Cannot delete connection when specified field in the property is filled in with content [message #195656] |
Thu, 03 July 2008 09:03  |
Originally posted by: nhaphuong.web.de
--------------030002020809060109050703
I want to develope something like an Entity Relation Model with GMF. My
nodes should represent the tables and the compartment in the nodes the
attributes of the table.
Ok, I have two nodes (table A und table B). Table A references to table
B. It's the concept of primary und foreign key. To decribe this
relationship graphically I draw a connection between the nodes.
In the property view of the relation, the source and target are correctly.
Source is Table A
Target is Table B
Now I also want to reference to the attributes of the table. For better
understanding you can look at the attach.
If the property of FK Reference and PK Reference are filled, I cannot
delete the connection. If these fields are empty I can delete the
connection.
I looked at the error log and the message is an execute error.
I google this error and in the news they say that this error message has
something to do with OCL constraint. But I can't bring my case with the
case in the newsgroup together.
I hope anybody can help me. Thanks.
Regards Phuong
Here the detail log:
org.eclipse.core.commands.ExecutionException: While executing the
operation, an exception occurred
at
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:519)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:193)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:168)
at
org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.exe cute(DiagramAction.java:141)
at
org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.doR un(DiagramAction.java:103)
at
org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandl er.run(AbstractActionHandler.java:359)
at
org.eclipse.gmf.runtime.common.ui.action.ActionManager$1.run (ActionManager.java:225)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.gmf.runtime.common.ui.action.ActionManager.run(A ctionManager.java:223)
at
org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandl er.runWithEvent(AbstractActionHandler.java:377)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Caused by: java.lang.ClassCastException: java.lang.Boolean cannot be
cast to org.eclipse.emf.ecore.EObject
at
org.eclipse.emf.ecore.util.ECrossReferenceAdapter.handleCros sReference(ECrossReferenceAdapter.java:608)
at
org.eclipse.emf.ecore.util.ECrossReferenceAdapter.selfAdapt( ECrossReferenceAdapter.java:447)
at
org.eclipse.gmf.runtime.emf.core.util.CrossReferenceAdapter. selfAdapt(CrossReferenceAdapter.java:92)
at
org.eclipse.emf.ecore.util.ECrossReferenceAdapter.notifyChan ged(ECrossReferenceAdapter.java:425)
at
org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify (BasicNotifierImpl.java:247)
at
org.eclipse.emf.ecore.util.EObjectEList$Unsettable.unset(EOb jectEList.java:59)
at
org.eclipse.erm.schema.impl.RelationImpl.unsetFK_Reference(R elationImpl.java:369)
at org.eclipse.erm.schema.impl.RelationImpl.eUnset(RelationImpl .java:472)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eUnset(BasicEObj ectImpl.java:1143)
at
org.eclipse.gmf.runtime.emf.type.core.commands.DestroyElemen tCommand.tearDownOutgoingReferences(DestroyElementCommand.ja va:191)
at
org.eclipse.gmf.runtime.emf.type.core.commands.DestroyElemen tCommand.doExecuteWithResult(DestroyElementCommand.java:124)
at
org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTr ansactionalCommand.doExecute(AbstractTransactionalCommand.ja va:246)
at
org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:137)
at
org.eclipse.gmf.runtime.common.core.command.CompositeCommand .doExecuteWithResult(CompositeCommand.java:403)
at
org.eclipse.gmf.runtime.common.core.command.AbstractCommand. execute(AbstractCommand.java:134)
at
org.eclipse.emf.workspace.CompositeEMFOperation.doExecute(Co mpositeEMFOperation.java:212)
at
at
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:511)
... 37 more
Content-Type: image/gif;
name="ERM.GIF"
Content-Disposition: inline;
filename="ERM.GIF"
R0lGODlhcwE5AfcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/ AP//AAAA//8A
/wD//////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMwAAZgAAmQAAzAAA/wAz AAAzMwAzZgAz
mQAzzAAz/wBmAABmMwBmZgBmmQBmzABm/wCZAACZMwCZZgCZmQCZzACZ/wDM AADMMwDMZgDM
mQDMzADM/wD/AAD/MwD/ZgD/mQD/zAD//zMAADMAMzMAZjMAmTMAzDMA/zMz ADMzMzMzZjMz
mTMzzDMz/zNmADNmMzNmZjNmmTNmzDNm/zOZADOZMzOZZjOZmTOZzDOZ/zPM ADPMMzPMZjPM
mTPMzDPM/zP/ADP/MzP/ZjP/mTP/zDP//2YAAGYAM2YAZmYAmWYAzGYA/2Yz AGYzM2YzZmYz
mWYzzGYz/2ZmAGZmM2ZmZmZmmWZmzGZm/2aZAGaZM2aZZmaZmWaZzGaZ/2bM AGbMM2bMZmbM
mWbMzGbM/2b/AGb/M2b/Zmb/mWb/zGb//5kAAJkAM5kAZpkAmZkAzJkA/5kz AJkzM5kzZpkz
mZkzzJkz/5lmAJlmM5lmZplmmZlmzJlm/5mZAJmZM5mZZpmZmZmZzJmZ/5nM AJnMM5nMZpnM
mZnMzJnM/5n/AJn/M5n/Zpn/mZn/zJn//8wAAMwAM8wAZswAmcwAzMwA/8wz AMwzM8wzZswz
mcwzzMwz/8xmAMxmM8xmZsxmmcxmzMxm/8yZAMyZM8yZZsyZmcyZzMyZ/8zM AMzMM8zMZszM
mczMzMzM/8z/AMz/M8z/Zsz/mcz/zMz///8AAP8AM/8AZv8Amf8AzP8A//8z AP8zM/8zZv8z
mf8zzP8z//9mAP9mM/9mZv9mmf9mzP9m//+ZAP+ZM/+ZZv+Zmf+ZzP+Z///M AP/MM//MZv/M
mf/MzP/M////AP//M///Zv//mf//zP///yH5BAEAABAALAAAAABzATkBAAj/ AP8JHEiwoMGD
CBMqXMiwocOHECNKnEixosWLGDNq3Mixo8ePIEOKHEmypMmTKFOqXMmypcuX MGPKnEmzps2b
OHPq3Mmzp8+fQIMKHUq0qNGjSJMqXcq0qdOnUKNKnUq1qtWrWLNq3cq1q9ev YMOKHUu2rNmz
aNOqXcu2rdu3cOPKnUu3rt27ePPCpEYtVd+/fgMDHiy4MOHDhhMjXqy48WK9 JPk6nsy4MuXL
ljMLpuaQc9hUkEd6/jp6IeiwpUN7PP2VtWmNYDCiMDjbpGvVHVNXjH2xNkHf I28nFD6R2iLd
A1EoXw48OW2HzYvjBklconHkApkvPxg9Om3mFasb/8Qe8YyfMwy9Oy+onv2/ 9g7FT7dIHqJ5
9Avhd0//m2J9gvI5ZIsfA9qSH3vKZfdegu9lt91z8DX033wTBdhQgQQe+BuD sz1YG3jurSeR
hQKROJx5sKQCy3niqdehbx02KKJzETJkIoUPTahQKiiqyGJCLi5Io4wK9jcj RCbeaJAZixDI
FzUDLmIGQkECF6OVIRIpHY4VpaZkQUw6yVeUU3JHpZZXGpkciBV2ZhGPfqS4 4hktIpggli+y
WaSWXKL0l4429jhnnRve2V+eD85YI0KAfnkQhgYqhKWCePJpJ4MU6dlnjpxp GhGkGu4Z45D6
qRlRkhndx5+Io1KKpqmWPv8EXiqB0dqXrbTWquutu+bK66++BovrsL0SC6yx whar7LHLJsvs
s6B5Wt55q4r6aqt8TjpifBldV62Dd4L4YaJ7lhuRtJtCR25xx327YLgegtsd ug2ZCChDvBVF
b7oH+dXpuhPlO1Sj/M7F11moflYwfQrXq9nDmEUM8cSKLRwexRhLrHHGiLnZ sMXWocatyCBv
C1bCJ5cccsr1arSoTveqXKLLRtkbaqzYStrQy/u1KXOON3uXM5CS7mvu0RKO TPSRsC6t86Iv
J/2z0mcybbWZTsfadHhUvyvvu2leyeGhHpKLLYzwip2nvOo5WnJqZafdYNhj 0xj3h0aijejc
Qt7/7R3KIWo7NqZnW8vqq9mu6bWDW/8Ts8zV4c0q3oQjDuOheZuLNriKW20z 1oIPKXqRl69X
OqylYyrk1W6DjJ3khvM9uoynz+1pc6errvtBBBcKO5GXV2r6muJaXTnpVmpb 0OMq31b84a7O
Drt2hSMI/eqMe0516moGj/nwSGu3dOrJN976TUZrDXP35eZ+beZHKw8/8OVr 3zL0oUevf93v
z0+66fXD3vKUIr9CCcU13Lte4TYHvO/9b34MzJ4AB/I54kXQUJRi03YY+Dzw mW1Uu9sgQs5X
kwJm6SdwSxThWoUovdHva2AjX/kiaLuhOa5rVFEP83BiwsbphIRD+RsO/59C LyDOpIdXW18O
ATaz+4Flh+jzIdJ2YsSkVLA1BJSi+nICxab07olZBB/igFJFpADOK2WMiQYB yEQufuw1JJua
jd6okC42JY1csuNSvkgaOToRjZ1pFrIGKchCQouQhzQkHnGUyEY665GIhKQi I4ksPfrxkpjM
pCY3yclOevKToAylKEdJylKa8pSoTKUqV8nKVrrylbCMpSxnScta2vKWuMyl LnfJy1768pfA
DKYwh0nMYhrzmMhMpjKXycxmOvOZ0IymNKdJzWpa85rYzKY2t8nNbnrzm+AM pzjHyZNp3NCc
nEHnP9TJznO6M53vXGc82wnPesrTnvS8pz7zyf/PefoTn//cZ0D7CdCCCtSg BD2oQhPK0IE6
FKEPXWhEGwpRfD5pGhc9GGc2ekOOerSjIP2oSENK0pGatKQoPalKU8rSlbq0 pTB9qUxjStOZ
2rSmOL2pTnMKUkbpk6PqBCpJgxpPoX6UqPY0KkiR+tOiOjWpT20qVKcq1aoy 9apDzepRtbpU
rir1q1HF6lbH2lWygpWqYi2rWs+60SddlKc7jStc5yrXutL1rnbNK173qte+ 0pUv+HgSPigq
0YoW9rCETexEF2tYxTaWsYiFrGMj+9jKUvayk2XoRjHaF87y9bN+DS1oRyva 0pL2tKZNbUr9
wRc/+CWwaw2rV2VrVtr/xhats8VtbXV7W6vm1re7BW5v03pW4RaXuLY97m+R q9u2UmMaqXCt
aqeL2upS97rWzS52t9tSwLrWtZmVrHgtG17yjhez5y0ves3L3vW6V73wPedm JeNagXD3vtrN
L373q9/+8nejrMVHfZNLYN4qN7jMNW6BFWzgBSf4wcuNMIIlPFwKH7jCE96t c/siEKb+178g
/rCIQ0ziEXsUsBsdbHpX3N74tpjF74Wxi2P84hrT+MaJnS9fPGviEvu4x0D+ sZBLy1q+BDjD
GE7yhZfsYAs3GclMbrCUGUxlCEP5yUrG8oGp8d3oetkPQw5zkMcs5jKTmaNT 8EOa16xmMJPz
/81wFkqX5/zlOtP5znbOM573rOc+8/nPfg40oAct6EIT+tCGTjSiF63oRjP6 0Y6O9HdRTGlq
BLbSl7a0YDeNaU5rutOg/rSoM01qT5c61KcetalXjWpWq7rVsH61rFNNa1fX Ota3nrWtd41r
Xuu616jm7HMzumNiD7vYyD62soXNbGM3O9nPXrazpw1taku72ti+trajzW1r dzvb3962t8cN
bnKLu9zoPre6w81uah+5yNR495PkbWRNw5ve8bb3vPVd78Dem9/59ve+Bd7v fBf83wQPuMEV
jvCF4/vhAId4wiXu8IhbfOIXrzjGN67xjjf84wP3eMhBfvCRm7zkKP9n+MAh zXJJu7zlMH+5
zGNO85nbvOY4v/nL611peGfa5/vuuaeBznNR+0O6Px+60oXOdKMv3elNTzqX F0kTLzcj6kGH
utalvvWsc/3rffED0RcO9qKXnexeT7tk2p1utq+by29vu7ndTvcngXmj28C7 3h2Xd77vnRp9
B/zfA0/4wRve74gXfOId52W/1F3ukI+7tP0g+cdX3t0nV3nKKU5yhlNe86Dn fOZFv/mMFxnM
1bhh6jmz+n+0/vWqjz3rZe962sN+9rivfe5vr/vap/4f0XUr6UNv+tEXH+Vi Pz7xOd754Svb
rcKGvluNLf3pP5/6cMdoKJax/e4vw/rRx37/sqs//fCPX/zXb63fqyF49ufd /dSAv/zbT//3
1z/+95+//fePf/7rv/8A+A+UZ37pV4AEeIDWZ4AJiICfh34ICH4LGIEQOIG5 VoG+ZoGvRQ3L
YBDM8H0WCGy/FoK3RivVUHiJZ4KKl4IouIKHp4ItyIInyFGu5S8fqGvvEArM wAz3IIIXuGoZ
iGKGwAViwAVEOIRFyAWGwIMgSGuW14TklgrCFgoD4RnT0IGR54RXaGy2wn58 8Qda8Ad+AIZ/
8AeFQIZ/4C/4xxdcmIZsuIZu+CRvqIZwOIdyWIdtSId3yH62koXI9g7L4A87 iApzN4jQ5i/C
dgNe+AdUkIiL+IU3/0CIl4dshmAI7Nd8yjd89JZ8gbWBArEFHXYPVoiJlziK zOdWd/d+qfB+
qlANsEANquCK1FAI/pd/tDiLtgiA//d/bdZ/azaLUFh6pVgPzOAPWwCIzGB8 pQiM8fZ5RyYG
f7ANqbcN0vgP0ugHYkCKIgeMrrcFraiAE1h+CYgCElh+aEgNUkgNnlh7AhEK 40h+1SeODtiO
8biH8QcLY5gKZ1gIqqCPqaAKW9iNbgiQcCiQakiQ9WiHrIiQBpmQ8TcFAjEF reiQ/zAFB8mG
9OiO4ueHxOgP03AP7PiA4PiNfCGO5veLbrUFfzAav+d6f7AFIfmSGHl+JOlW ArENLul0y/+h
dmhXdPC4k2THjNRwCp3IgV7HHE93aSgwdkoJj/gAj0rJaXfHftXAGsiRClIZ f0Z5lVqJf1vZ
lVgplSjglWKJf24mgBI5kWO5h08pdPXwh/0AiP0AD/Ugasxxdk8pjlLnB0nH Bc/4B4aAklQw
EH/ABWhnlF1ndvuGl/O2BYbwD1vQbTOZhZF5biZpjv9wA45jCDfgkv9wCteG ApwFmt4Gj2wn
mpG3h68IC6rQjdTQiq7JF6qQmq6IAq2oCrQJi7XZmri5m7LZm7fZm7oJnLk5 nGc5EBQpnLB4
K4MoCswQCqhwD/3QkcvwDsxGmpAobD3JbIb4JIjIe9XwB4+IbKb/GYnKlp18 UQiNWYwWJ47+
sBysxZ7UwJ7uOZI52Z7KEWA5GXDJxxeoMJQ1KRDSoHFJ+SR4mZ/2mZTwWJ/i OKD5uRxN+Z7K
YWlGeWRcxopSWQhTeBCFoJVhCQvVEJYgyoo5+aEjGp/K4aEhuhwfyn7L4aEm Ko4WypX1WJZo
6aJaaaN9cXXLF2+C+CTPGZdz+W5OqWn1+aIj2Z6BlZPMcW96uXB8uQ1+OYaA +Q+DmZgV16BF
mpNNGaHxKaERGgPsd5PkZ54LSqDTV6Yj2aUYhabPt53nuAXVYAgxAKfKAArU Z51syqbxGX0L
2pMEOg09uaCh2aXP5aeo6YoqwpvB2Y+w/2ibr+ioEeqosympkPqoKGCb4kip l3qpk8qpj9qo
oFqcU/CppAqqyimS1CAK1OAMgMGc1BmOXEqafrqnsVpsgXps5YhRW7Chvbd6 heCS2ElsgQqo
Zjqet5qnmCmmqZagWrqgSKmkxUqkhDpqnxdYp5B6nhiN/wAK24ppTNml2tGl SJmkSpppdcmU
zjqSTQlY31qhuYmh9qWhu8kcr5ipXVqvXdqKfQqt+qqb+xqhJ6qouVmcAhEn Arubp0prqMAM
PfoXofAOv4YCW4qlyrGuEopiiqmYXFZqKAmNvld7LUmXnCax6oquJmqmafqv KGAD3AgLkDmt
CUqsMKum4Bqtz/9WmX3gsTCwDaBADD3rD/5gp+IZrJOZnYI6kjKbtEdLqzu2 tONJK7WpmoWg
Iq9ItX0htatpqY+qmpfKtVm7qVrbtVo7qZ2ata7ItbS5tVt7llPAtmb7tqp5 timChs/2DtLg
D+yYK6LAbktbqE27p0iLstMKXckWA2V4uGZ4uDGQUZOptID7uAA7bGUamQIR C7AAcmWapGaq
uSmbb5lbs5l4ZKiwDbUHCv7wlqjbD6BAcAP6oF36ntOKpAMan0gab04psbOL oP62oPgJbxX6
qX8wELBwECn5qfaKr8hbs/hqr2WavM17r2RbqqrgZsdJvaAqvclpkvJWD28p EKqaCs7/EAqc
x7sS2p5GhrtF1roz629AGVh/uQXwG7/ym4SsK6Tn67q0K63wObmeawis+XzL EZo5uaZuZZgG
zKWAyqU7Vo59wHfVAArQCZ3T0A/2ILRNm5+FqsDQ+qJ6esAyO8C3Omy0krUp IoZfeMIm/Aer
SbVimyIt3KKYeqIqAsMoQLWwoBy2OcMnGsMkvMKqCQttC5FUG8Q+3MNyQsJz a33vYA/+MBB4
mwp9IIFGuaYavMFUXKYE/CSVKX3wCwPwq4AHnKB/m58JLMZlrJNreZg+mcYC Vm+h0AeogIOn
UAygUMcUzI5sjMZHqcdY97s/DLc9fLaBbMRq+8OZ+sdxS8iC//zHiwzIjKzI kIzIaquWfHG3
TtwPohAKdrnHiNnJBtekPCe/8lsFX7zGnGzKPYeF5PltlcltoFDBqhzL5jbC /ljL/XjLtpzL
uLzLumzLNdzLvBzMwDzMwlzMxFzL/ugHnNWRTmwP9xDFfLjKF7Wd0SzL2GaJ ybij2LyfoQcK
eIyM2ajN4NxwcKe2gnzOgIzOibzO5pzO7szO6tzO8PzO8mzO7RvOopjND9ek 2IzP2Nh53giT
8Yiq40fNAn1+CB3QManQ2EfLsdmPDx2byDzREE3REl3RGH3RGh3RHG3RHZ3R H73RHj3SEL0i
F8nQCQ2SC81ZuSqPKe3SKH1sNTjTPf/oXUtY00qY07dGeYQsyT7d00D900Id 1EQ91EZd1G9r
dTe91L8GyjqN0zQNWNYszcjWytd51dVsbbRszFx9zF391V4d1mA91sjceFR9 1oSL1lhNmTnX
1jrn1jA3z3Jdz/Fc1/Rs13ON13R913z91n4N1za3whudIoMN0oTN0YeNzIld 0obd2IX92Ijt
2JEN2Yot2ZVN2YyN2bG52Jtt2Zk92aB92aH92aJd2qR92p2t2YI92qnN2qtt 2q0N26+N2kXc
yOz8yJJs24XsyLx92729274d3MA93Lpd3JE8yLl93LiN3My93M7928ad3NLd 3NCt3NU93c8t
3NFN3dpt3XH/G2fgHd7iPd7kvRYqmaECsZLnHa/pjd7qeEPtzd7vvd7wPd8D od737d74Hd/1
vd/2zd/0HeD5Ld/+XeD6feAEjuD9reACDuADvuAJHuEQPuEN/t8WbuASXuEY TuHl7UcrSRAf
/uAgfhAhzt8jbhAl/t4nXhAp3uIk/uIoDuMsLuMrXuMifuMmjuMqruMuHuM+ PuM/buM5PuQ7
TuQ9DuRILuRFvuQp3uHpMhpQ7t5RLt9TXt9VfuVSnuVUruVWzuVYvuVg3uVh /uViXuZkfuZe
nuZjruZmzuZovuZw3uZx/uZy7uQWQ+d47uZ6Pud7Xud5zueA7ud9/ueCHuiE fuiD/57ohq7o
dr4pu2d7kP7okt6rkU7pk+6dlY7pl57pnL7pnm7poK7pod7po/7pon7qpI7q pp7qrL7qm97o
m6LqpT7rsl7rrU7rt27rro7ru67rvP7rvh7suT7svU7svUcQpGsQyV4Qy47s B9HsAwHt/6ns
z17t1H7tzG7t2Y7tzs7t0a7t3b7t4h7u5P7t3j7t427u6Y7u5c7u6t7u1Aju 7z7v7l7v8X7u
957uZ2Zm/L7v/t7vPmbv0p7v8D7wBi/vAo/wBE/vC5/w+H7wD6/wEL/uDV/x E1/wEp/xEb/x
FH/xDO/x9s5RrSfyJDXytEfyH2XyuYfyIKXyvcfyMH/yMv+/8jP/8jXv8jhf 8jqf8jvf8j0f
8zQf9DYv9DnP80bv80cP9EO/9EWP9E6v9CsZ9Q8u9fxN9e9t9Vg/9Vpf9Vt/ 9V2f9Vwf9l4v
9mA/9mZf9mj/9WpP9mt/9m2f9mwf924v93Dv9v9+9wCP93qf93dF92//934f +HM/+HVf+IBP
+Idv+IKv+Ii/+In/+I4f+Wa/95TP95V/+ZYfe6Q7e9rK+fHu+Zv/saGfep0v +rFX+qT/+aYP
+qev+qk/+rUH+6gf+60v+65P+6yf+6u/+69f+76v+70P/LjP+8Mf/MQ/+8h/ +8lv+8z/+8ev
/NBv+7Ae667JhR5a/Xxx/a1p/Qn/6aLbj/3fv/3Z3/3cD/7a7/3nX/7iH/7o T/7jb/7uz/7q
3/7wX//rn/7vf//xj//yn//0r/8AAYsarGrUBlYTSNAgwYQFDzZciPBgRIgP J1pUiNEhw4sc
M3rcKPGjyJAVQVLsSBLlSIEGp1Hz80/mTJo1bd7EmVPnTp49ff4EGlToUKJF jR5FmlTpT4P4
qKVaGlXqVKpVrV7FmlWrz5cGY24FG1bsWLJlzVr1R80p1Jqp3L6FG1fuXLp1 7d7Fm1fvXr59
/f4FHFjwYMKFDdc16NUm27ONHc+c8ljyZMiUbRpMy3gmVLWJ0zb1nNgpZtGh QZM+Te1zZ9Ss
VZduPfp1/+rVsmubdn07Nm7bsGf7iblb+OzcvnUT703b+HLlzYs7T/5cenTq wP8dx858Om/u
mLvCXPwv8Xfy4827PE+tPHr26tOvd98e/vz39eXbj5+fvstUkffrx+8/AQMk 8D4DATxwwAQL
7E88BB9UEMICV9NMJs6cWi0tDEPbkLQOX/tQQ+JEzLCzEkM0kcMRU/RwRRRf dDHGDK07UUYV
a8TxRh1bzJHHHUG00UchgeyRSA6tG5LEH5VMkkUjzfuKJs4Sy4/K76ykMj0s s6xSSy/b2zLL
K7/sEkwyxzSTvQbTLBMFNMuE8005uYyTzjm5vFNMO/fEk0+DGswzTEHP9HPL tf/Ccw0FRVGQ
rVHfHE0NhUcnTQ1S1yzFlNJLNc20UkqRZI1Rg0Q9jdRNPUX1VFU7XZVTV1Nl NdZHrZMV1ldb
rdSPVHSNcjMH3ZP0pWALlHDYBY+VENkIlyWWPEDHk1S9aMmbtllrlb02WW2Z xVbNyLrdNtv1
dpryNUnTkjRd1RZFd1HM2KVGXXfPjTfIJ+9lEl8n8+V3X39h9IdGE6P1R1R3 C8YHhc8UjlfR
Jf+1t1+AH564yYr17ZDWiCEuUmIXyRXvu2jrdbheYesdFWWSox25ZUL7hFnP mAdlM9CXqVwz
S3WtlNelneO1ueZCb6a5zpmJRpq/b5M2WmanBQU50UX/naJXUqpVTnfRn0dO ON7soOsOubC/
3m44spMDdTV123VY4Wi71trUs8fWjjq6wTa77runExhvsfP2G7uo0TMW68TU PXnkkxcfdZpq
weU2XMjFHe9ZwlF2s/F0u3Lzcck/jzx0yif31kHRSU826g3pvTrlq6s2HHYR R/a4Y44p3vji
2j3rG0SGvVbLbeATLvhd3W+3OHflbT+++bSRx3j5HQc/XOf43G245OxT9tnl oJsu+nvxhxb6
qaWvrFZroLNnWfvyn2Z6/KPfD5/8Ki2Hn/747VT9Vtm49t/b/DdAWxUQVwes FahqhUACMtCA
C4RgAyPYFI09UIISpB6zCqeg/8yh7nSgG9228PdBEoawhB404Z/Ol0IUsgdk vNpVDGE4QxnW
kIY3tGEOcbhDHfaQhz/0YRCBOMOYCNGIQzxiEpG4RCU2kYk3LOITnThFXZFr ClfEYha1uEUu
dtGLXwRjGMU4RjKW0YxnRGMa1bhGNrbRjW/sIrlgoAIqwMCOVbAjHe0IAzzO sY53zOMf+RjI
PfZRj4D0YyEJichDDjKRjBSkISO5SEc2UpKKfGQlJ5lJQ+IDk5ak5CUh+clN gpKToUTlKVVp
SlaW0pWkhOUoqaHJWNJylLe0ZS6rQC4VzNGXvQTmL4UZTGIO05jFROYxlZlM Zi7Tmc2E5jN9
OctoVv9TmtbE5jW1mU1ubtOY0/BmN8X5S3LhsY7mHOQ5YaBOdqbTneiE5zrf Kc94trOe87Qn
PfWZT37i05/3BCgMPBnQfhL0n/s8aEERalCGLtShCoWoP/3x0IRWtKH85GU4 NYpNmWzUo+ME
qTKpOcwphBSa/zCpR//xUZaOc6Qphekw5XhImv6xpoSsiQpWOsed0pEmi9Qj Sm06VKAS9ZE3
PapRkbpUpTa1qHn05FGpMQVqMDWPHfWpH1da05X+w6kw8OpTkwrWoN4UpT1V KlqBitWvWnWs
Y61qW+UqVrcyNaMh3aovt4pScgKTr8XMa0wF21JpvtSXU+iPNGXiV8Ye86// ju1mXgMrzMkC
1pmLJaw1wTlYzpaTogZdqTq7us9/mLO065xJHWfCx5ngcbRUSC1YW4tamai2 oxe16Gd1q85Z
wtMZqfitMwoa1tCm1ri7hO0uV5tc1Cr3tMtNZ2xXO12wVpcmqpVnVzsK29qy FrsRxe09Jwre
3eYWondV6U8xS8y/8lWy1e3lezErX73Cl6eN5WxmYbDZOU41Faqghir6U1XI wre9ft2rThl7
4APf15ijja9e3WtfCFu3vhFWsH3zW0zDbvijM30lLl3bSLYW8qd2rEl1Xave q6o3qNXV6k9b
WUtR6jKVrIwqDPyAWGck5rdT8IMpictard5xq7AF/2sfvbrTXYL1jzWJJItH jN0R79S6L+5p
ip2s4huH2MaJ7G2XaSxmEYdyhotJ6WQr3Nj3BrPNF9YwhTX8WA/H9KX+BbCA qZpMm2TYzwxe
cKAdbNkIv5m+ha7vm+ObU/02k791/rCv2hJehIZ2kCtFbnRN69pLV/e7FuY0 py092k03t7yU
Jm8+B0rP4AK3n5ZG7mmZO+vShjXWm7Z1rkXb6VFn19eYtjB2gT1sT3vXvMdG 53iRfWpmsxM9
vbJQmikLZz8beL7kvDaCJ4zhmSy6so0mbIdhgNgpXLavsl30n3W6Wm+7192V lTFWOyrfbvOU
3fLO9qDBzeF9N5o0FfpHKv/eWte5DrzgBKfrwRWecIbPMao0nWpcG45wg098 4RXHOMU17lSJ
Z/ziGw/kS14C7YBD2uT9Pnkzxa2Ckh6TGy+HecxlPnOa19zmN8d5znVOc5QL 89E9BymFFoPq
Zae66EcnetIdGuaI7tzpT4d61KXODaVHVNlVR/pDRQ6etujP6+Db3/zA/nX5 5W/s7pl62tW+
9p2T3X5lr5/YbdYVgAPcMne3Cj6Cwna+953vWaEG3meydZLbXfCHV0rg9+53 xjde51qZBuIr
Fx7EVz4qep9G5pmR+Wk0g/Obf4nlRQ8UfyD+JangupRGr6jREyXwqNgGNbZR jdnXXva0r0br
da//E8UL3j3TqDtSWC+T4dcEBTxZ1E2Ov3uhYJ7226g99J9fe+ZXnya9xzvq UV944S//H8Wn
ifd1Iv7wWx8or9/GDbYQ+EIYYgvv3wIMbpB781c/8of/ffCPcnz+f5/4w0++ 7wM/4vs/ADRA
8qs/mQi8adiG95uJbUjACLwOxNO+1JM0o+i/DJyJ/rMJ8ls+7+NA/yNACZSJ yEuF9NuC3Gu/
PygE+Is/Emw97Lu7/KM8DBxB/tMaESxADxxB/wPBDYTBf9A7VagGBwzCBJRB y0gF4LNACxG+
G9TBHvzB8tPBEJxCEmQ/6BOPf2i/91M/sILAI6y8+/O909M/Gyy/H7xC/x6s wjbsQQkcwv8q
BADbwsCzQzG0vNI7PO2bBu7bP+MrwA38wAAMRDUMvwGMwCTkQvdrwS24gRvA w8pTxOyrwUhs
Pb2zCVXoQviTLUvEu0mUjDNrC0/UPVAkRdEjw0/kj0o8RclrRevTQ8F7iWZo woBzO7l7u1zE
xV00O7gLu17URWDkxbgTxmIkxmP8RWT0usxgxVfEO0x0xlI0vcTww2j0PWvU vVS8O6EbRWx8
Rm8cvVhUxZFrxsZAxFacxMioCgTcCnZ0RfzrjDMsihx0wx3MCXdsRWi8Pqrq ieK7wjTcCXy8
RyDswChUvnskRK0wRcf4jmqcRyD8QEB8Qyr0Rv9FJLd+XMOBHD+h+EeJ1MiD nMir0EbLEBF5
JApDRMA1PMBA9EGWpEcBHESBfIwkbDVnCMgbZL3k00B6VMOVNL6V1MmW5EmI 9MmOvApxnEFq
LMeg6EmQFEFDlEIBjEqojMrDS0U8C7AB08iIlMKIpEorJMiCVEkC/Mp6xMFz tIqFbIx/W0qg
4El2fMm4qcIcBEG6hMhDTMi7g8YdAy4f6w+Sg0KzvEuyHEyYHEC7rMqWJMzF NEyw3Aq1PIuG
bMuf4MGUTMzLrMeppEhJ3Mf/ykp+VD65zEjGBEuj1MzELM3CZEODFEnE40bV +0MqXE2uVMw2
zEiqzEy9tIma3EjVDMv/1CTNsLTN3/TNsgzOrUBKy3i2yfSJ2dzMmHzDABQ/ 6SRI6UTLybDI
BulNnPw/2yTEt2RJvBzE7uxJf7ROl8xLrIBMswANkwTHx9DHmYg4nHC8+rRP mAOL9SwLyezG
98ROnFBHm7jPAa3PrRhJyihJ5vRPsdBPmSDQB/U75JQ8pey6s/PFWzTGZNRQ DK0fCPXQtVNG
Cw3GEL1QZuzPBXWM+OyJD2VRqMvPaVSME0XRs2jQGQ2LA52M17xAGzULzNM8 zvO8Hw09HtWK
5KSM5ZTRdSRSnEC/26s92nNS+lvSq6hRBo1HBUW+9BRO4qRM06w+54O+6BNT 2ptS9YTRWjQ8
/7fc0jVlzeb0UuZDP/VjP/fjxPkr09Y8vARNUo78TQBETw60zsN8yj+VyvA8 0n9gQCP8hzC8
UwmFxxiFTTQcVMYMTuNczMqEwjc1CxNEQRU0BBZ0wU5sVKmo0rBgyz1lyu9E TMSsTcfMVHvk
yrO8zh79ByJU1FF9Uauk0Eh9yNwEzlbNTK8czkGVybXkQi2cUy98QUbF1aXA UcnQUSeMzUkV
yuL0zT4dVmENyRStVTmkwzu8w2aVCiPFTvdwyJOUTT81TPJ0SeGsS1gNTC11 DEXswkZ8RHEl
1Qk9FFTF18u7CU2k0/cT1X49ilIFC/7kVYKdCoNVWKJ41sfQ04Rt2P+lYNiJ DQpylQwqKTwO
3VARHcaOvVCPzVCOJVmRJdERBVmUJVkTlViLRQoVddmFPdNzjdmCrVk8Fbxo DbibVQofnQbQ
67zPy7yKnViMnUlzxdInxNUmfVLbe1KePT99fYqkHT95bVNN7cCXjEAwlb4w nT4y/cliLdYy
JVqsQNgdRddtvVpJxcJ/gD05XcRQtVOKFMhZbdSHdYyIRduhUMlYBco/hUvi jEu7NdZE3YIH
RD423cx+Ndp53dW95dPArM1KvVa6tVa1fQxOVT9PBVVO9EiZHNspLVsqfQ33 5EhVDcp1LUuj
nE5qldXQJYshLMLDpUzFtd1RHV2rOFtpRcP/jvzV3y3IwcRN/DtWCExWR1zW z73JhsXbxtDZ
NK1dydVAyj3Oxb3N222MONTEb63DLVTeYC3aCSVHfo1enPRbA3xKdWXN2UTd d6yJevVCSMza
0YTJhs3dqmhPqkW81mU+mAXYUIXaqNVVSIVc5uPf3bvfAB4817xS8lVgnkjg B27ctXxcCynZ
kMVglTXZlP3YC9bgDO7gDfbgEC7RqXXgB9YJmEVh15tZ/V1h+XzhpGjes3je GA4KFbbhn5hg
GkXaE85hGL6JM8C71cTDCCbVBm7Z0yXcRoVZajCDhZTL4J1cnIhij8RcQbQ+ I46K3d3ZaY1Z
RQSDVACD5f3IK15c/+vNUuubYbPQW97tVbzUTOisX2xMwldIBTt+he20x/o9 y9yMwkA93+CF
XQSdUAJ243lU39KkTT8+xasM40WghkUQ40kcSur148BFyS1d5BicUJYtYHRd XXfV2leExkUw
gztODDs2g0VwytOc3BB8ztQVylHe5NHTYmet4C5WCuD9x0EWQ+yjhkeO5Emm YuXFTVjmUmBF
ZkEcZVRk4D9x4ZsM5ejEXjxUUTy+Yz0e1il2x+slzF4+4zwUXzTtPvOsy5yE 4zm2RjAW44Bk
1fEcT7WdTp2kTnWmZgSWWtP94Zto4ie+Cl+uyBb24X2eRCH+52Zd47JoY13e Z95r6KHYYf/2
zGXUE+GKBuGRtegP1mgS3miMvuiT5eiQHllPPuSHtgkcNmkmFegkTmnvbeme SGiyqOGXPmma
7omILgskZemULughtuJfzudont8l1uZo7GcobuZtRkgtJeKhzuKV/mSmTAqA hkF2HuOi/unQ
xcem/t7di+mxWGjoVVNmvtRANVRnrOM7zuYyXlc+duuQnOeYDGTLZT6cJguN FepWJkpXXmZn
dORUgGRJBgNKrmdlTmY2Tc1etlrOhEeSZmi2fWeilGVsLOVTfoVUToVV1utp plRRRudv1lqs
vcYBJuepFtzTDudXBGZhFmxKNubCnGLUHM5urma8+2qxmGml3Wa9zqZsm8Dm PGZr3m5Twczk
ex7uyrPrsdDpqB5reGVmOS7Udb6JML7qpf7s9MVueRbPtobuPYbToB7oqaBq Tzzqg15aqC5p
rFhscOxp8x7V2w6LsLbpmrhlnk1uKzVkW8xokQZpj+7o/gZwDvZv/hbwAB/h kTbhnTZplJ5v
l7btiW5wII7wm4BvsMjtBmfw+b5vU+1hBX/o+r5ZEEeK/A3vHM5wmxbxo+Bi sf7wCceJCkdO
JGbuFndxm9hwsAgIADs=
--------------030002020809060109050703--
Re: Cannot delete connection when specified field in the property isfilled in with content [message #195756 is a reply to message #195693] |
Fri, 04 July 2008 03:31  |
Hi Alex,
thanks very much, your advice was brilliant :). My model was not
updated. Now everything works fine.
> Hello Bonkers,
>> cast to org.eclipse.emf.ecore.EObject at
>> at
> I'm suggesting you yo pout breakpoint somewhere here to see the reason
> of this class cast exception (particular reference in your domain model)...
> The strange thing is: exception was caused by calling
> org.eclipse.erm.schema.impl.RelationImpl.unsetFK_Reference(R elationImpl.java:369).
> AFAIKSee from the trace old value of this feature was instance of
> java.lang.Boolean, in the same time EMF AFAIU is waiting for EObject
> instance here (based on the metainformation of your model..)
> Alex Shatalin
FUDForum. Page generated in 0.08259 seconds
