
http://java.sun.com/xml/ns/j2ee/web-app_2_4.xsd">
<display-name>
w</display-name>
<servlet>
<description>
</description>
<display-name>
E</display-name>
<servlet-name>E</servlet-name>
<servlet-class>
e.E</servlet-class>
</servlet>
<servlet-mapping>
<url-pattern>/E</url-pattern>
</servlet-mapping>
<welcome-file-list>
<welcome-file>index.html</welcome-file>
<welcome-file>index.htm</welcome-file>
<welcome-file>index.jsp</welcome-file>
<welcome-file>default.html</welcome-file>
<welcome-file>default.htm</welcome-file>
<welcome-file>default.jsp</welcome-file>
</welcome-file-list>
</web-app>
my servlet :
package e;
import java.io.IOException;
import javax.servlet.ServletException;
import javax.servlet.http.HttpServletRequest;
import javax.servlet.http.HttpServletResponse;
* Servlet implementation class for Servlet: E
public class E extends javax.servlet.http.HttpServlet implements
javax.servlet.Servlet {
static final long serialVersionUID = 1L;
/* (non-Java-doc)
* @see javax.servlet.http.HttpServlet#HttpServlet()
public E() {
super();
/* (non-Java-doc)
* @see javax.servlet.http.HttpServlet#doGet(HttpServletRequest
request, HttpServletResponse response)
protected void doGet(HttpServletRequest request, HttpServletResponse
response) throws ServletException, IOException {
// TODO Auto-generated method stub
response.getWriter().write("<html><head><head><body></body ></html>");
/* (non-Java-doc)
* @see javax.servlet.http.HttpServlet#doPost(HttpServletRequest
protected void doPost(HttpServletRequest request,
HttpServletResponse response) throws ServletException, IOException {
  • Attachment: 1.jpg
    (Size: 85.38KB, Downloaded 334 times)
  • Attachment: 2.jpg
    (Size: 44.35KB, Downloaded 335 times)
  • Attachment: 3.jpg
    (Size: 30.36KB, Downloaded 337 times)
  • Attachment: 4.jpg
    (Size: 65.10KB, Downloaded 323 times)
Re: why am I recieving HTTP ERROR: 404 [message #195763 is a reply to message #195750] Thu, 05 July 2007 17:43 Go to previous messageGo to next message
I may add, that it also happens with jsp files.
& I have a jre1.6.
& it happens also when i set the project facet to java6.
& i done this and it still happens:
at a new computer i download&install jre1.6
i download&install eclipse
i download&install wtp
i created a dynamic web project using the wizard
& stiil getting this 404 error.
my project is attached
"david" <tauberg@013.net>
  • Attachment: f.rar
    (Size: 5.34KB, Downloaded 303 times)
Re: why am I recieving HTTP ERROR: 404 [message #195787 is a reply to message #195763] Fri, 06 July 2007 08:59 Go to previous messageGo to next message
I tried your files using a new workspace with Tomcat 5.5 and the J2EE
Preview server and everything worked as expected. It's not clear what
is different about your workspace that is causing this behavior. Is
there anything in the console log that might give a clue?
Larry
> & I have a jre1.6.
> "david" <tauberg@013.net> ëúá áäåãòä:f6jnpv$8u0$1@build.eclipse.org...
>> hi,
>> any browser)
>> or
>> any other.
>> my web.xml:
>> <?xml version="1.0" encoding="UTF-8"?>
>> <display-name>
>> w</display-name>
>> <servlet>
>> <description>
>> </description>
>> <display-name>
>> E</display-name>
>> <servlet-class>
>> e.E</servlet-class>
>> </servlet>
>> <servlet-mapping>
>> </servlet-mapping>
>> <welcome-file-list>
>> </web-app>
>> my servlet :
>> package e;
>> /* (non-Java-doc)
>> public E() {
>> super();
>> /* (non-Java-doc)
>> HttpServletResponse
>> /* (non-Java-doc)
Re: why am I recieving HTTP ERROR: 404 [message #195828 is a reply to message #195787] Sat, 07 July 2007 06:12 Go to previous message
hi thank you!
you have also answered me at the :
http://www.nabble.com/Why-does-i-receive-ah-http-404-error-t f3896399.html
i slove this like that:
i downloaded eclipse for jee developers from :
http://www.eclipse.org/downloads/
& run the project.
& now it works!
"Larry Isaacs" <Larry.Isaacs@sas.com> ???
??????:f6lebj$gvf$1@build.eclipse.org...
>Preview server and everything worked as expected. It's not clear what is
>different about your workspace that is causing this behavior. Is there
> Cheers,
> Larry
>> & I have a jre1.6.
Previous Topic:WTP 3.0 Requirements: Call for participation..
Next Topic:Extract to resource bundle
Current Time: Sat Jul 26 20:06:08 EDT 2025
Powered by FUDForum. Page generated in 0.04769 seconds
